Ati FirePro V5800 vs V4800
I have the Ati Fire Pro V4800 on my home PC and an Nvidia FX580 in the office. Both perform ok, but often I find that a better GPU wouldn't hurt. Since I mostly do drawing and simpler things in the office, I'd leave the office GPU as it is, but am thinking of investing into the Ati FirePro V5800 for my home PC as I often do quite complex and demanding stuff. My personal budget, as always, is quite limited, so, I'd just ask is the V5800 worth the extra buck$?
http://www.storyofstuff.org/
RE: Ati FirePro V5800 vs V4800
I found and read a few of these hardware comparison tests and the test results vary. However, none of them are done with SW and that is the only 3D app I'm using and the only reason to use a workstation class GPU. The manufacturer site states the main difference is in the double number of stream processors at the same amount of RAM. What good does that to the performance I am expecting, I can't tell, that's why I thought to ask here, in the SW forum. I'll wait a bit for some more info before I waste my money.
What are you expecting the better gpu to do for you?
SolidWorks gains the most performance boost from a fast, modern cpu.
Unless you are doing very complex models you will not gain much of anything from a better video card.
First priority is to be sure you have the best cpu you can afford.
Cheers,
Anna Wood
SW2012 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
I have the I-7 2600K @5GHz, 16G DDR3, 128G SSD system drive, and you hit the spot Anna, I usually end up with assemblies with multiple sub-assemblies adding up to about 500-700 parts and the parts are all complex individually. I usually suppress all the features I don't really need during the assembly process but once I need to check everything for clearances and do technical drawings, it becomes cumbersome. When I started working with SW a budget low end laptop was enough because I never got further in design from a basic 2D sketch extruded and converted to a single sheet metal part. I have no problems with rendering for presentation (SW2012 SP5.0) which relies on CPU.
