Phase Shift Keying
Phase Shift Keying
Phase Shift Keying
So we did some experimental measurements at college involving a carrier sine wave of 2Mhz being modulated using 16PSK and 16QAM modulations.
The information wave was a bunch of randomly generated '1' and '0'.
We observed the modulated signal via oscilloscope and a spectrum analyzer.
This is what we got...
16PSK (http://imageshack.us/photo/my-images/825/16pskspec...)
16QAM (http://imageshack.us/photo/my-images/404/16qamspec...)
Now I get why it's mirror ( cos' of the sums and subs of freq. and what not ... ) and I get the it's centered around 2Mhz (that being the freq. of the carrier wave ) but I don't get why the power (gain or what ever you wonna call it ) is the biggest around that freq. and falls of as we go further away ???
I would really appreciate some insight on that.
RE: Phase Shift Keying
No, I'm quite aware that not all sidelobes can be the same power .... that wouldn't even be the same signal in the end I believe.
Ok, I didn't mention that our info. wave (signal ... ) had the freq. of 100KHz (very inconvenient for transmission ergo we modulate it into a carrier wave .... ) But shouldn't our modulated signal be mirrored around 2MHz but have the highest power around 100KHz?
P.S. I would greatly appreciate any book suggestions on that topic
No, not unless you are doing frequency shifting. Your carrier at 2MHz is essentially always present, therefore, it should have the majority of the energy
TTFN
