IDC connector
IDC connector
I would like to know if IDC(insulation displacement connector) connectors are approved for aircraft application. Appreciated.
RE: IDC connector
Can you share more specifics, and details of the application? The more info you give, the better your response will be.
You will get good advice here, but you might also consider posting a link to this thread in the Aerospace Engineering Other Topics forum: http://eng-tips.com/threadminder.cfm?pid=31 (see Forum Policies on the proper method for cross-posting in more than one forum)
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
RE: IDC connector
Connections from an LRU to the aircraft wiring harnesses typically use 38999-series connectors or something equivalent; these have crimp on pins and sockets. There are exceptions (e.g. RF connectors). Virtually any aircraft would have platform- or fleet-level requirements that could not be met with any 'flimsy' connectors. Such requirements would be mandatory for all aircraft systems (flight safety).
Mission systems (e.g. laptops or similar commercial systems installed for a temporary purpose) might be able to get away with anything, but the fleet's Airworthiness rules would probably demand a formal waiver.
RE: IDC connector
