Tabular Note Point Chart - Journal
4
I am using NX 7.5. What I am trying to do is create a Journal that allows me to select points (less than 50 points on avg) and places the X,Y,Z coordinates into a tabular note on the drafting side. Is this achievable? I've searched several threads here, Google, etc and have come up short (Best I found was: http://www.eng-tips.com/viewthread.cfm?qid=314774 ).
If it is possible, other features I would like to know if NX is capable of and resources to help me develop are;
-Looking to have the points listed in order by order of selection and labeled like NX currently does when points are selected and Information -> Object is used
-If cannot be listed in that manner, all points on a certain layer would work as well.
-Control the decimal places to two or three
Closest example I can think of, is similar to CATIA V5 and the point charts created there.
Any help would be greatly appreciated
Kyle
RE: Tabular Note Point Chart - Journal
Sorry about being very novice here, but how are GRIP files launched in NX 7.5?
File -> Execute -> Grip... or the shortcut equivalent ctrl + G, browse to your grip file and press OK.
www.nxjournaling.com
Thanks cowski.
Looking deeper, I found this GRX that is -almost- exactly what I want, except I would like to shrink down/modify a few of the attributes such as posting the values into a tabular note rather than drawing lines. Any known source GRS like this? And is something like this possible using a journal (VB)?
Bump.
Attached is both a program (signed) and the source code to run as a journal. It does use a Tab Note. It is limiting in that I have not used a dialog to let a user set up a number of defaults. Hope this gives you a good basis for developing your requirements. Let me know if you need anything additional.
Frank Swinkels
Frank
I used your journal and it it's fabulous, I have a couple of questions about it.
1. Where in the VB code can I alter the number of decimal places from 3 to 1?
2. Could it be made accociative so that if a point moves, then the table will update?
3. How easy/hard would it be to add another column that measures Distance Between Bends?
4. How easy/hard would it be to include end to end length.
Many thanks
Si
Best regards
Simon NX7.5.4.4 MP8 - TC 8 www.jcb.com
Simon,
Re 1. The decimal places are set in three line of the journal. One of these reads
ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.X, 3).ToString())
Just change the 3 to 1 ie
ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.X, 1).ToString())
Re 2. No it cannot be made associative. It can be made so that by running another journal an existing table is updated. What I would do is when a table is created I add the point id as a name to the point object. Then when running an update journal the point info is available to update the table.
Re 3. No difficulty with adding any columns. It is more a problem of selection procedure. At the moment we simply select points and enter the data into the table. It probably will become necessary to use a dialog to allow different selection procedures.
Re 4. Similar to 3.
Frank Swinkels
Frank
Would you be able to make the attached table in to your journal to the points are imput using your way, with the other boxes just requiring manual entry? (unless you can get it to measure end to end length and developed length and number of bends???) Obviously the rows for the point coordinates would need to be created bu picking thte points on the screen we use a max of 10 points.
If it's to much hassle, not to worry.
Cheers
Si
Best regards
Simon,
Do you have a 3D model of the pipe? Specifically, I'm thinking of a "tube" feature. If so, it may be easier to allow selection of the tube and pick up points, bends, and lengths from that.
Hi Jeff
Yes, we do have 3D models of the pipes which we create in the following way.
1: Using the WCS, position points in space in the context of an assemply.
2: Join the points with associative lines
3: Use associative arc (tangent, tangent, radius)
4: Use the tube command with selectin intent set to follow fillet.
5: Orient the WCS so that origin is on the end of the pip (longest straight) with +Y oriented along first straight and +X oriented along the direction of the second straight after the first bend.
6: Create new component making sure ABS position for the pipe is taking from the WCS location in the assembly.
&: Finished.
If we need to tweak the pipe, then we just move points and the associative curves mean that the pipe will update.
If we could get a nice journal to do all the points for us and those other bits of info in my table, then this will be a huge step forward as currently it is open to lots of typo errors.
There is a video below
Cheers
Si.
http://screencast.com/t/rdFlyuncf1g
Best regards
Frank,
That original VB file is great. Thank you. It is definitely helping me get a base developed. One question. I noticed that it starts out onto one view. Is there a way to have the journal focus on the whole sheet? Or even all sheets? I have traditionally points on several different views as well as different sheets.
Would I need to modify the area of:
"Dim dwgview As Drawings.BaseView = Nothing
If select_a_drawing_member_view(dwgview) <> Selection.Response.Ok Then"
Thanks again!
Kyle
Simon,
Adding the extra table cells would not be a problem. I need to check out how to merge cells.
Kyle,
I think I need view info for inserting labels correctly. What we need here is to have a dialog so that views can be changed.
Frank
Frank
That's fantastic, thank you very much.
Cheers
Si
Best regards
Simon,
Attached is a proof of concept journal that allows you to select a tube feature and reports section lengths and end points to the information window. Perhaps portions of this would be useful to merge with Frank's code. In its current form it only works correctly with tubes made of lines and arcs (ie splines & conics not yet supported).
Tube information journal
Frank,
Working on getting a dialog for the changing of the views, however I noticed that the current view selection (in the original journal) does not allow you to select a 'projected' view. Is there a different type of code that allows you to select any view including one's projected from another?
Kyle
I have added the ortho projected views when selecting a view. This has also affected the code in a number of locations. Instead of using drawing.baseview I now use view with the selection mask including imported and orthographic view subtypes.
Here is the full program.
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Annotations
Imports NXOpen.UI
Imports NXOpen.UF
Imports NXOpen.Utilities
Module create_tabnote_with_all_3d_points_coordinates
    Dim s As Session = Session.GetSession()
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim ui As UI = UI.GetUI()
    Dim lw As ListingWindow = s.ListingWindow
    Dim workPart As Part = s.Parts.Work
    Sub Main()
        Dim startcell0 As String = "MATERIAL"
        Dim startcell1 As String = "C/L BEND RAD"
        Dim startcell2 As String = "END: A"
        Dim startcell3 As String = "END: B"
        Dim startcell4 As String = "PIPE TO CONFORM TO JCB STD 1000/002"
        Dim endcell0 As String = "NUMBER OF BENDS"
        Dim endcell1 As String = "DEVELOPED LENGTH"
        Dim endcell2 As String = "THIS COMPONENT MUST CONFORM TO: JCB STANDARD 9993/003 HYDRAULIC CLEANLINESS"
        Dim endcell3 As String = "ZINC PLATE TO: JCB STANDARD 9994/0800 - CORROSION PROTECTION TO: JCB STANDARD 1007/007 CATEGORY 'E'"
        Dim xvalue As Double = Nothing
        Dim response1 As Selection.Response = Selection.Response.Cancel
        ' Get a view for the IDs
        Dim dwgview As View = Nothing
            Return
        End If
        ' Get a location for the tabular note
        Dim cursor As Point3d
        Dim response As Selection.DialogResponse = SelectScreenPos(cursor, dwgview)
        If response <> Selection.DialogResponse.Pick Then
            Return
        End If
        ' Create the tabular note
        Dim n_new_columns As Integer = 4
        Dim tabnote As NXOpen.Tag = CreateTabnoteWithSize(0, n_new_columns, cursor)
        ' Get the column tags
        Dim columns(n_new_columns - 1) As NXOpen.Tag
        For ii As Integer = 0 To n_new_columns - 1
            ufs.Tabnot.AskNthColumn(tabnote, ii, columns(ii))
        Next
        Dim pt1 As Point = Nothing
        Dim row As NXOpen.Tag
        Dim cell As NXOpen.Tag
        Dim cells(3) As NXOpen.Tag
        ' add start row1
        ' MATERIAL
        ufs.Tabnot.CreateRow(40, row)
        ufs.Tabnot.AddRow(tabnote, row, UFConstants.UF_TABNOT_APPEND)
        For i As Integer = 0 To 3
            ufs.Tabnot.AskCellAtRowCol(row, columns(i), cells(i))
        Next
        ufs.Tabnot.MergeCells(cells(0), cells(1))
        ufs.Tabnot.MergeCells(cells(2), cells(3))
        ufs.Tabnot.SetCellText(cells(0), startcell0)
        ' C/L BEND RAD
        Next
        ufs.Tabnot.SetCellText(cells(0), startcell1)
        ' END: A
        Next
        ufs.Tabnot.SetCellText(cells(0), startcell2)
        ' END: B
        Next
        ufs.Tabnot.SetCellText(cells(0), startcell3)
        ' PIPE TO CONFORM TO JCB STD 1000/002
        Next
        ufs.Tabnot.MergeCells(cells(0), cells(3))
        ufs.Tabnot.SetCellText(cells(0), startcell4)
        ' Add points Header Row
        Dim headerrow As NXOpen.Tag
        ufs.Tabnot.CreateRow(40, headerrow)
        ufs.Tabnot.AddRow(tabnote, headerrow, UFConstants.UF_TABNOT_APPEND)
        ufs.Tabnot.AskCellAtRowCol(headerrow, columns(0), cell)
        '   ufs.Tabnot.SetCellText(cell, "ID")
        ufs.Tabnot.AskCellAtRowCol(headerrow, columns(1), cell)
        ufs.Tabnot.SetCellText(cell, "X")
        ufs.Tabnot.AskCellAtRowCol(headerrow, columns(2), cell)
        ufs.Tabnot.SetCellText(cell, "Y")
        ufs.Tabnot.AskCellAtRowCol(headerrow, columns(3), cell)
        ufs.Tabnot.SetCellText(cell, "Z")
        Dim letteringPrefs As LetteringPreferences = Nothing
        Dim userSymPrefs As UserSymbolPreferences = Nothing
        Dim markId1 As Session.UndoMarkId
        markId1 = s.SetUndoMark(Session.MarkVisibility.Visible, "Start")
        Dim jj As Integer = 0
        Dim id As Integer = 1
start1:
        ' Add one row for each point
        response1 = select_a_point(pt1)
        If response1 <> Selection.Response.Ok Then GoTo end1
        '  For Each pt As Point In pcol1
        id = jj + 1
        ' Get the Coordinates
        Dim pt3d As Point3d = pt1.Coordinates
        ' Add a row for each point
        ufs.Tabnot.AskCellAtRowCol(row, columns(0), cell)
        ufs.Tabnot.SetCellText(cell, id.ToString())
        ' Set the cell text
        ufs.Tabnot.AskCellAtRowCol(row, columns(1), cell)
        ufs.Tabnot.AskCellAtRowCol(row, columns(2), cell)
        ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.Y, 1).ToString())
        ufs.Tabnot.AskCellAtRowCol(row, columns(3), cell)
        ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.Z, 1).ToString())
        ' Add ID notes to the points
        AddNoteToPoint(id, pt1, pt3d, dwgview)
        jj = jj + 1
        Dim markId2 As Session.UndoMarkId
        markId2 = s.SetUndoMark(Session.MarkVisibility.Invisible, "Note")
        GoTo start1
end1:
        ' add the ending rows
        ' NUMBER OF BENDS
        Next
        ufs.Tabnot.SetCellText(cells(0), endcell0)
        ' DEVELOPED LENGTH
        Next
        ufs.Tabnot.SetCellText(cells(0), endcell1)
        ' THIS COMPONENT MUST CONFORM TO: JCB STANDARD 9993/003 HYDRAULIC CLEANLINESS
        Next
        ufs.Tabnot.SetCellText(cells(0), endcell2)
        ' ZINC PLATE TO: JCB STANDARD 9994/0800 - CORROSION PROTECTION TO: JCB STANDARD 1007/007 CATEGORY 'E'
        Next
        ufs.Tabnot.SetCellText(cells(0), endcell3)
    End Sub
    Public Function SelectScreenPos(ByRef pos As Point3d, ByVal view As View) As Selection.DialogResponse
        Return ui.SelectionManager.SelectScreenPosition("Select location for tabnote", view, pos)
    End Function
    Function select_a_drawing_member_view(ByRef dwgview As View) As Selection.Response
        Dim mask(1) As Selection.MaskTriple
        mask(0).Type = UFConstants.UF_view_type
        mask(0).Subtype = UFConstants.UF_view_imported_subtype
        mask(0).SolidBodySubtype = 0
        mask(1).Type = UFConstants.UF_view_type
        mask(1).Subtype = UFConstants.UF_view_orthographic_subtype
        mask(1).SolidBodySubtype = 0
        Dim cursor As Point3d = Nothing
        Dim vw As View = Nothing
        Dim resp As Selection.Response = _
        ui.SelectionManager.SelectObject("Select Points Drawing View", _
            Selection.SelectionScope.AnyInAssembly, _
            Selection.SelectionAction.ClearAndEnableSpecific, _
            False, False, mask, vw, cursor)
        If resp = Selection.Response.ObjectSelected Or _
           resp = Selection.Response.ObjectSelectedByName Then
            dwgview = CType(vw, View)
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function CreateTabnoteWithSize( _
        ByVal nRows As Integer, ByVal nColumns As Integer, ByVal loc As Point3d) As NXOpen.Tag
        Dim secPrefs As UFTabnot.SectionPrefs
        ufs.Tabnot.AskDefaultSectionPrefs(secPrefs)
        Dim cellPrefs As UFTabnot.CellPrefs
        ufs.Tabnot.AskDefaultCellPrefs(cellPrefs)
        cellPrefs.zero_display = UFTabnot.ZeroDisplay.ZeroDisplayZero
        ufs.Tabnot.SetDefaultCellPrefs(cellPrefs)
        Dim origin(2) As Double
        origin(0) = loc.X
        origin(1) = loc.Y
        origin(2) = loc.Z
        ufs.Tabnot.Create(secPrefs, origin, tabnote)
        ' Delete all existing columns and rows (we create them as needed)
        Dim nmRows As Integer = 0
        ufs.Tabnot.AskNmRows(tabnote, nmRows)
        For ii As Integer = 0 To nmRows - 1
            ufs.Tabnot.AskNthRow(tabnote, 0, row)
            ufs.Tabnot.RemoveRow(row)
            ufs.Obj.DeleteObject(row)
        Next
        Dim nmColumns As Integer = 0
        ufs.Tabnot.AskNmColumns(tabnote, nmColumns)
        For ii As Integer = 0 To nmColumns - 1
            Dim column As NXOpen.Tag
            ufs.Tabnot.AskNthColumn(tabnote, 0, column)
            ufs.Tabnot.RemoveColumn(column)
            ufs.Obj.DeleteObject(column)
        Next
        ' Now add our columns as needed
        Dim columns(nColumns - 1) As NXOpen.Tag
        For ii As Integer = 0 To nColumns - 1
            ufs.Tabnot.CreateColumn(40, columns(ii))
            ufs.Tabnot.AddColumn(tabnote, columns(ii), UFConstants.UF_TABNOT_APPEND)
        Next
        ' Now add our rows as needed
        Dim rows(nRows - 1) As NXOpen.Tag
        For ii As Integer = 0 To nRows - 1
            ufs.Tabnot.CreateRow(10, rows(ii))
            ufs.Tabnot.AddRow(tabnote, rows(ii), UFConstants.UF_TABNOT_APPEND)
        Next
        Return tabnote
    End Function
    Public Sub AddNoteToPoint(ByVal id As Integer, ByVal pnt1 As Point, _
                              ByVal pt As Point3d, ByVal dwgview As View)
        Dim screenpos As Point3d
        SelectScreenPoint(screenpos)
        Dim nullAnnotations_SimpleDraftingAid As Annotations.SimpleDraftingAid = Nothing
        Dim draftingNoteBuilder1 As Annotations.DraftingNoteBuilder
        draftingNoteBuilder1 = workPart.Annotations.CreateDraftingNoteBuilder(nullAnnotations_SimpleDraftingAid)
        draftingNoteBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
        draftingNoteBuilder1.Origin.SetInferRelativeToGeometry(True)
        draftingNoteBuilder1.Origin.Anchor = Annotations.OriginBuilder.AlignmentPosition.MidCenter
        Dim text1(0) As String
        text1(0) = id.ToString
        draftingNoteBuilder1.Text.TextBlock.SetText(text1)
        Dim leaderData1 As Annotations.LeaderData
        leaderData1 = workPart.Annotations.CreateLeaderData()
        leaderData1.StubSize = 5.0
        leaderData1.Arrowhead = Annotations.LeaderData.ArrowheadType.OpenArrow
        draftingNoteBuilder1.Leader.Leaders.Append(leaderData1)
        leaderData1.StubSide = Annotations.LeaderSide.Inferred
        leaderData1.Leader.SetValue(pnt1, dwgview, pt)
        Dim assocOrigin1 As Annotations.Annotation.AssociativeOriginData
        assocOrigin1.OriginType = Annotations.AssociativeOriginType.RelativeToGeometry
        Dim nullView As View = Nothing
        draftingNoteBuilder1.Origin.Origin.SetValue(Nothing, nullView, screenpos)
        Dim nXObject1 As NXObject
        nXObject1 = draftingNoteBuilder1.Commit()
        draftingNoteBuilder1.Destroy()
    End Sub
    Public Function select_a_point(ByRef pt1 As Point) As Selection.Response
        Dim mask(0) As Selection.MaskTriple
        With mask(0)
            .Type = UFConstants.UF_point_type
            .Subtype = 0
        End With
        ufs.Ui.SetCursorView(0)
        ufs.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
   ui.SelectionManager.SelectObject("Select a point", "Select a point", _
       False, False, mask, pt1, cursor)
        ufs.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
        ElseIf resp = Selection.Response.Back Then
            Return Selection.Response.Back
        Else
        End If
    End Function
    Function SelectScreenPoint(ByRef screenpos As Point3d)
        Dim displayPart As Part = s.Parts.Display
        Dim baseView1 As View = s.Parts.Work.Views.WorkView
        Dim point As Double() = {0.0, 0.0, 0.0}
        Dim response As Integer = 0
        Dim viewTag As Tag = Nothing
        Dim viewType As UFView.Type = Nothing
        Dim aView As View = Nothing
        Dim viewSubtype As UFView.Subtype = Nothing
        ufs.Ui.SetCursorView(1)
        Try
            ufs.Ui.SpecifyScreenPosition("Select Label Pos", Nothing, IntPtr.Zero, point, _
                                                   viewTag, response)
        Finally
        End Try
        If (response <> NXOpen.UF.UFConstants.UF_UI_PICK_RESPONSE) Then Return Selection.Response.Cancel
        screenpos.X = point(0)
        screenpos.Y = point(1)
        screenpos.Z = point(2)
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
Frank Swinkels
