excavated deeper than calculated depth
The actual digged or excavated depth is 2 meters to reach certain tuff rock layer, calculated depth of design is 1.5 meters.. what do you normally do in case like this?
1. Increase column size to control deflection
2. Put more bars to control deflection
3. Or nothing at all taking into account that the extra column length is below grade and the soil covering it can just hold it?
What do you usually do in your experience?
RE: excavated deeper than calculated depth
BA
The firm I started with in 1955 used an unreinforced pedestal atop each footing which had a dimension of one third of the footing size. That was large enough that it did not need to be reinforced. Its height could be varied to meet different site conditions without changing other design parameters.
Needless to say, it was not intended to handle columns with base moments required for stability.
BA
Alternatively, you can put the footing at the 2.0 m level and provide a stocky pedestal up to the underside of column.
You do not redesign the column for every minor site discrepancy.
BA
BA didn't say anything about redesigning the columns. Just make the footing thicker, or as he suggested, place low strength concrete up to the intended footing base. Using the blinding layer to make up the overrun has the added advantage of giving you a nice level surface for supporting the footing cage and placing the concrete.
You seem to be making a big issue out of a situation which arises frequently with foundations. I don't know what more I can tell you. Maybe someone else has something more pertinent to say.
BA
I'm a new construction engineer. I guess I have to ask the structural designers about it. But my fellow construction engineers said for 0.5 meter difference.. they never bother ask the structural designers since 0.5 meter is just short and negligible or within allowance...
Whenever a change occurs which affects design, the structural engineer of record must be notified. It is his job to determine whether or not the additional 0.5m will affect his design, not yours. You must ask the structural engineer what method he wishes to use to extend the structure down to bedrock.
Your "fellow construction engineers" are completely off base with their comment and should be told so in no uncertain terms. They are a bad influence on you as a new construction engineer. Ask the designer what he wants to do and then do it.
BA
Quickest and easiest is to fill the 500mm with "blinding" concrete. But if this is over the entire site, it might be financially viable to have a look at redesigning the columns for the extra length.
Our office puts a condition that the contractor is obligated to fill the areas over excavated in rock by concrete.
I believe strength of that concrete should not be less than the required bearing capacity of the rock.
Good luck
You are making this problem too complicated by overthinking it.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
The total footings concrete already reach 60 cubic meter. If we add another 0.5m, it would add another 48 cubic meters for total of 108 cubic meter. The cost would be huge. Do you really implement this? Anyway. I'll just have the columns recalculated to see if additional 0.5 meter would still make it stable and redesigning it accordingly.
Also as I have mentioned 2 meters below is hard rock. The calculations used assumed value of 150kpa... now it's more like 500kpa. But the contracts and payments already made so I think there is no problem with the footings actually larger than needed, is there? Because if they were changed smallers, the contract would still be the same and no refund or deduction will be issued.
Perhaps the footings could be reduced in area and increased in thickness such that the volume remains about the same. Footing reinforcement could be reduced both in length and number of bars so there should be a net saving in materials.
BA
I don't know your definition of Tuff. You assume it is softer hence less than 150 kpa? I'm talking of tuff rock that is 400 kpa or so. We didn't know the depth of the tuff initially. I'm concerned of your statement that if footing is designed for 150 kpa.. it is not designed for let say 400 kpa?? But the load (live and dead ) will be the same. Hence I assume that it will even be better putting a 150 kpa designed footing on 400 kpa soil because the latter is simply harder hence the footing is like kinda oversized larger but no harm at all because the live and dead load won't change.
What we intend to do is to put the 150kpa designed footing putting right on the rock and just let the designers change the column parameter for the extra 0.5 meter length. We don't want to change the design of the footing anymore. So there is absolutely no problem in putting the 150 kpa footing - as is- right on the say 1000kpa rock, correct?
Mike McCann
MMC Engineering
I agree with your last statement. One other (pedantic) thing. Mr Pascal's name should alway be respected by capitalizing...kPa.
There is no problem doing that, but you are wasting material. Why don't you want to change the design of the footing anymore? Why not stop and think about it and come up with a sensible design? Why do you insist on making decisions without reviewing all possibilities?
I suggest you sit down with all concerned and see if you can come up with something a little more intelligent than what you have proposed.
BA
Because the designers said they no longer have time to redesign the whole footing just to accomodate the increased bearing capacity.. and they also said 0.5 to 1 meter length increase of the column can be made without changing any of the design... because they have large margin of safety already. So we'll use as is. And base on my own calculations, the bonus of having increase bearing capacity than designed is one more floor can be added in the future... which of course will be coordinatated with the designers. Thanks to your assistance anyway.
By chance, would you be related or work with Pattontom?
If load is assumed to be spread evenly over the footing area, you will have no additional capacity to carry another floor. Footing capacity will be controlled by the reinforcement which has presumably been designed to carry the present design load.
If you want to obtain additional capacity, use a square concrete pedestal 0.5m high on top of each footing. If the side dimension of the pedestal is 1/3 the dimension of the footing, you will increase the footing capacity substantially because you will reduce the cantilever length of the footing to L/3.
BA
Thanks BAretired for the statement. Bending moments of footings are indeed controlled by reinforcement in the form of qu= factored column load / bearing area. So even if the soil capacity increases 5 times fold (from say 150 kpa to 750 kpa). If the shear, moment reinforcement is the same, increasing the column load would only strain the moment and shear bars even though actual soil bearing is higher. So from the beginning the reinforcements must be designed already. This is what you are emphasizing, agree?
Also from the formula. Increasing footing area would make designed qu or net upward soil pressure less requiring lesser bars. I'm wondering. Do you in practice use larger footing and less bars but more concrete for more overturning stability (instead of smaller footing and strong bars to obey the qu=factored column load/bearing area formula?
Now, suppose we add a pedestal 0.9 x 0.9 x 0.5 high to the top of footing. Factored soil pressure qudoes not change but the cantilever length becomes (2.7-0.9)/2 = 0.9m and Mu = 2.7qu*0.92/2 = 1.0935qu, a mere 61% of the moment without the pedestal. If the soil bearing is sufficient, this means a potential increase of 63% in permissible column load using the original footing reinforcement. The cost of the additional 0.4 cubic meters of concrete is trivial compared to the added benefit in additional load carrying capability of the footing.
In the above, I was considering a centrally loaded square footing with no consideration for overturning. In most buildings, overturning is not carried by individual pad footings but rather by stiff elements such as elevator shafts.
BA
BA and Hokie.... I wonder if this OP’er. isn’t from the same neck of the woods, or at least the same school of engineering thought, knowledge and logic, as the guy we dealt with a few weeks ago on the eccentric footings, etc. etc. They don’t have the time to redesign footings for rock, but they can find the time to redesign the frames and columns, and now are even planning on adding another floor?
What the heck kind of engineering really goes on in their neck of the woods? He claims there was some GeoTech involvement in the foundation design, but then they didn’t know there was solid rock .5m below the intended bottom of footing elevation during their original design? I can’t believe this. This shouldn’t even be called engineering, because it certainly isn’t by any stretch of the imagination. One wonders if some of the good advice being given here might not actually be twisted around, and be mis-applied or mis-used. This kind of so called engineering is down right dangerous, and probably shouldn’t be aided and abetted.
I was wondering the same thing. See my latest post. I am not expecting an answer, but if not, there are other ways of finding out.
I'm not sure whether the footings at design depth (1.5m) can safely sustain the loads using design pressures provided by the geotechnical engineer without extending them down by an additional 0.5m.
I'm not sure why it would be a huge cost to increase the thickness of the footings by 0.5m but there would be no financial consideration for reducing material quantities where possible to achieve a better design.
I'm not sure why the Structural Engineer of Record does not have time to get properly involved in the construction phase of the project.
In the absence of more information, I don't see how I can contribute to this thread in a meaningful way.
BA
