Restraint stiffness
Restraint stiffness
Restraint stiffness
Hi All,
I was just wondering what people think is the best way to introduce a restraint stiffness value into an ANSYS structural model.
Say we have a structure that is modelled as being fixed in the X and Z directions translationally at certain locations. However on closer investigation we need to introduce some flexibility of the X translational restraint. What is the best method of doing this?
RE: Restraint stiffness
Try attaching spring elements at the constrained points, with an appropriate spring stiffness matching that which represents this flexibility you require.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Normally, the horizontal springs that provide a restraint have the half stiffness of the vertical ones. As a rule of thumb!
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
