NX Journal Jpg Exports / Graphics Window Question
Over the last few days I've been looking into how to export framed images of the graphics windows to jpeg files through NX journaling in NX 7.5. The 'CreateFramedImage' method allows for the export of a rectangular window of the graphics window. Additionally, the function allows for you to specify this rectangular box in pixels. Unfortunately, I can see no way of identifying the pixel size (width x height) of the NX graphics window from within the journal or in the NX menus either. My ultimate goal is to export an image of the entire model (solid bodies) that is as small as possible while still containing all of the model within the image. Any help at all will be appreciated.
RE: NX Journal Jpg Exports / Graphics Window Question
Try this, I had some help creating it and it will export the current NX screen as a JPEG saved as the workpart name to a folder of your choice. I had some major helping getting it to run like this!
CODE --> vb
' NX 7.5.5.4
'http://www.eng-tips.com/viewthread.cfm?qid=327914&tmac=fav&val=1,327914
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports NXOpen.Utilities
Imports NXOpen.Layer
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim background_color As UFDisp.BackgroundColor = UFDisp.BackgroundColor.original
        Dim DisplayPart As Part = theSession.Parts.display
        Dim partName As String = Path.GetFileNameWithoutExtension(workPart.FullPath)
 'turn triad off
        theSession.Preferences.ScreenVisualization.TriadVisibility = 0
'turn WCS off
         DisplayPart.WCS.Visibility = False
        Dim folderName As String = "C:"
        Dim strPartJpg As String = ""
        Dim strCurrentDate As String = Format(Today, "dd.MM.y")
        Dim s As Session = Session.GetSession()
        Dim ui As UI = UI.GetUI()
        Dim lw As ListingWindow = s.ListingWindow
        Dim root As Component = s.Parts.Work.ComponentAssembly.RootComponent
        Dim folderBrowserDialog1 As New FolderBrowserDialog
        With folderBrowserDialog1
            .Description = "Specify folder for screenshot output"
           .ShowNewFolderButton = False
            .RootFolder = Environment.SpecialFolder.Desktop
 'use folderName as default directory
            .SelectedPath = folderName
        End With
        Dim result As DialogResult = folderBrowserDialog1.ShowDialog()
        If (result = DialogResult.OK) Then
            folderName = folderBrowserDialog1.SelectedPath
        Else
 'user pressed cancel, exit the journal
            Exit Sub
        End If
        If Not Directory.Exists(folderName) Then
            MsgBox("The specified directory does not exist, journal will now exit", MsgBoxStyle.Exclamation, folderName & " not found")
            Exit Sub
        End If
            Dim partLoadStatus2 As PartLoadStatus
            Dim status1 As PartCollection.SdpsStatus
            status1 = theSession.Parts.SetDisplay(displaypart, False, True, partLoadStatus2)
            'workPart = theSession.Parts.Work
            'displayPart = theSession.Parts.Display
            partLoadStatus2.Dispose()
        strPartJpg = Path.GetFileNameWithoutExtension(workPart.FullPath) & "_" & strCurrentDate & ".jpg"
        strPartJpg = Path.Combine(folderName, strPartJpg)
        ufs.Disp.CreateImage(strPartJpg, UFDisp.ImageFormat.Jpeg, background_color)
 'turn triad on
        theSession.Preferences.ScreenVisualization.TriadVisibility = 1
'turn WCS off
         DisplayPart.WCS.Visibility = true
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
 'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
dhusk09,
I appreciate your quick feedback. However, I am able to export the entire graphics window without any issues. My main issue still remains to be specifying a rectangular box within the graphics window that will be exported. Additionally, I still have no way of identifying the window size in pixels from within the journal.
Okay, so I found a jerry-rigged way of finding the graphics window's pixel size:
Option Strict Off
Imports System
Imports System.IO
Imports System.Text
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports System.Xml
Module NXJournal
Sub Main
Dim pixel_x As Integer
Dim pixel_y As Integer
theSession.Preferences.HighQualityImageVisualization.GetImageSize(size_dummy, pixel_x, pixel_y)
End Sub
Where pixel_x and pixel_y contain the number of pixels of the graphics window. However, an issue arises when the nx window is resized without executing an action that redetermines the graphics window size. This can easily be achieved by the following lines (renders the current viewing window):
workPart.ModelingViews.WorkView.HiqhQualityImage.Generate()
workPart.ModelingViews.WorkView.HiqhQualityImage.Erase()
