EDIT DIM VALUES
EDIT DIM VALUES
EDIT DIM VALUES
I need to edit the dim value on some dimensions. (don't ask why) I have to do it for certification drawings which require max/min values attached to the parts.
How can I do this without sketching lines and arrows?
RE: EDIT DIM VALUES
EDIT THE DIMENSION TEXT
IT WILL BE {0:@D} BY DEFAULT.
CHANGE THIS TO {0:@O} THEN JUST TYPE WHATEVER YOU WANT AFTERWARDS
