DFA's not listed in DFA manager
I have added dfa path to the dfa-manager directories, but not able to see the list of dfa-classes.Unable to use "Load on Succesful Check".
This forces me to reopen NX every time to make the dfa changes effective..
Please suggest a way to fix this..
thanks
basenxuser
NX 7.5
RE: DFA's not listed in DFA manager
Hi Basenxuser,
Are the dfa file name and the DEFCLASS (in the dfa file) name same? I know it is not a mandate but is always better to have the two names same.Also if in between the sessions you make any changes in the dfa then try using Reload All (KF navigator)
Best Regards
Kapil
