Electronics beginner guides
Does anyone know of some good guides/electronic kits that help you learn basics about circuit elements and work your way up? For instance, a book called Make: Electronics has 36 experiments done on a breadboard that involve resistors, LEDs, switches, etc. It seems like a good book and has good review, but the lab kit required for it is way too expensive. Does anyone know of any books/kits that are similar to this book?
RE: Electronics beginner guides
There are LOTS of kits available on the web, like: https://www.sparkfun.com/categories/157 However, the question is what are your objectives?
I personally don't think that you necessarily need to brute force your way through all the components of the kits your reference. I mean, sure, it's desirable to slog through all the resistor and capacitor experiments, but are they really necessary? A decent, free sircuit simulator can do more for you for the basic circuit elements. Again, your objectives should dictate what you need to learn.
A BOEBot kit might make more sense for certain objectives: http://www.parallax.com/Store/Robots/AllRobots/tab...
or even a LEGO NXT: http://www.frys.com/product/5978894?site=sr:SEARCH...
or something simpler/cheaper: https://www.sparkfun.com/products/10170
TTFN
Thank you.
Radio Shack used to carry this stuff, but here you can get it from the author:
http://www.forrestmims.com/
Mike Halloran
Pembroke Pines, FL, USA
Learn how analogue electronics works. If you understand analogue then digital will be easier, especially when it doesn't behave as expected.
There are some decent, if not high-quality, texts here:
http://www.electronicstheory.com/COURSES/ELECTRONI...
google the phrases below for many more online tutorials:
electronics 101
passive components 101
basics of electronics
tutorial capacitor inductor
etc...
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Just to follow up IRStuff's comment about circuit simulators - there are some fine ones available for free.
LTspice for example.
Build you circuit - probe the waveforms with current and voltage traces. Try to understand why it does what it does. In many ways not much different than hands on ....and it's a lot easier/cheaper.
(2B)+(2B)' ?
