weld cracking
weld cracking
If full penetartion weld was done between stiffner and angle in structural components, will it is possible for weld being cracked after galvanizing? welders say there there is lots of heat transfered because of the thickness of the weld. WPS does not say to do partial weld.
The material is SA 572 gr. 50
Please send me your comments
RE: weld cracking
RE: weld cracking
RE: weld cracking
RE: weld cracking
RE: weld cracking
RE: weld cracking
hope this helps,
