Assembly Constraint
Assembly Constraint
Assembly Constraint
Hello Eng-Tips,
Is there an Assembly Constraint alike Limit Distance from Solidworks in NX? Or another way to do something like Limit Distance? I've found this constraint useful when I'm working with mechanisms.
Regards.
RE: Assembly Constraint
Thanks jerry1423!!! There is a lot to read and practice.
btw . . . don't forget to specify what version of NX you are on
Sorry,
but NX lacks a lot in assembly environment compared to other mid and hight end CAD packages.
What you are locking for is present in Mechatronics Concept Designer, but in this environment you have to add again similar assembly constraints.
Thank you...
Using NX 8 and TC9.1
Thanks Cubalibre00, unfortunately that option is not available with the actual NX's version (7.5) odd because I just saw a Mechatronics Concept Designer video with 7.5.
