Dimension vs. Heat Treat
I have a question in regards to Heat Treatment of metals vs. Dimensional characteristics.
Ex. Carbon Steel ASTM A-1011 TY B
.125 +/-.005 THK x 2" +/-.005 Outside Dia.
Under standard heat treatment practices for hardeneing of metals. Will the dimensional characteristics of the parent material alter enough to be a cause of concern for the finished part after it has normalized from heat treatment?
RE: Dimension vs. Heat Treat
rp
At least not by thermal processing alone, i.e. you would need a carburizing or carbo-nitriding step.
