Looking for an ABS to Rubber solution.
I am needing to attach a seal to ABS, the Seal material is still up in the air but rubber / silicone are very likely. Is there any chemical solvents that will hermetically attach ABS to Rubber or the like and hold while under 80psi of pressure?
RE: Looking for an ABS to Rubber solution.
If you choose to use an actual adhesive material, here is a design guide from Henkel:
http://www.henkelna.com/us/content_data/14105_LT26...
