LC 2415 - Need Help Alarm 2589 AUTO AGING
Hello
We are getting alarm 2589 AUTO AGING does anyone encountered this issue ???
We did a warm up on the laser oscillator but no luck, the high voltage led keeps blinking
RE: LC 2415 - Need Help Alarm 2589 AUTO AGING
Is this a Fanuc resonator? If so, aging is normal when the resonator has been shut down for more than 36 hours. It will automatically go through up to 7 aging cycles (each cycle should take about 5-10 minutes depending on some parameters).
THANKS A LOT FOOTSTRAP
We let it run trough the 7 cycles our parameters where at 22 minutes and worked ok
Thanks for your help!!!!
