Cable Joints
Cable Joints
Cable Joints
I need to make a cable joint between Rubber Insulated cables(for use in sump pits)
and xlpe/pvc cables.
This happened because sump pump supplier supplied a short run of cable so not
reaching to panel board which 40 mtrs away.
This joint comes after sump pit and in trays.So xlpe/pvc cable doesnt undergo any condition
of sump pit.
So can I use xlpe/pvc cable for jointing.please advice
best regards
Abraham
RE: Cable Joints
Consider using a Scotchcast Jointing Kit. This is a LV application I am assuming, 220, 415 or 440V? The required joint is in a tray and not underwater? Google for Scotchcast.
rasevskii
