Weld Qualification Corrosion Test
Dear All,
I have a 304SS corrosion resistance vessel. I am wondering if the vessel welds shall conduct a corrosion resistance qualification test. If so, what is the corrosion test instruction / standard? what are the acceptance criteria?
Thank you for your advise.
Best Regards,
Oil Sands
Best Regards,
Oil Sands
RE: Weld Qualification Corrosion Test
http://www.npl.co.uk/publications/methodology-for-....
Again, if you are the end user, and you suspect that the fabrication process may have degraded the performance of the alloy, try ASTM A262.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Steve Jones
I've been involved in oil and gas for 40 years and developed some of the initial corrosion tests of welding procedures for duplex stainless steel imposed on projects in 1980 and have spelled out corrosion testing requirements for 316, 317L, 904L, etc and various nickel base alloys and weld overlays. I simply have not seen any similar requirements for 304 welding procedures and weld overlay procedures.
Steve Jones
