A-Pillar Aerodynamics
I have noticed that cars are tending to have recessed windshields these days. The A-pillar is broader than previous habit. It appears that the A-pillar will guide air flow around and keep it attached. My question is this, does recessing the windshield by about 1 inch allow this to work?
I had formally believed you would need a slat to take the air flow off the windshield, turn it an lay it onto the side glass.
RE: A-Pillar Aerodynamics
Quite how they manage to get the airflow to remain attached around the A pillar is not known to me, and is something that has only become common in the last 20 years.
Cheers
Greg Locock
I also believe that a slat will do the job, but nobody uses one.
Cheers
Greg Locock
Cheers
Greg Locock
