Flammability of Gas Mixtures
Hi!
I recently posted this query in elsewhere;
How can I calculate the flammability of a gas mixture from the analysis of the gas mixture, plus the individual flammability limits?
Also, how do I modify the flammability of the gas mixture by introducing some inert gas?(Nitrogen)
RE: Flammability of Gas Mixtures
I have also this same problem and I now know how to calculate gas mixture which contains nitrogen. But the problem is how to calculate flammability limits of gas mixture which contains water vapour?
The flammability at the LEL is actually a function of the absorbed heat by the inert components.  Normally, flammability limits are given in air (Nitrogen diluent).  Because of the relative specific heats Water vapor has about 1.35 x the effect of nitrogen and CO2 has about 1.8 x the effect of Nitrogen so the limits are different for other inerts.  I have a calc posted at http://www.geocities.com/flareman_xs/Gases/Flammability_calc.html which may help you.
David
To Flareman, now, three months later, I still can not read the graphs on yor site, I get just empty squares. What should I do to be able to read and use them ? Thanks.
25362
I'm not sure what your specific problem is but there are a couple of possibles.
1 - you may not be using IE 5 or above
2 - you may not have Excel on your computer (97 or above)
3 - Excel may be set for manual recalc (if so press F9 to get a calculation)
If none of these work, let me know.
To Flareman, problem solved. I raised the site through Words 2000. Thanks.
