Submersible Pump Corrosion
I am looking for an equipment coating vendor or product for an industrial wastewater stream with elevated temperature flow (105-115 F) and extremes in pH (5.5 – 11.) The waste stream is eating off the submersible pump’s manufacturer coating system (primer plus Tnemec epoxy.) I have contacted Contech, Carboline (Pittsburg Paint) and Madison Chemicals with no luck for a potential solution. Please let me know if there is someone you’ve used for coating materials that might have a product.
Pictures:
Link
Link
Link
Pictures:
Link
Link
Link
RE: Submersible Pump Corrosion
Either they didn't have good enough surface prep or the filler in the coating is being attacked.
I have used various products over the years, this is one that comes to mind:
http://www.duromar.com/exp
When you are coating surface prep is everything, getting the correct profile and cleanliness along with temp and humidity are critical if you expect a coating to last.
Plymouth Tube
