Abaqus frictional generated heat model
Hello
Found out that I posted this thread in a wrong forum group, hope this is the right place.
So, in Abaqus I managed to create two objects with contacting surfaces, pressed to each other while one is fixed and the other is moving with a constant velocity. The simulation seams fine for stress results, but at temperature it shows no change at all. I tried different BCs and predefined fields for temperatures and some other adjustments, but no goal. What could be wrong? Attached my cae file. Would appreciate some help.
RE: Abaqus frictional generated heat model
But here is your problem:
You are doing static stress displacement analysis, so you are getting the stresses and displacements.
If you want to get a temperature, use the coupled temperature displacement step.
Also, use the C3D8T elements to free up the thermal DOF.
Changing this, I got a very small temperature result using your values (2.5e-4). If this is not what you expect, check to make sure your units are consistent.
Only one thing is not really clear for me with the units and that might needed to be fixed. This problem is related with the model. Like if all units are in SI then are the part's sketch dimensions also in SI (m)? So if there is a r10 radius in the sketch it means that it is 10 m, so in that case I should resize it to r0.001 to have 10 mm radius? (guess that will make a huge change in results since the load would be very small in that first case, but had no time to try this out jet)
Further that the BCs velocity behaves strange. If I change V1 from 1 to 2 I expect twice the distance gaind by the moving part (while the step's time period remained the same), but insted what I expected the moving part moved to the same place, apparently with the same speed. The strangest behavior accured with much higher velocity. The moving part went to the same place with the same visible velocity, but the temperature change in the fixed plane ovetook the moving part far ahead which is absurd. So Is there a distance and velocity limit for the displayed part motions in the results, or what could be wrong?
Furthermore, you should constrain your cylinder in the Y direction, to avoid numerical singularities. The reason your simulation still runs is probably because of the frictional contact, still, you should properly constrain everything.
If you use SI units, indeed dimensions are in meters. so 10 is 10 meter.
Velocity has NO meaning in a static analysis!
This is perhaps one of the reddest flags. I strongly recommend not to focus on colors and animations AT ALL before you have looked at the numbers. This is no rule and there are exceptions but, if you are a beginner, then take this as a rule.
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
7. This forum reaches out to engineering professionals worldwide, many of whom are not native English speaking. When responding to non-native English posters, please refrain from disparaging their use of English; ask for clarification where necessary.
Feel free to correct me; I may simply have misunderstood what you wrote. Indeed, I'd like to know where I went wrong in my (mis?)interpretation.
Static analysis, as the term implies, is carried out for a point in time. So, one is not concerned with how, for example, the stresses evolve over a period of time. Time, in FEA, for static analyses is simply a numerical parameter that allows the numerical procedure to apply a portion of external load and try to establish equilibrium, if 'possible'. Therefore, speed/velocity (delta_s/delta_t) is, by definition, irrelevant in a static analysis because delta_t is not the "time" you expect. The time you expect shows up in quasi-static, dynamic or explicit analyses.
Next, colors in an FE analysis are simply mappings of results. In a static stress-displacement analysis, for example, color may stand for some stress (von Mises, I guess, is the default stress in Abaqus/Viewer) or contact pressure or a field variable etc. But color scales are simply for visualization of the underlying results. Say, the computed stress in a region varies from 1 MPa to 20 MPa. ABAQUS post-processor uses this information to create a scale of colors (typically, from blue to red in 10 units). [There is also averaging at nodes, and scaling to be kept in mind.] If one is not aware of the results at nodes, elements, interfaces etc. and the discontinuities, looking at colors, in all probability, is simply a disaster waiting to happen. What one must be aware of is, for example, reaction forces at nodes of interest, rather than a plot of von Mises stress. Why? That's where the theory of FEA and structural mechanics comes in to play.
As sdebock pointed out to you, using the appropriate analysis, elements, constraints etc. will let you carry out a thermomechanical analysis in the right way. However, my comments had to do with implicit issues.
For example, in the step definition, note that the type of analysis is Static, General. In the description, you wrote Apply velocity and "time period" is 10. In the load definition, you are applying a load of 0.2 units on top of a surface. Now, what you are really doing is applying 1 unit of pressure (10 x 0.1 = 1.0) on top of the surface at "time" = 10. [Here, as pointed out in my previous post, time has no meaning except as computational parameter.] If that is what you wanted to accomplish, great! If not, then I am sure you'd agree that you ended up correctly solving the wrong problem. Why wrong problem? Well, because you may really have wanted to apply 0.1 units of pressure on that surface at a particular speed in a given direction. In that case, the Implicit Dynamic analysis may be more appropriate.
If you expect a wide variation, in say temperature, in a given region and you do not see any variation in colors, then yes, you are correct. But, I guess, if there is little to no variation, then there should be little to no change in colors too. Besides, it also depends on how many colors (levels) are chosen. In ABAQUS/Viewer, you can go up to 20 levels, if I remember correctly. Note, however, that there are situations where even this may not necessarily be true but those situations arise in advanced features in FEA.
did you successfully finished your simulation? I'm also doing something similar and I just wondered if you could post your final .cae file. Would be very grateful for that. Thanks!
