Question about default fonts in drawing
Good morning
I am still learning NX system .... and Learning
How to set default fonts and its size for drawing mode (i want to have the same fonts and size everywhere: in tables, notes, dimensions) ?
I have imported drawing form DWG and there are complications because when I want to insert note then NX try put very small size text and every time I Need charge it. How to set default value of size and font.
With Best Regards
Mat
RE: Question about default fonts in drawing
You will need to take a look at your Customer Defaults and possibly in the Drafting Standard that you are using. These settings will only affect NEW files (very important to remember). It will NOT affect existing (legacy) files. If you are opening or importing an NX part into a new file, the font settings will not reflect the default settings you have set.
There are quite a few defaults that behave in this manner - and the list is quite long.
Tim Flater
NX Designer
NX 7.5.4.4 MP8
WinXP Pro x64 SP2
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Hi Tim
Thank you for your replay. I was searching there and now everything is ok :)
Best Regards
Pol
