merging coincident nodes
I have two coincident nodes that I'm unable to merge. Does anyone know why coincident nodes would not show up as coincident when performing the check?
Thank you,
W
Thank you,
W
RE: merging coincident nodes
it sounds like either
1) both nodes are undeletable ('cause they're being used for something like loads or constraints), or
2) maybe your coincident node check says to delete a specific node (lower, higher, ...) and that one is undeletable ?
Thank you,
W
