macro to project 3d point to sktech
I have 3d point and wanted to project it on to sketch with face support. I wanted to find the coorindates of the projected point
Here is the macro I am using but getting error as
GetCoordinates not support by the object
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim sketches1 As Sketches
Set sketches1 = body1.Sketches
Dim reference1 As Reference
'Set reference1 = part1.CreateReferenceFromName("Selection_RSur:(Face:(Brp:(Pa d.1;1);None:();Cf11:());Pad.1_ResultOUT;Z0;G3055)")
Dim InputObjectType(0)
InputObjectType(0)="Face"
'Dim reference1 As Reference
Dim oStatus As Status
Dim oSelection
Set Document = CATIA.ActiveDocument
Set oSelection = CATIA.ActiveDocument.Selection
oStatus = oSelection.SelectElement2 ( InputObjectType, "Select face for sketch referance", True )
Dim face
Set face= oSelection.Item(1).value
Dim sketch1 As Sketch
Set sketch1 = sketches1.Add(face)
Dim arrayOfVariantOfDouble1(8)
arrayOfVariantOfDouble1(0) = 0.000000
arrayOfVariantOfDouble1(1) = 0.000000
arrayOfVariantOfDouble1(2) = 0.000000
arrayOfVariantOfDouble1(3) = 1.000000
arrayOfVariantOfDouble1(4) = 0.000000
arrayOfVariantOfDouble1(5) = 0.000000
arrayOfVariantOfDouble1(6) = 0.000000
arrayOfVariantOfDouble1(7) = 1.000000
arrayOfVariantOfDouble1(8) = 0.000000
sketch1.SetAbsoluteAxisData arrayOfVariantOfDouble1
part1.InWorkObject = sketch1
Dim factory2D1 As Factory2D
Set factory2D1 = sketch1.OpenEdition()
Dim geometricElements1 As GeometricElements
Set geometricElements1 = sketch1.GeometricElements
Dim axis2D1 As GeometricElement
Set axis2D1 = geometricElements1.Item("AbsoluteAxis")
Dim line2D1 As CATBaseDispatch
Set line2D1 = axis2D1.GetItem("HDirection")
line2D1.ReportName = 1
Dim line2D2 As CATBaseDispatch
Set line2D2 = axis2D1.GetItem("VDirection")
line2D2.ReportName = 2
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = body1.HybridShapes
Dim reference2 As HybridShape
'Set reference2 = hybridShapes1.Item("Point.1")
Dim InputObjectType2(0)
InputObjectType2(0)="Point"
Dim oStatus1 As Status
Dim oSelection2
Set oSelection2 = CATIA.ActiveDocument.Selection
oStatus1 = oSelection2.SelectElement2 ( InputObjectType2, "Select 3D Point", True )
Dim Point
Set Point = oSelection.Item(1).value
Dim geometricElements2 As GeometricElements
Set geometricElements2 = factory2D1.CreateProjections(Point)
Dim pt As Point2D
set pt = geometricElements2.Item(1)
Dim arrayOfVariantOfDouble2(2)
Pt.GetCoordinates(arrayOfVariantOfDouble2)
MsgBox(arrayOfVariantOfDouble2(0))
MsgBox(arrayOfVariantOfDouble2(1))
sketch1.CloseEdition
part1.Update
End Sub
Shiva
