Abaqus frictional motiion generated heat model
Hello
In Abaqus I managed to create two objects with contacting surfaces, pressed to each other while one is fixed and the other is moving with a constant velocity. The simulation seams fine for stress results, but at temperature it shows no change at all. I tried some BCs and predefined fields, but no goal. What could be wrong? Attached my cae file. Please help.
