Surface Interference
I am modeling a roadway through mountainous terrain in civil 3d. In doing so, I have created the alignment, profile, corridor, and corridor surface. I set the target of the corridor and surface as the existing surface. The corridor surface itself looks good. When I do a drive, the existing surface is overrunning the corridor surface through the new cut areas. How do I create a new surface that shows the proper interface of the corridor with the existing in cut areas?
RE: Surface Interference
