Defining a stop connector to limit motion?
can anyone please advise me to define a stop connector inside abaqus cae? I believe I have set up everything correctly, but after adding the stop connect there is no displacment in my model anymore :(.
I try to stretch a one sided closed tube moving a stamp inside it (rigid body), pressing to the tube bottom until the bottom is contacting a mould (rigid body). Contact is defined as surface to surface and hard contact. The motion of the stamp is limited by a fixed value.
I did:
- Interaction-Module => Menue Connector => Geometry => Create Wire
- Interaction-Module => Menue Connector => Section => Create (Category Basic; Trans. Connection Type Slot, Rot. Connection Type None, Behaveaur Options Stop with Component U1, Positions at Stop 50, 50)
- Interaction-Module => Menue Connector => Assignment (mit CSYS +x-Richtung in Bewegungsrichtung)
After adding the stop connector there is no motion. What could be wrong - any ideas? Is there anybody who has a simple model with a stop connetor to have a look at it and learn/compare with my model?
Is there a simplier possibility to stop the motion without a stop connector?
RE: Defining a stop connector to limit motion?
It looks like your connector has stop from the beginning of the analysis.
You can check it with stop/lock connector flag which can be save into history output.
For connector stop you define minimal and maximal connector position (it is connector length no connector displacement).
Lets make simple example with keywords. Initial length of your connector is 25.0 [mm] and you want to set stop
when the connector extend by 10.0 [mm] and shrink by 15.0 [mm] you need to define stop as follow:
CODE
** min stop = 25.0 - 15.0 = 10.0
** max stop = 25.0 + 10.0 = 35.0
*CONNECTOR STOP, COMPONENT=1
10.0, 35.0
Bartosz
Hallo Bartosz,
thanks al lot for the very helpful hint. Indeed, the connector has stopped from the beginning, but for me it is absolutely unclear why. May be there is a dependency from the node order of definining the wire? After redefining the model again, the connector is free from the beginnning, but unfortunately the model behavier on simulation with the connector is totally different from that model without the connector.
Before adding the connector the model was working well until the point of too much compression in the contact area resulting in excessive material non linearity. After adding the connector with stop and lock behavier to limit motion and compression, the simulation terminated at the first increment with "Too many attempts made for this increment" and "Excessive distortion at a total of 470 integration points in solid (continuum) elements" already from the beginning.
SUMMARY OF JOB INFORMATION:
STEP INC ATT SEVERE EQUIL TOTAL TOTAL STEP INC OF DOF IF
DISCON ITERS ITERS TIME/ TIME/LPF TIME/LPF MONITOR RIKS
ITERS FREQ
1 1 1U 1 1 2 0.000 0.000 1.000e-005
1 1 2U 1 1 2 0.000 0.000 2.500e-006
1 1 3U 1 1 2 0.000 0.000 6.250e-007
1 1 4U 1 1 2 0.000 0.000 1.563e-007
1 1 5U 1 1 2 0.000 0.000 3.906e-008
THE ANALYSIS HAS NOT BEEN COMPLETED
In addition I got a "zero pivot when processing DOF 1" at the connector element, which is defined between two rigid bodies Reference points. One of them is fixed in all directions, because the mould is fixed.
Any ideas for troubleshooting?
Regards berounba
In one case it is true in other not. It depend what type connector you are using.
For instance it's not true for AXIAL since displacement output is always positive.
But for TRANSLATOR where the output is in local coordinate system node ordering make a difference so it has influence also for connector stop/lock.
Do you mind to share the model so I can tak a look for it.
Bartosz
the definition of the stop should be ok now in general, but I have trouble to avoid the "zero Pivot Message".
Sorry for including instaed of attaching the input file, but I have no idea where to upload the file.
CODE -->
*Heading
** Job name: Stretch-Con-Stop-21-Forum Model name: Model-21-Con-Forum
** Generated by: Abaqus/CAE 6.12-2
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Bl
*End Part
*Part, name=Pr
*Node
      1,   1.49245393,  -59.9907532
      2,           0.,         -60.
      3,           0.,        -62.5
      4,   1.04999995,        -62.5
      5,   1.49245393,         -58.
      6,           0.,         -58.
      7,          3.5,  -59.9489822
      8,   4.05190897,  -59.9316063
      9,          3.5,         -58.
     10,   4.05190945,         -58.
     11,   7.05145121,  -55.0523949
     12,   10.0010624,  -55.0523949
     13,   7.14896154,  -59.7868996
     14,   5.70948505,  -57.5004883
     15,   6.41781425,  -56.8445854
     16,   9.96977997,  -56.8445854
     17,           0.,  -60.8333321
     18,           0.,  -61.6666679
     19,   1.19748461,  -61.6635857
     20,   1.34496927,  -60.8271713
     21,   1.49245393,  -58.9953766
     22,           0.,         -59.
     23,   2.49631429,  -59.9740677
     24,   4.05190897,  -58.9658051
     25,   2.49622703,         -58.
     26,   8.52625656,  -55.0523949
     27,   5.60090256,  -59.8692551
     28,   6.42922306,   -58.643692
     29,   4.91751146,  -57.8724098
     30,   8.19379711,  -56.8445854
     31,   9.98542118,  -55.9484901
     32,   6.88033485,  -56.0000038
     33,   8.22914219,  -59.5153046
     34,   9.13579655,  -58.8683662
     35,    9.7439518,  -57.9352531
     36,   2.49627066,  -58.9870338
     37,          3.5,  -58.9744911
     38,   5.25920725,  -58.8708305
     39,   8.43287849,   -55.974247
     40,   8.31672096,  -58.2877998
     41,   7.44520855,  -58.8076782
     42,   7.08537483,  -57.8214722
     43,   10.0610085,  -51.6181068
     44,   10.0809898,  -50.4733429
     45,   10.1009722,  -49.3285828
     46,   10.1209536,  -48.1838188
     47,   10.1409359,  -47.0390549
     48,   10.1609182,  -45.8942947
     49,   10.1808996,  -44.7495308
     50,    10.200882,  -43.6047707
     51,   10.2208633,  -42.4600067
     52,   10.2408457,  -41.3152428
     53,   10.2608271,  -40.1704826
     54,   10.2808094,  -39.0257187
     55,   10.3007908,  -37.8809586
     56,   10.3207731,  -36.7361946
     57,   10.3407545,  -35.5914307
     58,   10.3607368,  -34.4466705
     59,   10.3807192,  -33.3019066
     60,   10.4007006,  -32.1571465
     61,   10.4206829,  -31.0123825
     62,   10.4406643,  -29.8676205
     63,   10.4606466,  -28.7228584
     64,    10.480628,  -27.5780945
     65,   10.5006104,  -26.4333324
     66,   10.5205917,  -25.2885704
     67,   10.5405741,  -24.1438084
     68,   10.5605555,  -22.9990463
     69,   10.5805378,  -21.8542824
     70,   10.6005201,  -20.7095203
     71,   10.6205015,  -19.5647583
     72,   10.6404839,  -18.4199963
     73,   10.6604652,  -17.2752323
     74,   10.6804476,  -16.1304703
     75,    10.700429,  -14.9857082
     76,   10.7374229,  -12.8663568
     77,    9.3050518,  -9.87049961
     78,   7.82038784,  -11.0000477
     79,   7.80067158,  -12.1295948
     80,   7.78095531,  -13.2591419
     81,   7.76123905,   -14.388689
     82,   7.74152279,  -15.5182371
     83,   7.72180605,  -16.6477833
     84,   7.70208979,  -17.7773323
     85,   7.68237352,  -18.9068794
     86,   7.66265726,  -20.0364265
     87,     7.642941,  -21.1659737
     88,   7.62322474,  -22.2955208
     89,   7.60350847,  -23.4250679
     90,   7.58379221,   -24.554615
     91,   7.56407547,  -25.6841621
     92,   7.54435921,  -26.8137093
     93,   7.52464294,  -27.9432583
     94,   7.50492668,  -29.0728054
     95,   7.48521042,  -30.2023525
     96,   7.46549416,  -31.3318996
     97,   7.44577789,  -32.4614487
     98,   7.42606163,  -33.5909958
     99,   7.40634489,  -34.7205429
    100,   7.38662863,    -35.85009
    101,   7.36691236,  -36.9796371
    102,    7.3471961,  -38.1091843
    103,   7.32747984,  -39.2387314
    104,   7.30776358,  -40.3682785
    105,   7.28804731,  -41.4978256
    106,   7.26833105,  -42.6273727
    107,   7.24861431,  -43.7569199
    108,   7.22889805,   -44.886467
    109,   7.20918179,  -46.0160141
    110,   7.18946552,  -47.1455612
    111,   7.16974926,  -48.2751083
    112,     7.150033,  -49.4046555
    113,   7.13031673,  -50.5342026
    114,   7.11060047,  -51.6637535
    115,   7.09088373,  -52.7933006
    116,   7.07116747,  -53.9228477
    117,   10.7204113,  -13.8409462
    118,    7.8401041,  -9.87049961
    119,   10.7700005,  -9.87049961
    120,   10.7700005,         -11.
    121,   10.7544346,  -11.8917675
    122,   10.0210447,  -53.9076309
    123,   10.0410261,   -52.762867
    124,   8.54610538,  -53.9152374
    125,   8.56595516,  -52.7780838
    126,   8.58580399,  -51.6409302
    127,   8.60565281,  -50.5037727
    128,   8.62550259,  -49.3666191
    129,   8.64535141,  -48.2294655
    130,   8.66520023,   -47.092308
    131,   8.68505001,  -45.9551544
    132,   8.70489883,  -44.8180008
    133,   8.72474766,  -43.6808434
    134,   8.74459648,  -42.5436897
    135,   8.76444626,  -41.4065361
    136,   8.78429508,  -40.2693787
    137,   8.80414391,   -39.132225
    138,   8.82399368,  -37.9950714
    139,   8.84384251,   -36.857914
    140,   8.86369133,  -35.7207603
    141,   8.88354111,  -34.5836067
    142,   8.90338993,  -33.4464493
    143,   8.92323875,  -32.3092957
    144,   8.94308853,  -31.1721401
    145,   8.96293736,  -30.0349865
    146,   8.98278618,   -28.897831
    147,   9.00263596,  -27.7606754
    148,   9.02248478,  -26.6235218
    149,    9.0423336,  -25.4863663
    150,   9.06218243,  -24.3492107
    151,    9.0820322,  -23.2120571
    152,   9.10188103,  -22.0749016
    153,   9.12172985,   -20.937748
    154,   9.14157963,  -19.8005924
    155,   9.16142845,  -18.6634369
    156,   9.18127728,  -17.5262833
    157,   9.20112705,  -16.3891277
    158,   9.22097588,  -15.2519722
    159,    9.2408247,  -14.1148176
    160,   9.25918865,  -13.0627489
    161,    9.2775526,  -12.0106812
    162,   9.29519367,  -11.0000238
*Element, type=CAX3H
1,  1,  2, 20
2,  2, 17, 20
3, 20, 17, 19
4, 17, 18, 19
5, 19, 18,  4
6, 18,  3,  4
 7,  2,  1, 22
 8,  1, 21, 22
 9, 22, 21,  6
10, 21,  5,  6
11,  5, 21, 36
12, 36, 25,  5
13, 21,  1, 23
14, 23, 36, 21
15, 25, 36, 37
16, 37,  9, 25
17, 36, 23,  7
18,  7, 37, 36
19,  9, 37, 24
20, 24, 10,  9
21, 37,  7,  8
22,  8, 24, 37
23, 10, 24, 29
24, 24, 38, 29
25, 24,  8, 38
26,  8, 27, 38
27, 29, 38, 14
28, 38, 28, 14
29, 38, 27, 28
30, 27, 13, 28
31, 15, 30, 32
32, 30, 39, 32
33, 30, 16, 39
34, 16, 31, 39
35, 32, 39, 11
36, 39, 26, 11
37, 39, 31, 26
38, 31, 12, 26
39, 16, 30, 35
40, 42, 30, 15
41, 40, 35, 30
42, 42, 14, 28
43, 42, 41, 40
44, 42, 28, 41
45, 41, 13, 33
46, 40, 33, 34
47, 40, 34, 35
48, 41, 28, 13
49, 41, 33, 40
50, 42, 40, 30
51, 42, 15, 14
 52,  11,  26, 116
 53,  26, 124, 116
 54,  26,  12, 124
 55,  12, 122, 124
 56, 116, 124, 115
 57, 124, 125, 115
 58, 124, 122, 125
 59, 122, 123, 125
 60, 115, 125, 114
 61, 125, 126, 114
 62, 125, 123, 126
 63, 123,  43, 126
 64, 114, 126, 113
 65, 126, 127, 113
 66, 126,  43, 127
 67,  43,  44, 127
 68, 113, 127, 112
 69, 127, 128, 112
 70, 127,  44, 128
 71,  44,  45, 128
 72, 112, 128, 111
 73, 128, 129, 111
 74, 128,  45, 129
 75,  45,  46, 129
 76, 111, 129, 110
 77, 129, 130, 110
 78, 129,  46, 130
 79,  46,  47, 130
 80, 110, 130, 109
 81, 130, 131, 109
 82, 130,  47, 131
 83,  47,  48, 131
 84, 109, 131, 108
 85, 131, 132, 108
 86, 131,  48, 132
 87,  48,  49, 132
 88, 108, 132, 107
 89, 132, 133, 107
 90, 132,  49, 133
 91,  49,  50, 133
 92, 107, 133, 106
 93, 133, 134, 106
 94, 133,  50, 134
 95,  50,  51, 134
 96, 106, 134, 105
 97, 134, 135, 105
 98, 134,  51, 135
 99,  51,  52, 135
100, 105, 135, 104
101, 135, 136, 104
102, 135,  52, 136
103,  52,  53, 136
104, 104, 136, 103
105, 136, 137, 103
106, 136,  53, 137
107,  53,  54, 137
108, 103, 137, 102
109, 137, 138, 102
110, 137,  54, 138
111,  54,  55, 138
112, 102, 138, 101
113, 138, 139, 101
114, 138,  55, 139
115,  55,  56, 139
116, 101, 139, 100
117, 139, 140, 100
118, 139,  56, 140
119,  56,  57, 140
120, 100, 140,  99
121, 140, 141,  99
122, 140,  57, 141
123,  57,  58, 141
124,  99, 141,  98
125, 141, 142,  98
126, 141,  58, 142
127,  58,  59, 142
128,  98, 142,  97
129, 142, 143,  97
130, 142,  59, 143
131,  59,  60, 143
132,  97, 143,  96
133, 143, 144,  96
134, 143,  60, 144
135,  60,  61, 144
136,  96, 144,  95
137, 144, 145,  95
138, 144,  61, 145
139,  61,  62, 145
140,  95, 145,  94
141, 145, 146,  94
142, 145,  62, 146
143,  62,  63, 146
144,  94, 146,  93
145, 146, 147,  93
146, 146,  63, 147
147,  63,  64, 147
148,  93, 147,  92
149, 147, 148,  92
150, 147,  64, 148
151,  64,  65, 148
152,  92, 148,  91
153, 148, 149,  91
154, 148,  65, 149
155,  65,  66, 149
156,  91, 149,  90
157, 149, 150,  90
158, 149,  66, 150
159,  66,  67, 150
160,  90, 150,  89
161, 150, 151,  89
162, 150,  67, 151
163,  67,  68, 151
164,  89, 151,  88
165, 151, 152,  88
166, 151,  68, 152
167,  68,  69, 152
168,  88, 152,  87
169, 152, 153,  87
170, 152,  69, 153
171,  69,  70, 153
172,  87, 153,  86
173, 153, 154,  86
174, 153,  70, 154
175,  70,  71, 154
176,  86, 154,  85
177, 154, 155,  85
178, 154,  71, 155
179,  71,  72, 155
180,  85, 155,  84
181, 155, 156,  84
182, 155,  72, 156
183,  72,  73, 156
184,  84, 156,  83
185, 156, 157,  83
186, 156,  73, 157
187,  73,  74, 157
188,  83, 157,  82
189, 157, 158,  82
190, 157,  74, 158
191,  74,  75, 158
192,  82, 158,  81
193, 158, 159,  81
194, 158,  75, 159
195,  75, 117, 159
196,  81, 159,  80
197, 159, 160,  80
198, 159, 117, 160
199, 117,  76, 160
200,  80, 160,  79
201, 160, 161,  79
202, 160,  76, 161
203,  76, 121, 161
204,  79, 161,  78
205, 161, 162,  78
206, 161, 121, 162
207, 121, 120, 162
208,  78, 162, 118
209, 162,  77, 118
210, 162, 120,  77
211, 120, 119,  77
*Nset, nset=Axis
  2,  3,  6, 17, 18, 22
*Elset, elset=Axis
 2, 4, 6, 7, 9
*Nset, nset=_PickedSet16, internal, generate
   1,  162,    1
*Elset, elset=_PickedSet16, internal, generate
   1,  211,    1
*Nset, nset=Mndg
  77, 118, 119
*Elset, elset=Mndg
 209, 211
** Section: Section-Pr
*Solid Section, elset=_PickedSet16, material=Plastics
*End Part
*Part, name=St
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=St, part=St
          0., -57.999999999997,           0.
*Node
      1,           0.,           0.,           0.
*Nset, nset=St-RefPt_, internal
1,
*Surface, type=SEGMENTS, name=Surf-St
START,           0.,          5.5
 LINE,           4.,          5.5
 LINE,           4., 0.500000000000002
 CIRCL,          3.5,           0.,          3.5, 0.500000000000002
 LINE,           0.,           0.
*Rigid Body, ref node=St-RefPt_, analytical surface=Surf-St
*End Instance
*Instance, name=Bl, part=Bl
*Node
      1,           0.,         -90.,           0.
*Nset, nset=Bl-RefPt_, internal
1,
*Surface, type=SEGMENTS, name=Surf-Bl
START,           0.,         -90.
 LINE,          14.,         -90.
*Rigid Body, ref node=Bl-RefPt_, analytical surface=Surf-Bl
*End Instance
*Instance, name=Pr, part=Pr
*End Instance
*Element, type=CONN2D2
1, St.1, Bl.1
*Connector Section, elset=Wire-1-Connector-Set-1, behavior=ConnSect-1
Slot,
Csys-1-Connector,
*Nset, nset=Ref_St, instance=St
 1,
*Nset, nset=_PickedSet98, internal, instance=St
 1,
*Nset, nset=_PickedSet172, internal, instance=St
 1,
*Nset, nset=Ref_Bl, instance=Bl
 1,
*Nset, nset=Wire-1-Connector-Set-1, instance=Bl
 1,
*Nset, nset=Wire-1-Connector-Set-1, instance=St
 1,
*Elset, elset=Wire-1-Connector-Set-1
 1,
*Nset, nset=_PickedSet189, internal, instance=Bl
 1,
*Elset, elset=_Surf-Pr-outside_S1, internal, instance=Pr
  26,  30,  34,  38,  55,  59,  63,  67,  71,  75,  79,  83,  87,  91,  95,  99
 103, 107, 111, 115, 119, 123, 127, 131, 135, 139, 143, 147, 151, 155, 159, 163
 167, 171, 175, 179, 183, 187, 191, 195, 199, 203, 207, 211
*Elset, elset=_Surf-Pr-outside_S2, internal, instance=Pr
  6, 13, 17, 21, 45, 46, 47
*Elset, elset=_Surf-Pr-outside_S3, internal, instance=Pr
  1,  3,  5, 39
*Surface, type=ELEMENT, name=Surf-Pr-outside
_Surf-Pr-outside_S1, S1
_Surf-Pr-outside_S2, S2
_Surf-Pr-outside_S3, S3
*Elset, elset=_Surf-Pre_inside_S2, internal, instance=Pr
 10, 12, 16, 20
*Elset, elset=_Surf-Pre_inside_S3, internal, instance=Pr
 31, 35
*Surface, type=ELEMENT, name=Surf-Pre_inside
_Surf-Pre_inside_S2, S2
_Surf-Pre_inside_S3, S3
*Orientation, name=Csys-1-Connector
          0.,          -1.,           0.,           0.,           0.,           1.
1, 0.
*End Assembly
*Connector Behavior, name=ConnSect-1
*Connector Stop, component=1
1.5, 100.
** MATERIALS
*Material, name=Plastics
*Density
 1.4e-09,
*Hyperelastic, yeoh, test data input, poisson=0.4
*Biaxial Test Data, smooth=3
 1.05, 1.25
  1.4,  1.5
 1.45, 1.75
  1.4,   2.
 1.35, 2.25
 1.25,  2.5
  1.2, 2.75
 1.15,   3.
 1.35, 3.25
*Material, name=steel
*Conductivity
 4.9e+11,
*Density
 7.85e-09,
*Elastic
210000., 0.3
** INTERACTION PROPERTIES
*Surface Interaction, name=IntProp-Bl
1.,
*Friction
0.,
*Surface Behavior, pressure-overclosure=HARD
*Surface Interaction, name=IntProp-St
1.,
*Friction
0.,
** PHYSICAL CONSTANTS
*Physical Constants, absolute zero=273.15
** BOUNDARY CONDITIONS
** Name: BC-Bf-fix Type: Displacement/Rotation
*Boundary
_PickedSet189, 1, 1
_PickedSet189, 2, 2
_PickedSet189, 6, 6
** Name: BC-Pr-Axis-fix-rad Type: Displacement/Rotation
*Boundary
Pr.Axis, 1, 1
** Name: BC-Pr-Mn-fix Type: Displacement/Rotation
*Boundary
Pr.Mndg, 1, 1
Pr.Mndg, 2, 2
** Name: BC-St_fix_rad Type: Displacement/Rotation
*Boundary
_PickedSet98, 1, 1
_PickedSet98, 6, 6
** INTERACTIONS
** Interaction: Int-Bl-Pr
*Contact Pair, interaction=IntProp-Bl, type=SURFACE TO SURFACE, tracking=STATE
Surf-Pr-outside, Bl.Surf-Bl
** Interaction: Int-St-Pr
*Contact Pair, interaction=IntProp-St, type=SURFACE TO SURFACE, tracking=STATE
Surf-Pre_inside, St.Surf-St
** STEP: Stretch
*Step, name=Stretch, nlgeom=YES, inc=1000000
*Static
1e-05, 0.2, 6e-30, 1e-05
** LOADS
** Name: Load-St-ax   Type: Concentrated force
*Cload
_PickedSet172, 2, -63120.
** INTERACTIONS
** Contact Controls for Interaction: Int-Bl-Pr
*Contact Controls, master=Bl.Surf-Bl, slave=Surf-Pr-outside, reset
*Contact Controls, master=Bl.Surf-Bl, slave=Surf-Pr-outside, stabilize=2.
** Contact Controls for Interaction: Int-St-Pr
*Contact Controls, master=St.Surf-St, slave=Surf-Pre_inside, reset
*Contact Controls, master=St.Surf-St, slave=Surf-Pre_inside, stabilize=2.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-2
*Output, field, variable=PRESELECT, frequency=10
** HISTORY OUTPUT: H-Output-Whole-Model
*Output, history, frequency=10
*Energy Output
ALLAE, ALLCD, ALLDMD, ALLEE, ALLFD, ALLIE, ALLJD, ALLKE, ALLKL, ALLPD, ALLQB, ALLSD, ALLSE, ALLVD, ALLWK, ETOTAL
*Contact Output
CFN1, CFN2, CFN3, CFNM
** HISTORY OUTPUT: H-Output-Connector-Set
*Element Output, elset=Wire-1-Connector-Set-1
CFAILST1, CP1, CSLST1, CU1
*End Step
Dear IceBreakerSours,
plaese make a answer in more detail. Which nodes are free in which DOF?
I took a look for you inputdeck. I changed your model and I can run it with success but not exactly what you have.
My modifications:
- I change connector type from SLOT to AXIAL
Connector lower node is already constrained with BOUNDARY in all
active DOFs (1,2,6) and upper in 1,6. So the only free direction is 2.
Since there is only one DOF free there is no point to use connector which introducing additional kinematics constrains.
AXIAL does not constrain any DOF so it not lead to model over-constrain , I think.
- I using much smaller force to run model.
You have value of 63120, now is question of what?
Base on your definition of steel I guess you are using mm, tonne, sec system of unit. Am I right?
Then force is in N, are you really apply 63 kN of force? It's huge value.
The model is not able to start any calculation with so high force.
I used 63.120 to my test.
- I changed increment settings under *STEP
- The model is stable until we have a punch displacement more than ~7 mm, after that it crash.
I think the problem here could be contact or high element deformation.
I did what I can, I hope I helped you a little bit.
I am attaching my model.
Bartosz
I must take my previous statements back; I had not tried running your INP.
The zero pivot messages are generated due to overconstraints (as explained by Bartosz above). Sometimes ABAQUS pre-processor releases some overconstraints which can result in unconstrained rigid body rotations/translations showing up as zero pivot messages.
By the way, reducing time increments isn't a great strategy when trying to investigate issues in your model. Default time increments, in a majority of cases, tend to be reasonable.
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
