operating philosophy of fire pump
Please, I need your comment about the operating philosophy of a group of fire pump:
Setting the pressostat:
The pressostat connected to the jockey pump (1) should be set to:
- A starting pressure of 9.5 bara
- A shut-off pressure of 11 bara
The pressostat connected to the pump jockey (2) must be set to:
- A starting pressure of 9.0 bars
- A shut-off pressure 11 bar.
The pressostat connected to the principal electrical pump set at:
- A starting pressure of 8.5 bars
- Manual Stop
The pressostat connected to the diesel pump set to:
- A starting pressure of 8.00 bars
- Manual Stop
Are there any requirements in the NFPA code?
Thanks in advance and have a nice day
R.B (Mechanical Engineer)
(Note: sorry for my english)
RE: operating philosophy of fire pump
From NFPA 20, 2013 ed
A.14.2.6
Examples of fire pump settings follow (for SI units, 1 psi = 0.0689 bar):
i. Pump: 1000 gpm, 100 psi pump with churn pressure of 115 psi
ii. Suction supply: 50 psi from city — minimum static; 60 psi from city — maximum static
iii. Jockey pump stop = 115 psi + 50 psi = 165 psi
iv. Jockey pump start = 165 psi − 10 psi = 155 psi
v. Firepumpstop=115psi+50psi=165psi
vi. Firepumpstart=155psi−5psi=150psi
vii. Fire pump maximum churn = 115 psi + 60 psi = 175 psi
Where minimum-run timers are provided, the pumps will continue to operate at churn pressure beyond the stop setting. The final pressures should not exceed the pressure rating of the system components.
Fire Sprinklers Save Firefighters’ Lives Too!
Good morning LCREP,
Thank you sir for your good collaboration,
for information, my case is a network of firefighting of a Cannery boxes of sardines
plant,
thank you in advance and good luck to all intevenant,
