Large vertical pump installation
To install a large vertical 12,000 kg pump / motor on a concrete pedestal, what is a typical installation procedure from installing the rebar, casting the plinth, cure time levelling, screeding etc?
What are the key factors in a successful and vibration free installation?
The pump has a 700mm inlet and outlet, the inlet being vertical has a 90 degree duckfoot bend which is to be located beneath the two individual concrete plinths to keep the pump height as low as possible.
Pump info in this case: speed is 690 RPM and delivers 1571 litres / second at 19.4m head with a motor size of 500 kW.
Best Regards
John
Best Regards
John
RE: Large vertical pump installation
I gave you this guide to pump installation in the other pump base question you posted:-
http://www.sureseal.co.za/pumps/Pump_Installation_...
desertfox
Forsthoffer's_Best_Practice_Handbook_for_Rotating_Machinery
http://www.sciencedirect.com/science/article/pii/B...
Thanks for the replies I will check them out also.
John
As for the pump installation, from the drawing provided in your earlier thread, the pump is a large pump. You should follow the manufacturer's recommendation to avoid any argument in case of a warranty issue crops up later.
The basic things to look out for are leveling, pipe strain and coupling alignment.
