Something seasonal: what is the plural of Father Christmas
Just heard someone in the office sayings Father Christmases. Then I thought, is that correct or should it be Fathers Christmas as in brothers in law? Neither sounded right. I have also heard Santa Clauses but that doesn't sound right either. I normally use Santas as a cop out.
RE: Something seasonal: what is the plural of Father Christmas
If the two words form a proper noun that refers to a unique person or entity (usually indicated by the capitalization of all words), the plural modification goes at the very end. Father Christmases. David Joneses. The key is to never modify someone's name or title, or a company name. Home Depots. Of course, this would not be the case with Father Christmas since there is only one such entity and there should never be a reason to need the plural form. (Correct me if I'm wrong).
If the two word form a common noun, the plural goes with the noun, not the modifiers. Brothers-in-law. Act like the hyphens aren't there.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
I left out the non-hyphenated case, obviously, make the noun plural:
Sergeants Major
Sisters of Charity
Emo girls
Mothers Against Drunk Driving
All of the above have application in the singular as well.
Best to you,
Goober Dave
I would go with Fathers Christmas but Santa Clauses.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Most respectably disagree with ya, Cajun. The Cambridge Learners' Dictionary says Father Christmases. But the Cross-lingual society's reference says that there is no plural.
I couldn't find any more legitimate references, but there are plenty for the plural of proper nouns in general.
Translate Father Christmas to its Western term: Santa Claus. Plural is Santa Clauses, which can be found in many references.
Best to you,
Goober Dave
Well, Father Christmas being the slightly debauched, most certainly drunk, fat, old English bloke he probably doesn't care too much, too busy lookng for his next mince pie and pint of Christmas cheer.
Santa Claus, being a European and (basically) a saint, he might want you to be more formal and correct in his terms of address.
If we have a family of people called St Clair (or Sinclair as it is sometimes spelt), then several of them would be called St Clairs (or Sinclairs).
Similarly, if it was St Nicholas, it would be St Nicholases, which, I suppose translates to Santa Clauses.
==> Most respectably disagree with ya, Cajun.
I have no problem with that.
Good Luck
Cajun,
Thanks also for not pointing out that I typed respectably instead of respectully. I cringed at that since this is the grammar forum.
I figure if I'm extra nice, you might post us some gumbo recipes. I miss the Cajun cuisine.
Best to you,
Goober Dave
I simply did a copy and paste; I didn't even notice the misspelling until you pointed it out. As far as a gumbo recipe, first you start with a roux. After that, it's anything goes.
Good Luck
Fathers' Christmas... Well, it is a form of it...
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Father Christmas' is a possessive form of the noun. So isn't it considered plural if you just add an s at the end in this case or can you.
Looks like you have to use an apostrophe s and it solves all the problems. Father Christmas's address.
Correct usage is as follows:
There is no Father Christmas.
http://julianh72.blogspot.com
"Father Christmas"
Father: vt
Christmas: n (proper)
or maybe
Father: adj
It's not really that clear to start with, so trying to extend it into some plural form isn't going to be easy.
- Steve
