Stopple Tee
Stopple Tee
Stopple Tee
Has anyone encountered a problem where the Stopple became stuck in the pipe and was not able to be removed? If so what options were used to remove the Stopple?
RE: Stopple Tee
Did you ask the manufacturer for advice (I assume you are using a name-brand Stopple hot-tapping setup, e.g like in the link below?)
Link and Link
