Small Air Valve
Small Air Valve
Im looking for a air valve that will sound an air horn. The area I have to work with is very small 14x30mm. What type of small valves will work in this size constraint?
RE: Small Air Valve
Check for instance Norgren, SMC, and number of others.
RE: Small Air Valve
Again the entire size the complete valve can be is appx 14x30mm in a cylinder chamber.
Thanks for the ideas!
RE: Small Air Valve
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
RE: Small Air Valve
As per solenoid I'm not sure, if I use a manual valve do I need one? I was thinking of a thumb lever on the end outside the bar that would link to the valve inside the bar and release air.
