Where is the Animation option in Modeling?
Sorry for the really basic question here. Refering to John's last post here: http://www.eng-tips.com/viewthread.cfm?qid=313982
NX 7.5. I am looking for a way to animate the deformation of an elastomer mount between two solid objects. I have the elastomer as a deformable part in my assembly and when I move one of the objects it is connected to it updates properly but I want to animate this motion. Is there a way to do this outside of Motion Simulation? Where is the Animation option he is talking about?
RE: Where is the Animation option in Modeling?
View -> Visualization -> Create Animation...
To find more information about how to set up and run an 'animation' go to the NX Help files and search on 'Create an Animation'. Now you'll have to sort through at lot of irrelevant stuff since most of the 'hits' will be referencing 'animation' option from the CAE simulation products (starting with NX 8.0 you'll be able to search the NX Help files and explicitly skip areas like CAE or CAM which will make it much easier to get 'hits' on only relevant topics).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Animation allows you to create a so-called 'stepping' or 'FrameNumber' expression and then run through a number of iterations while either viewing the resulting animation or capturing frames of a video.
As a simple demo of how you can 'animate' the size of a block, see the attached example. Open the file and go to...
...and press the 'Preview Animation' button and then select the 'VCR-like 'Play' button.
Now look at the Expressions to see how I controlled the Height of the block and going back to the above Animation dialog, select the Edit 'Key Frame' button to see how I defined the number of steps in the animation sequence (it's best to set the number of steps to be equal to value of the 'FrameNumber' expression +1). BTW, the expression name 'FrameNumber' is a unique and reserved name which is used ONLY for creating Animations. This is the only expression which you can increment and therefore any and all 'variables' must be driven by this one expression.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
