Influence of electromagnetic pipeline mapper in magnetic flowmeters
I'm looking for references and/or comments about the effects that can be produced from a Electromagnetic Pipeline Mapper (e.g. Link) on a magnetic flowmeter. I'd like to know any obstacle or special consideration when using both equipments at same time on a pipeline (water) of more than 10 km.
As far as I've searched the pipeline mapper systems send a current along the pipe in a range of 10 to 200 mA aproximately, with frequency in a range of 4 to 200 Hz. Basically the system work this way: A Transmitter is located a some point over the pipeline (buried) and connected to this, the operator later will carry a receiver and walk over the buried pipeline, the receiver will sense the magnetic distortion caused by the current flowing through the pipe, an especial accesory is also used to detect some imperfections with increased accuracy.
Any comment or advice is welcome
Thanks for your time
Danny Alarcón S.
Instrumentation & Control
GMI Ingenierios Consultores
Lima Perú
Danny Alarcón S.
Lima Perú
RE: Influence of electromagnetic pipeline mapper in magnetic flowmeters
