lube oil tank temp is very high for gas turbine unit GE-10 type
hello all,
my problem is that the temprature of lube oil tank rise from time to another without any new condition of unit operation like bearings drains temp. or turbine load or exhaust temp.
the action that taken is shutdown the unit for one hour and started again then the temp. back to its normal condition and it will take afew days to go back to the high value.
any one can help i will be glad, thanks
RE: lube oil tank temp is very high for gas turbine unit GE-10 type
There is probably some type of cooler for the lube oil. I would look at that first. It may be undersized for the conditions.
Speco (www.stoneprocess.com)
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
When you see indications the temperature is rising I'd start checking to see if any lube oil is coming back hotter, how the lube oil cooler is working, the temperature control valve for the lube oil cooler, etc.
If it's just a steady increase in temperature until you reach the high temperature limit it's either the cooler is undersized as said or the bypass valve isn't sending enough oil to the cooler.
rmw
Items i would check:
Most lube oil tanks have lube oil heaters, if these are left on inadvertently they may contribute to the temperature rise
Cooling system: ensure that: 1. there is no bypass, 2. the valves are fully open, 3. the coolers are full of water (the vents do not vent air).
Assuming there is a closed loop cooling water system: also check the coolers of the water for the same three items mentioned above
In case there is a three way valve that regulates the water to the lube oil coolers: check that it works properly, if it is stuck in the position bypassing water to the lube oil coolers, the coolers will be starved from water.
saludos.
a.
