UV stabilizing of Polysulfone / polyethersulfone
Hi all,
can anyone suggest a way to UV stabilize polysulfone or polyethersulfone (Solvay´s Udel or Veradel) that will allow outdoor use?
I have found some evidence that benzotriazole UV absorber in 1% concentration can do something but I am not sure that it will be enough. Anyone with experience in this area?
Painting or coating the final product is not an option here. A sort of mechanical block rather than absorber could be a possibility. (TiO2 ?)
Alternatively, is there another amorphous thermoplastic which can be solvent cast into a film, with better UV and similar mechanical properties? Preferably transparent, translucent or white and without the aerospace price tag....
your help will be highly appreciated.
many thanks,
Claus
many thanks,
Claus
RE: UV stabilizing of Polysulfone / polyethersulfone
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
http://books.google.com/books?id=WbBH5QFXOhoC&...
They show results for 0.5% and 1% Tinuvin 234
TiO2 can help with UV blocking, but will also alter other properties to some extent.
There are quite a few materials that might be a suitable substitute, depending on what properties you might want to retain as mechanical properties is a very broad term.
Polycarbonate and polyester copolymers or so called high heat Lexan or even aromatic nylons spring to mind as maybe possible. Polyesters are very hard to cast from solvent but I have seen it done, although I must admit it was poorly done with straight PET and I think 90% Meta Cresol? It was probably 30 years ago or more, so memories fade.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
your help with this is most appreciated.
Chris, thanks for suggesting the UV stabilized grade from RTP. I will see what they have to say and I will also look further into Tinuvin 234. It does look like a fairly modest improvement though and perhaps I just have to look for alternatives.
Pat, This is not a high temp application although a high Tg (low tensile creep) and high tensile modulus are desired properties. Also, solvent casting a film should be fairly straight forward.
TiO2 might give that extra protection but the high polarity of PSU and low polarity of TiO2 might not work well together in a solution?
Low water absorbtion is also on my wish list so nylons are probably not a very good choice. PSU has a very good set of properties, except for the UV issue.
regards,
Claus
If it's not high temperature or impact, maybe acrylic (PMMA). Easy to solvent cast, very good creep, very hard, perfect UV and perfect transparency. It is brittle though.
Pat
for site rules
toughness is top of the list, I forgot to mention this... Sorry.
aramids have nice properties but would be too difficult to dissolve, I think. PC or perhaps polyester copolymers, as you say, could be possible alternatives, although a step down in some of the mechanical properties. I will look into this as well.
Thanks again for your help, both of you.
Pat
for site rules
