Thrust Block for 2" Dia PVC Pipe (Glued Joints)
Two Questions Here:
1)Are thrust blocks required for Sch 80 2" Dia PVC pipe in good soil (bearing pressure is at least 1,500 PSF)? The pipe will be pressurized to at least 100 psi wuth solvent-glued joints.
I have seen some tables showing thrust block sizes for 2" PVC pipe, but a client has asked us to compute whether the pipe against the soil is adequate for thrust restraint.
My reading of AWWA C605 is that it applies only to push on joints, and am I correct in my understanding that solvent glued joints are mechanical joints?
2) If I am to analyze the bearing adequacy of just the pipe against soil how would I compute the actual bearing area of the pipe against the soil? In other words for a 2" pipe, how many square feet of the face per lineal inch or foot would be the resisting surface?
RE: Thrust Block for 2" Dia PVC Pipe (Glued Joints)
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Not sure what you application is but it is generally considered to be best practice to use flexible piping joints for underground piping.
Appreciate your input - do you have a good site or source for flexible piping joints?
Try the PVC handbook by Bell for a reference. i think it is freeley available on the Internet.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
