How to separate the Turbine Work
I have a high Rankine Cycle output electricity, which is 50 MW. How can I get just 1 MW from this Cycle and use the rest for another application.
If I use step down AC voltage device, that is mean the whole 50 MW will step down. But I just need the 1 MW and keep the 49 MW for another application.
Any help will be appreciated in advance
RE: How to separate the Turbine Work
What is the 'alternative load' you mention? The turbine needs some form of mechanical load - e.g. an alternator, compressor, or similar. You have the option to recover exhaust heat to raise steam or desalinate water.
