Problem with NX Custom Menus
Hi everyone,
I've been searching in this forum and I didn't found solution to my problem. Some guy who no longer works for my company did a customization for NX4. Now I'm trying to update/improve that customization for NX7.5 adding new shortcuts.
The problem is that I don't know why I am unable to make calls to NX commands from my custom menu. I put some easy/dumb code to see if you can help me make it work. Once I get this to work I will do the real customization.
Variable UGII_SITE_DIR is set properly
CODE --> File@startup\toolbar.tbr
TITLE MY_TOOLBAR
VERSION 120
  BUTTON PRINT_PDF
  LABEL Print PDF file
  BITMAP print
  ACTIONS U:\Journal\print_pdf.vb
  BUTTON UG_FILE_NEW
CODE --> File@startup\menus.men
VERSION 120
EDIT UG_GATEWAY_MAIN_MENUBAR
MODIFY
  APPLICATION_BUTTON UG_APP_MODELING
     MENU_FILES menu_modeling.men
END_OF_MODIFY
CODE --> File@application\menu_modeling.men
VERSION 120
BEFORE UG_HELP
  CASCADE_BUTTON Custom_modelling
  LABEL Custom Shortcuts
END_OF_BEFORE
MENU Custom_modelling
  BUTTON UG_FILE_NEW
  ACTIONS STANDARD
  BUTTON PRINT_PDF
  BITMAP print
  ACCELERATOR Ctrl+P
END_OF_MENU
The thing is, toolbar is loaded and both buttons also loaded and working.
The menu is also loaded but only the print custom button appears.
Why doesn't the New file button appear? What am I doing wrong? I can always replace it with a macro, but I don't see it "clean".
To create the menus applying a role is not a option here.
Can you help me?
Thanks a lot!
RE: Problem with NX Custom Menus
Put the 'menu_modeling.men' file in the 'Startup' folder instead of the 'Application' folder.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John!
It works, but I just see one problem there: this will load the 'menu_modeling.men' always and keep it at all apps, not only on the modeling app. I plan to have different menus for drafting, modeling...
I can create those menus hidden and show them only when I want. Code of a new 'menus.men' will be like this or is it too twisted?
MODIFY
MENU_FILES show_modeling.men
END_OF_MODIFY
and in another file in application
SHOW custom_modeling
