Variable Draft
Variable Draft
Similar to adding variable radius points on an edge blend, is there a way to do this on faces that you add draft too? For example if I have a forged part where the outside face varies between 10 and 20 deg draft, is there a way to model that? Thanks.
RE: Variable Draft
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Variable Draft
RE: Variable Draft
RE: Variable Draft
RE: Variable Draft
RE: Variable Draft
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Variable Draft
RE: Variable Draft
I love the way the law extension worked.
RE: Variable Draft
When using the method John showed, the Law Extension, you can also control how the surface transitions between the different angles, linearly, cubic etc. The taper is more restricted in that matter.
Tomas
RE: Variable Draft
