Face Rule with SelectionManager.SelectObjects()
It is possible to allow the user to change the Face Rule during a SelectionManager.SelectObjects()?
During a pick faces operation of a built-in function the face rule drop-down is on the selection toolbar. While picking faces using SelectionManager.SelectObjects() and a MaskTriple the drop-down is not there. We have a function to pick faces and apply color templates and users are complaining they can only select one face at a time.
I found CreateRuleFaceTangent in the documentation but the user doesn't always want tangent faces. I would like it to behave like built-in NX functions where the user can choose the rule.
Here is the code I have for reference
CODE --> VB.NET
theUI.LockAccess()
        Dim mask(0) As Selection.MaskTriple
        mask(0) = New Selection.MaskTriple
        Dim sel1 As Selection.Response
        If type = "feature" Then
            With mask(0)
                .Type = UFConstants.UF_feature_type
                .Subtype = UFConstants.UF_feature_subtype
                .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
            End With
        Else
            With mask(0)
                .Type = UFConstants.UF_face_type
                .Subtype = 0
                .SolidBodySubtype = 0
            End With
        End If
        Do
            sel1 = theUI.SelectionManager.SelectObjects("Select " & type & "(s)", _
                "Select " & type & "(s)", Selection.SelectionScope.WorkPart, Selection.SelectionAction.ClearAndEnableSpecific, _
                False, True, mask, selected_objs)
        Loop While sel1 = Selection.Response.ObjectSelected Or _
                   sel1 = Selection.Response.ObjectSelectedByName
        theUI.UnlockAccess()
