[ANSYS Meshing] Can't get a conformal mesh between bodies
I’m trying to solve a spar meshed with shell elements.
In order to get shell elements, I created 2D surfaces using “Surface from Face”
http://files.engineering.com/getfile.aspx?folder=5...
I formed a new part to identify it as a one body
http://files.engineering.com/getfile.aspx?folder=6...
But solution I get is wrong
http://files.engineering.com/getfile.aspx?folder=b...
PS -
2D body (DM)
http://files.engineering.com/getfile.aspx?folder=8...
3D body (Mechanical, after adding thickness)
http://files.engineering.com/getfile.aspx?folder=c...
PS -
2D body (DM)
RE: [ANSYS Meshing] Can't get a conformal mesh between bodies
I am not sure is there a geometry tollerance you could play with to close tha gaps between the 3 surfaces... The best way would be to create surfaces from adjusting faces or manualy close the gaps.
Once they are touching you will have common nodes and one piece part.
Cheers
Lisek
