Shell and Tube Heat Exchanger
In Richardson & Coulson Vol 6, It is mentioned that in case of horizontal condensers if a single segmental baffle is being used in a horizontal position it will restrict the condensate flow,and by rotating the baffle by 90 degrees problem can be solved. Can anyone explain that why this problem would arise and the solution for the same..?
RE: Shell and Tube Heat Exchanger
Good luck,
Latexman
Latexman is right.
For shell side condensation, the baffle cut (segmental baffles) is vertical to allow the condensate to flow towards the outlet without significant liquid holdup by the baffle.
I forgot to add that to allow for liquid drainage, sometimes a small portion (window) is removed at the bottom of the vertical baffle.
Good luck,
Latexman
Whether support plates can be called baffles is ,IMHO, a moot point.
In particular when referring to condensers of the TEMA J and TEMA X shells, operating under vacuum with minimum pressure drops.
