Nodal stress history output
Hello all,
I am trying to obtain the stress history output of a node in my model. To do this I went into the Step module -> Tools menu -> Set -> Create -> Node, and selected the desired node.
I then went to the Output menu -> History Output Requests -> Create -> Set, and select the set I just created. I then selected the stresses as the output.
However, after I run the analysis and go into the Results menu -> History Output, the stress data is nowhere to be found in the output list.
Am I missing a step here?
Thanks for any help,
pfsm01
pfsm01
RE: Nodal stress history output
Open your INP, scroll down to the OUTPUT REQUESTS, and put the following in your INP:
CODE --> ABAQUS_INPUT_FORMAT
Note that myNodeSet is the name that you provide to the node set of your interest.
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
