Transformers oil containment pit
I am designing foundation/oil pit and firewall for a few large transformers. However I'm having difficulties regarding the oil pit requirements. does anybody know about any code/standards which clarify the oil containment requirements for transformers?
RE: Transformers oil containment pit
http://www.epa.gov/region6/6sf/sfsites/oil/elecuti...
I am doing these designs for Canada. Do you know any guideline which is for Canada?
Section 25 prohibits a person from causing or permitting a spill and establishes a duty to report any spills that do occur. Reasonable measures must also be taken to respond to the spill and protect the environment. Section 25 also enables anyone other than the spiller to recover costs associated with responding to the spill.
http://lois-laws.justice.gc.ca/eng/acts/O-7/index....
For the last few projects, I've designed the containment for 110% of the oil volume and a 24 hour storm event. We've also used a product supplied by Albarrie (sp?) called Sorweb. This is a material that allows drainage of water, but forms an impervious gel when subjected to transformer oil. Containment pits are filled with a 'firestone' (limestone aggregate) which has a large void ratio.
Fire separation between transformers has used a 2 hour metal clad barrier, filled with mineral wool insulation. Roxul has a tested assembly.
Dik
Oil containment may be required by an environmental code to prevent the spread of oil into the environment.
These issues will depend on the size and location of the transformers (which have not been identified). The electrical code is also typically adopted by the municipality where the project will be located.
As these isues may change on a case-by-case basis with each project, you probably should talk to the local AHJ for specific details related to your project.
