Measuring the radius on a section of cable routing
Does anyone happen to know how to measure the bend radius on a section of routing? I'm currently using the mechanical routing module to route some cables. Since I can't seem to control the minimum bend radius, I have to use the Analysis->Minimum Radius tool and change the control points iteratively in order to meet my minimum requirements.
Is there a way to measure the bend radius on a section of that overall routing to see if I meet the preferred radius vs. the minimum at those routing spans?
Thanks for any help. I'm using NX6, by the way.
RE: Measuring the radius on a section of cable routing
But, I'm not 100% sure it is in NX6...
www.nxjournaling.com
