Classic Punch and die Probelm.
Hi Guys, I am new to Abaqus . I am modelling classic lunch and die simulation in Abaqus Explicit. I have some problem with boundary condition. The sheet metal doesnt deform even after its been punched. The Punch just passes over the Sheetmetal. do you have any suggestions ?
RE: Classic Punch and die Probelm.
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Thanks again for your patience. I double checked it. I have made contact definitions but I don think its correct. Can you please go through the Input file once and give me a suggestion.
*Heading
** Job name: Job-2 Model name: Model-1
** Generated by: Abaqus/CAE 6.10-1
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Clamp
*End Part
*Part, name=Die
*End Part
*Part, name=Piston
*End Part
*Part, name="Sheet Metal"
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Clamp-1, part=Clamp
-4.62372333094489e-16, 1.77, -1.5786378905173e-15
*Surface, type=REVOLUTION, name=CP-2-Clamp-1
START, 55., 1.25000000000001
LINE, 19.75, 1.25
LINE, 19.75, 25.
*End Instance
*Instance, name=Die-1, part=Die
*Surface, type=REVOLUTION, name=CP-3-Die-1
START, 60., 3.00000000000002
LINE, 25., 3.
CIRCL, 20., -2., 25., -2.
LINE, 20., -5.00000000000001
LINE, 24., -5.00000000000001
LINE, 24., -25.
*End Instance
*Instance, name=Piston-1, part=Piston
9.19800091096544e-16, 22.02, 0.
*Surface, type=REVOLUTION, name=CP-1-Piston-1
START, 19., 15.
LINE, 19., -11.
CIRCL, 15., -15., 15., -11.
LINE, 0., -15.
*End Instance
*Instance, name="Sheet Metal-1", part="Sheet Metal"
1.06640670125363e-15, 3.00999999999999, -1.94908591625969e-15
1.06640670125363e-15, 3.00999999999999, -1.94908591625969e-15, 0.707106811231782, 3.00999999999999, -0.707106811231783, 180.
*Node
1, 44., 0., 0.
2, 38., 0., 0.
3, 34., 0., 0.
4, 28., 0., 0.
5, 22., 0., 0.
6, 16., 0., 0.
7, 12., 0., 0.
8, 6., 0., 0.
9, 50., 0., 0.
10, 0., 0., 0.
11, 49.6400681, 0., 5.98863173
12, 48.5654526, 0., 11.8910437
13, 46.791626, 0., 17.6222553
14, 44.3441238, 0., 23.0997562
15, 41.2581863, 0., 28.2446804
16, 37.5782433, 0., 32.9829597
17, 33.3572769, 0., 37.2463722
18, 28.6560516, 0., 40.9735374
19, 23.5422573, 0., 44.1107941
20, 18.0895195, 0., 46.6129723
21, 12.3763409, 0., 48.4440536
22, 6.48497629, 0., 49.5776672
23, 0.500245273, 0., 49.9974976
24, -3.49891329, 0., 49.8774261
25, -9.44767666, 0., 49.0993004
26, -15.2604189, 0., 47.6142807
27, -20.8534527, 0., 45.4437408
28, -26.1462517, 0., 42.6189346
29, -31.0626163, 0., 39.1805305
30, -35.5317612, 0., 35.1780319
31, -39.4893456, 0., 30.6690636
32, -42.8783913, 0., 25.718544
33, -45.6501045, 0., 20.397747
34, -47.764576, 0., 14.7832785
35, -49.1913681, 0., 8.95596981
36, -49.909935, 0., 2.99971914
37, -49.909935, 0., -2.99971914
38, -49.1913681, 0., -8.95596981
39, -47.764576, 0., -14.7832785
40, -45.6501045, 0., -20.397747
41, -42.8783913, 0., -25.718544
42, -39.4893456, 0., -30.6690636
43, -35.5317612, 0., -35.1780319
44, -31.0626163, 0., -39.1805305
45, -26.1462517, 0., -42.6189346
46, -20.8534527, 0., -45.4437408
47, -15.2604189, 0., -47.6142807
48, -9.44767666, 0., -49.0993004
49, -3.49891329, 0., -49.8774261
50, 0.500245273, 0., -49.9974976
51, 6.48497629, 0., -49.5776672
52, 12.3763409, 0., -48.4440536
53, 18.0895195, 0., -46.6129723
54, 23.5422573, 0., -44.1107941
55, 28.6560516, 0., -40.9735374
56, 33.3572769, 0., -37.2463722
57, 37.5782433, 0., -32.9829597
58, 41.2581863, 0., -28.2446804
59, 44.3441238, 0., -23.0997562
60, 46.791626, 0., -17.6222553
61, 48.5654526, 0., -11.8910437
62, 49.6400681, 0., -5.98863173
63, -41.3274307, 0., -20.4500599
64, -45.9944878, 0., -4.28706169
65, -46.101429, 0., 4.88650703
66, 47.1580849, 0., 11.7834644
67, 45.5249748, 0., 4.00594282
68, 41.6940308, 0., 3.72082329
69, 37.884491, 0., 3.95055199
70, 33.9566689, 0., 3.98896623
71, 30.020216, 0., 4.08458805
72, 26.0005989, 0., 4.39225149
73, 21.3948097, 0., 5.2753377
74, 17.212925, 0., 4.17628098
75, 13.4480877, 0., 3.75673866
76, 7.73936415, 0., 3.70589328
77, 3.82110524, 0., 3.78238964
78, -0.494220465, 0., 3.65335798
79, -5.07626534, 0., 3.88918495
80, -9.48042297, 0., 4.40535545
81, -13.5782232, 0., 4.48644686
82, -17.3680706, 0., 4.84594345
83, -20.8547306, 0., 5.17604685
84, -24.0640907, 0., 4.67431164
85, -29.6295776, 0., 3.90486455
86, -33.1442909, 0., 4.33379078
87, -36.805542, 0., 4.4744668
88, -42.3610344, 0., 4.80171347
89, -42.1236229, 0., -5.4048605
90, -38.412735, 0., -5.05364609
91, -34.5396996, 0., -3.92136478
92, -30.3368397, 0., -4.95794439
93, -24.6137829, 0., -4.3141427
94, -20.2597904, 0., -3.64045024
95, -16.5469322, 0., -4.42191792
96, -11.9398022, 0., -4.19618464
97, -7.75982332, 0., -4.41310501
98, -4.36926603, 0., -4.50531578
99, 4.79595852, 0., -4.28707981
100, 8.59307098, 0., -4.01134539
101, 12.4571533, 0., -3.92742085
102, 16.3557091, 0., -3.91545653
103, 20.2734661, 0., -3.91939712
104, 24.1911182, 0., -3.8983767
105, 30.0430908, 0., -3.84297514
106, 33.9219017, 0., -3.85177112
107, 37.6994934, 0., -3.81330514
108, 41.6068344, 0., -3.76964331
109, 45.6619873, 0., -3.88666749
110, 45.4940758, 0., 8.24908733
111, 42.3183594, 0., 8.82446384
112, 37.7949982, 0., 8.38140011
113, 33.9802971, 0., 7.87717724
114, 30.2339935, 0., 8.07838631
115, 26.5261364, 0., 8.47768402
116, 20.7905655, 0., 8.6194849
117, 16.4829044, 0., 10.2828016
118, 12.6540575, 0., 7.37812471
119, 7.69359493, 0., 7.42781639
120, 3.8519628, 0., 7.72586918
121, -0.256289035, 0., 7.83477116
122, -4.5071764, 0., 8.154706
123, -9.42486477, 0., 8.98061275
124, -13.7200212, 0., 7.65738392
125, -16.4343243, 0., 8.16508293
126, -20.7462082, 0., 8.38521385
127, -25.099596, 0., 8.15133095
128, -29.1138325, 0., 8.29988289
129, -35.1085396, 0., 7.79613209
130, -37.8268852, 0., 8.39699745
131, -42.0378342, 0., 8.12536144
132, -45.6555443, 0., 8.46887398
133, 42.4972687, 0., 12.8360748
134, 36.4010086, 0., 11.111845
135, 32.4277534, 0., 12.1913891
136, 28.7035942, 0., 11.9812088
137, 25.8157787, 0., 14.2964897
138, 20.0643883, 0., 12.7562008
139, 16.0910206, 0., 12.5144024
140, 12.5129929, 0., 13.0625734
141, 7.88270569, 0., 11.584115
142, 4.02174711, 0., 11.71278
143, 0.0491664819, 0., 11.889883
144, -3.9084723, 0., 12.2339849
145, -9.47586918, 0., 13.5488052
146, -13.6132708, 0., 13.2283955
147, -16.6284943, 0., 11.9106474
148, -21.1779423, 0., 11.5950699
149, -24.65835, 0., 12.4604378
150, -29.3948593, 0., 12.4120865
151, -31.6278477, 0., 11.9846802
152, -38.4715195, 0., 12.9419241
153, -41.0300217, 0., 12.4945469
154, -44.8700066, 0., 11.97295
155, -41.2185097, 0., 16.2769661
156, -37.0633354, 0., 16.2498531
157, -33.3843727, 0., 16.4576797
158, -30.2593079, 0., 16.8114586
159, -20.5266418, 0., 17.2275791
160, -16.2599678, 0., 17.5222549
161, -12.9572248, 0., 16.0906811
162, -7.07281113, 0., 16.8931141
163, -3.1246736, 0., 18.0425816
164, 0.350536168, 0., 15.8320093
165, 4.18758535, 0., 15.6570539
166, 8.26432228, 0., 15.3214788
167, 12.4899206, 0., 16.9343128
168, 16.702774, 0., 16.2053814
169, 21.0320835, 0., 16.2256794
170, 24.7435722, 0., 16.4178238
171, 28.2684097, 0., 16.8073597
172, 33.5128593, 0., 16.9256096
173, 36.8455429, 0., 17.2320461
174, 40.9712791, 0., 16.8791924
175, 41.8737106, 0., 19.4579983
176, 37.1577034, 0., 21.085125
177, 33.5643349, 0., 21.214819
178, 28.7690334, 0., 19.6329079
179, 25.6289101, 0., 19.2174721
180, 20.4816246, 0., 20.9923859
181, 16.3810349, 0., 21.0387287
182, 12.5685396, 0., 21.1060104
183, 8.45819855, 0., 21.4233646
184, 4.249547, 0., 19.7367744
185, 0.433582753, 0., 19.8523903
186, -4.09301996, 0., 21.8813076
187, -8.25084591, 0., 21.3455944
188, -12.8237257, 0., 21.7538128
189, -15.8601274, 0., 19.5543804
190, -21.4343452, 0., 19.9014473
191, -25.1318359, 0., 20.8598804
192, -29.2208652, 0., 21.2400131
193, -33.1324387, 0., 19.943222
194, -37.109581, 0., 20.3127594
195, -41.3153458, 0., 20.4429989
196, 41.7522049, 0., 23.821558
197, 36.631176, 0., 24.9541969
198, 33.8323326, 0., 25.020998
199, 28.4702778, 0., 24.3532677
200, 26.5698624, 0., 23.9819431
201, 20.8392086, 0., 25.5484848
202, 16.8788719, 0., 25.4256706
203, 12.3402357, 0., 25.9765663
204, 8.38543701, 0., 25.3251362
205, 4.60371399, 0., 25.5804939
206, 0.0784732774, 0., 25.2020817
207, -4.5601778, 0., 25.7085266
208, -8.15573597, 0., 25.3746586
209, -13.7355795, 0., 25.9133778
210, -17.007103, 0., 22.9290791
211, -19.9155617, 0., 23.7881374
212, -24.4524975, 0., 25.2653694
213, -28.7597694, 0., 25.7923107
214, -32.5203629, 0., 23.8286285
215, -36.8098145, 0., 24.411047
216, -41.1548157, 0., 24.7388935
217, 38.530571, 0., 28.6886578
218, 31.7545776, 0., 28.204361
219, 29.2792931, 0., 28.3833466
220, 25.4727135, 0., 29.1556015
221, 21.2805195, 0., 29.756321
222, 16.2589226, 0., 29.6984367
223, 11.0359144, 0., 29.9614849
224, 7.83998346, 0., 28.6033173
225, 5.72624111, 0., 29.0746193
226, 0.801546335, 0., 28.5117378
227, -4.91678047, 0., 29.4994507
228, -8.43120098, 0., 28.9762821
229, -12.9855185, 0., 29.3514862
230, -16.3866329, 0., 28.9253979
231, -19.7770157, 0., 28.3782406
232, -25.132864, 0., 28.3547535
233, -29.320797, 0., 30.4946938
234, -33.7055359, 0., 28.9709454
235, -36.3457565, 0., 28.5228901
236, 33.3160629, 0., 31.9039803
237, 29.2784786, 0., 33.207859
238, 21.0546665, 0., 32.844265
239, 16.6594734, 0., 32.9726868
240, 12.3553419, 0., 34.9404221
241, 6.43957233, 0., 34.6300125
242, 2.89643335, 0., 32.9471855
243, -0.512054741, 0., 32.1376419
244, -4.16571665, 0., 33.3340607
245, -9.42511845, 0., 32.908287
246, -12.8920717, 0., 32.3263397
247, -16.4528828, 0., 33.3083038
248, -20.5554409, 0., 32.3945999
249, -25.0191841, 0., 33.2054253
250, -29.5063553, 0., 32.9605064
251, -33.0743256, 0., 32.8383865
252, 30.5091, 0., 37.131176
253, 25.267046, 0., 36.4278908
254, 21.8246269, 0., 37.4973907
255, 15.8552904, 0., 37.4570045
256, 13.1166124, 0., 38.4324608
257, 8.33070755, 0., 37.9313698
258, 2.38515663, 0., 37.5016251
259, -0.465119481, 0., 37.432869
260, -3.46348476, 0., 37.104454
261, -8.74516201, 0., 38.2055817
262, -12.2122812, 0., 37.7837257
263, -16.4223232, 0., 36.9640541
264, -19.3411179, 0., 36.7502861
265, -23.768713, 0., 38.9884148
266, -28.257349, 0., 38.6621666
267, 25.7977867, 0., 40.4711304
268, 21.4651737, 0., 40.5401573
269, 17.3852997, 0., 40.6028252
270, 14.2410097, 0., 41.8883591
271, 8.93866253, 0., 41.4794235
272, 3.94561672, 0., 40.6402512
273, 0.726416349, 0., 40.8939209
274, -4.45352459, 0., 42.4063606
275, -7.86573315, 0., 41.9683228
276, -12.8781652, 0., 41.0997314
277, -16.6069031, 0., 41.5431137
278, -19.0543461, 0., 42.14674
279, -23.3439083, 0., 41.8425522
280, 17.3225842, 0., 44.8005486
281, 13.7215862, 0., 46.0536461
282, 9.64301968, 0., 45.1377258
283, 6.05338621, 0., 45.8123169
284, 2.3858707, 0., 46.2010994
285, -1.31366491, 0., 46.2704239
286, -6.82800579, 0., 45.8181839
287, -10.4565868, 0., 45.2107201
288, 45.0973587, 0., -7.73475552
289, 41.2366142, 0., -7.24113798
290, 37.7511063, 0., -8.13420963
291, 33.7261009, 0., -7.85036945
292, 28.2163506, 0., -7.69233561
293, 24.3939667, 0., -7.82133818
294, 20.5262756, 0., -7.85563326
295, 16.6861687, 0., -7.82799721
296, 12.9018135, 0., -7.82524109
297, 7.43313646, 0., -7.99655151
298, 3.94956565, 0., -8.44514084
299, 0.405300051, 0., -9.53649235
300, -4.04330826, 0., -8.32948303
301, -8.04502964, 0., -8.56237698
302, -11.9295263, 0., -8.71546841
303, -15.8787212, 0., -8.69518471
304, -19.8863068, 0., -9.394557
305, -23.9765663, 0., -7.51566076
306, -28.9532852, 0., -7.97546673
307, -33.4559669, 0., -8.57819843
308, -37.7588196, 0., -8.68540955
309, -41.5398026, 0., -8.74801254
310, -45.4533844, 0., -7.95547009
311, -44.6080513, 0., -11.605485
312, -42.2633553, 0., -12.7046289
313, -38.0107002, 0., -12.8857079
314, -32.6777802, 0., -12.3190279
315, -28.703371, 0., -12.3445778
316, -24.9537792, 0., -12.5609245
317, -20.9869671, 0., -11.4601479
318, -16.3878746, 0., -13.0528059
319, -12.1473646, 0., -12.9230194
320, -8.03894329, 0., -12.6883354
321, -4.05324602, 0., -12.4683905
322, 1.24202669, 0., -13.4887171
323, 5.0671339, 0., -13.3059301
324, 8.01366234, 0., -11.7233248
325, 11.4446478, 0., -11.6192579
326, 16.9030113, 0., -13.5406256
327, 20.6950779, 0., -11.8022833
328, 24.7832642, 0., -13.6190615
329, 28.4838161, 0., -11.3898296
330, 32.8064384, 0., -12.333972
331, 41.5994987, 0., -12.1877527
332, 46.4617996, 0., -13.5975084
333, -40.3358116, 0., -17.908453
334, -36.8590851, 0., -16.4227676
335, -32.046875, 0., -17.4982624
336, -29.3420849, 0., -16.8299122
337, -25.330164, 0., -16.6803169
338, -21.4892521, 0., -17.4127789
339, -16.5724068, 0., -17.7584705
340, -12.0440207, 0., -17.1254616
341, -7.91286325, 0., -16.821003
342, -3.73906636, 0., -16.7314892
343, 0.615530968, 0., -17.247406
344, 5.03927326, 0., -16.3834934
345, 8.08374405, 0., -15.9384422
346, 11.8967752, 0., -15.0824528
347, 16.2983322, 0., -17.0434837
348, 20.6800098, 0., -15.9112768
349, 28.612484, 0., -15.144639
350, 32.7438812, 0., -17.2151852
351, 37.2591133, 0., -16.8389549
352, 41.3248062, 0., -15.6744919
353, -37.1649704, 0., -20.5192089
354, -33.3337021, 0., -21.0826454
355, -28.8212261, 0., -20.4758625
356, -25.2892227, 0., -20.8956947
357, -21.3294163, 0., -20.2958164
358, -17.3914738, 0., -20.5348835
359, -11.6789865, 0., -21.1263561
360, -7.82275009, 0., -20.8792973
361, -3.91125464, 0., -20.9099407
362, 0.083657369, 0., -21.4078255
363, 4.58375931, 0., -20.7292156
364, 8.41464901, 0., -20.7466221
365, 11.9851208, 0., -20.3255463
366, 15.5903244, 0., -20.2144356
367, 21.4833794, 0., -20.4510574
368, 24.6138, 0., -21.7919044
369, 29.4546452, 0., -20.8601933
370, 33.0420952, 0., -21.7973022
371, 37.9109001, 0., -20.8576698
372, 41.440197, 0., -21.4150486
373, 41.0105629, 0., -25.5249882
374, 37.3663597, 0., -24.7607574
375, 32.2720222, 0., -26.1344013
376, 28.4641552, 0., -24.6286392
377, 24.7917919, 0., -26.0490074
378, 20.4483948, 0., -24.9742603
379, 15.7828827, 0., -24.5768032
380, 13.1575651, 0., -24.5983868
381, 8.03387737, 0., -23.6050739
382, 3.5709343, 0., -24.6052094
383, -0.579045236, 0., -24.9075642
384, -4.0612874, 0., -24.7024021
385, -7.8636322, 0., -24.804697
386, -11.5916462, 0., -24.7323399
387, -17.7035809, 0., -24.1385612
388, -20.4258881, 0., -23.52104
389, -24.6261024, 0., -25.4991379
390, -28.7626801, 0., -24.135128
391, -33.0521774, 0., -23.5583858
392, -37.0310097, 0., -24.4619083
393, -41.2043915, 0., -24.7543583
394, -36.3902054, 0., -28.4609871
395, -33.7408981, 0., -28.7205563
396, -29.5335293, 0., -28.4605923
397, -25.6436863, 0., -28.5605679
398, -20.2112904, 0., -30.1953182
399, -16.2061634, 0., -28.8302822
400, -13.7333918, 0., -30.115839
401, -7.95278692, 0., -28.87747
402, -3.8833828, 0., -27.9591961
403, -0.150864661, 0., -29.7314301
404, 3.16750002, 0., -29.7452755
405, 8.84944439, 0., -28.9719467
406, 11.9778442, 0., -29.4630928
407, 16.7528038, 0., -28.4849205
408, 21.1308823, 0., -29.9476089
409, 24.6700249, 0., -29.2980309
410, 28.2222538, 0., -28.3647995
411, 32.8592529, 0., -29.7930965
412, 37.6331291, 0., -30.117548
413, -32.8859787, 0., -32.5941353
414, -29.0092106, 0., -33.4074936
415, -25.1416378, 0., -34.0279427
416, -20.3772621, 0., -32.9500008
417, -15.7882967, 0., -34.0613747
418, -12.5033998, 0., -33.3693199
419, -6.9188261, 0., -33.1070633
420, -3.34862494, 0., -33.5789757
421, 0.364918292, 0., -34.2147713
422, 3.51761532, 0., -34.5978622
423, 9.44911957, 0., -33.3675117
424, 13.6288052, 0., -33.3699799
425, 17.5101109, 0., -32.3397446
426, 20.0821705, 0., -32.6547585
427, 25.0909271, 0., -32.6934738
428, 27.721508, 0., -32.1882172
429, 32.1942024, 0., -32.2994308
430, -29.9051495, 0., -37.6280746
431, -24.8081169, 0., -36.6424141
432, -19.5786991, 0., -37.8164558
433, -16.0109024, 0., -37.6334305
434, -11.4555244, 0., -37.1682663
435, -7.60615301, 0., -37.3875618
436, -2.21416116, 0., -37.3162956
437, 2.01079035, 0., -37.8726158
438, 6.22622967, 0., -38.1905098
439, 9.69484806, 0., -36.1390266
440, 13.1122017, 0., -36.7707138
441, 16.8020439, 0., -37.7936974
442, 20.4412727, 0., -37.2316055
443, 23.0890293, 0., -37.5769539
444, 28.7943478, 0., -38.0804329
445, -25.2289906, 0., -40.9383202
446, -21.1507263, 0., -41.1398354
447, -15.6176567, 0., -41.5613976
448, -11.8442173, 0., -40.689518
449, -8.469244, 0., -41.3416824
450, -3.24113226, 0., -42.2933578
451, 0.252528936, 0., -42.5857048
452, 3.70032358, 0., -42.5881195
453, 7.0201335, 0., -42.2966423
454, 12.4598103, 0., -42.831131
455, 17.3009663, 0., -41.1920547
456, 19.8192387, 0., -41.9109192
457, 24.1341877, 0., -41.5651283
458, -12.5949068, 0., -44.4092445
459, -8.99385166, 0., -45.2076759
460, -5.30861425, 0., -45.7723274
461, -1.560992, 0., -46.0868492
462, 2.19632649, 0., -46.1328926
463, 7.72879982, 0., -45.676178
464, 11.8422384, 0., -46.6990051
465, 15.5026455, 0., -45.6312752
466, 48., 0., 0.
467, 46., 0., 0.
468, 42., 0., 0.
469, 40., 0., 0.
470, 36., 0., 0.
471, 32., 0., 0.
472, 30., 0., 0.
473, 26., 0., 0.
474, 24., 0., 0.
475, 20., 0., 0.
476, 18., 0., 0.
477, 14., 0., 0.
478, 10., 0., 0.
479, 8., 0., 0.
480, 4., 0., 0.
481, 2., 0., 0.
482, 49.9599648, 0., 2.00048041
483, 49.8399239, 0., 3.99775696
484, 49.3607178, 0., 7.96991634
485, 49.0023193, 0., 9.93843746
486, 48.050808, 0., 13.8246069
487, 47.4592171, 0., 15.7360315
488, 46.049099, 0., 19.4802608
489, 45.23283, 0., 21.3070679
490, 43.3844032, 0., 24.8554497
491, 42.3552094, 0., 26.5713425
492, 40.0950928, 0., 29.8727894
493, 38.8677902, 0., 31.4530582
494, 36.2285194, 0., 34.460041
495, 34.8207779, 0., 35.8819351
496, 31.840353, 0., 38.5511589
497, 30.2724419, 0., 39.7942123
498, 26.9937706, 0., 42.0872459
499, 25.2882633, 0., 43.1335564
500, 21.7585526, 0., 45.0173912
501, 19.9400024, 0., 45.8518944
502, 16.2100677, 0., 47.2994041
503, 14.3046589, 0., 47.9100914
504, 10.4282036, 0., 48.9004364
505, 8.46336651, 0., 49.2785072
506, 4.49620056, 0., 49.7974319
507, 2.50022483, 0., 49.9374504
508, -1.50053549, 0., 49.977478
509, -5.49168777, 0., 49.6974983
510, -7.47566795, 0., 49.4379845
511, -11.4045553, 0., 48.6819878
512, -13.3431711, 0., 48.186718
513, -17.1532288, 0., 46.9655914
514, -19.018568, 0., 46.2416916
515, -22.6549416, 0., 44.5730133
516, -24.4201488, 0., 43.630909
517, -27.8304825, 0., 41.5387077
518, -29.4701462, 0., 40.3919601
519, -32.6053429, 0., 37.906353
520, -34.0958519, 0., 36.571476
521, -36.9107704, 0., 33.7282524
522, -38.2306709, 0., 32.2244606
523, -40.6847839, 0., 29.0645542
524, -41.8150711, 0., 27.4134998
525, -43.8730469, 0., 23.9824047
526, -44.7974434, 0., 22.2078571
527, -46.429657, 0., 18.5549736
528, -47.1348572, 0., 16.6824837
529, -48.3178024, 0., 12.8603992
530, -48.7936554, 0., 10.9169264
531, -49.5103035, 0., 6.98067141
532, -49.7499542, 0., 4.99419403
533, -49.9899902, 0., 1.00044048
534, -49.9899902, 0., -1.00044048
535, -49.7499542, 0., -4.99419403
536, -49.5103035, 0., -6.98067141
537, -48.7936554, 0., -10.9169264
538, -48.3178024, 0., -12.8603992
539, -47.1348572, 0., -16.6824837
540, -46.429657, 0., -18.5549736
541, -44.7974434, 0., -22.2078571
542, -43.8730469, 0., -23.9824047
543, -41.8150711, 0., -27.4134998
544, -40.6847839, 0., -29.0645542
545, -38.2306709, 0., -32.2244606
546, -36.9107704, 0., -33.7282524
547, -34.0958519, 0., -36.571476
548, -32.6053429, 0., -37.906353
549, -29.4701462, 0., -40.3919601
550, -27.8304825, 0., -41.5387077
551, -24.4201488, 0., -43.630909
552, -22.6549416, 0., -44.5730133
553, -19.018568, 0., -46.2416916
554, -17.1532288, 0., -46.9655914
555, -13.3431711, 0., -48.186718
556, -11.4045553, 0., -48.6819878
557, -7.47566795, 0., -49.4379845
558, -5.49168777, 0., -49.6974983
559, -1.50053549, 0., -49.977478
560, 2.50022483, 0., -49.9374504
561, 4.49620056, 0., -49.7974319
562, 8.46336651, 0., -49.2785072
563, 10.4282036, 0., -48.9004364
564, 14.3046589, 0., -47.9100914
565, 16.2100677, 0., -47.2994041
566, 19.9400024, 0., -45.8518944
567, 21.7585526, 0., -45.0173912
568, 25.2882633, 0., -43.1335564
569, 26.9937706, 0., -42.0872459
570, 30.2724419, 0., -39.7942123
571, 31.840353, 0., -38.5511589
572, 34.8207779, 0., -35.8819351
573, 36.2285194, 0., -34.460041
574, 38.8677902, 0., -31.4530582
575, 40.0950928, 0., -29.8727894
576, 42.3552094, 0., -26.5713425
577, 43.3844032, 0., -24.8554497
578, 45.23283, 0., -21.3070679
579, 46.049099, 0., -19.4802608
580, 47.4592171, 0., -15.7360315
581, 48.050808, 0., -13.8246069
582, 49.0023193, 0., -9.93843746
583, 49.3607178, 0., -7.96991634
584, 49.8399239, 0., -3.99775696
585, 49.9599648, 0., -2.00048041
586, 47.7196083, 0., -3.95094204
587, -47.8625793, 0., -4.63725424
588, -45.2940598, 0., -15.9188929
589, -14.8149767, 0., -45.7527351
590, -9.217206, 0., -47.1426239
591, 31.9931755, 0., -1.90941012
592, 27.9731007, 0., 2.12703061
593, 20.1355686, 0., -1.95141542
594, 14.1999283, 0., -1.95262885
595, 18.1561241, 0., -1.95064223
596, 33.9573364, 0., -1.89986587
597, 15.7131672, 0., 1.97794759
598, 10.2511606, 0., -1.97811842
599, 4.35994053, 0., -2.18319511
600, 2.44900227, 0., -2.36812568
601, 46.7281609, 0., 13.3052378
602, -48.0296478, 0., -2.72029543
603, 33.9687271, 0., 1.9946301
604, 35.9547844, 0., 1.97444308
605, 23.8310165, 0., 2.38599014
606, 17.6849422, 0., 2.12624598
607, 39.8760605, 0., 1.91048241
608, 45.8026657, 0., 1.98876035
609, 47.838459, 0., 2.02527976
610, 47.4231339, 0., 6.06180048
611, 11.8871632, 0., 46.5681152
612, 22.5143147, 0., 42.3411789
613, 45.1121597, 0., 16.7800579
614, 39.6687393, 0., 27.1170216
615, 36.0699272, 0., 31.7116508
616, 31.9686012, 0., 35.8730736
617, 27.4304218, 0., 39.4331703
618, 6.26845264, 0., 47.6817055
619, 0.514170825, 0., 48.1238937
620, -3.33121991, 0., 48.0248947
621, -42.1252823, 0., 23.0451832
622, -44.6719322, 0., 17.8217735
623, -43.8866653, 0., 19.581562
624, -34.2897987, 0., 33.9840546
625, -39.0491905, 0., 28.0112419
626, -29.8679771, 0., 37.5648499
627, -43.86026, 0., -19.5365334
628, -43.0439568, 0., -21.3082504
629, -40.1717224, 0., -26.4128361
630, -28.3871098, 0., -38.7827072
631, -18.4333172, 0., -44.4547386
632, -20.1900921, 0., -43.6885605
633, -32.8138275, 0., -35.1888199
634, -3.47426581, 0., -47.89151
635, 0.401673257, 0., -48.0370636
636, 36.3288918, 0., -31.543272
637, 39.9622421, 0., -27.0981617
638, 31.7714081, 0., -35.3320618
639, 27.2826805, 0., -39.3390465
640, 42.8834801, 0., -22.23209
641, 43.6900444, 0., -20.4957657
642, 44.4344368, 0., -18.7142963
643, 46.7185936, 0., -11.7540445
644, 13.7481537, 0., 1.88803411
645, 7.86014462, 0., 1.84665859
646, 1.839347, 0., 1.84039688
647, -47.4258919, 0., 8.71072769
648, -48.0765572, 0., 3.03385806
649, 5.89323807, 0., 1.86748731
650, 43.8163567, 0., 1.90721834
651, 47.4930916, 0., -5.90548849
652, 15.5383596, 0., 45.4678917
653, -24.9824352, 0., 40.804451
654, -21.6752777, 0., 42.8311539
655, -19.9737072, 0., 43.7554932
656, -14.6261711, 0., 45.9658546
657, -9.04291725, 0., 47.3226891
658, -47.3030052, 0., -8.45019054
659, -45.9046898, 0., -14.0845575
660, 25.7288685, 0., -40.4952965
661, 22.4832783, 0., -42.5465469
662, 13.6848316, 0., -46.2039452
663, 17.2895527, 0., -44.988945
664, -23.5887222, 0., -41.9264526
665, 8.08778095, 0., -47.4596786
666, 6.18266869, 0., -47.7218208
667, 42.6787109, 0., 22.1132832
668, -36.7550583, 0., -31.0549965
669, 43.8254967, 0., -1.92840886
670, 45.8461151, 0., -1.95919275
671, 41.8380852, 0., 1.87669754
672, 41.8087082, 0., -1.90050745
673, 37.8489761, 0., -1.88133276
674, 39.8072853, 0., -1.88166165
675, 35.9068718, 0., -1.88924634
676, 37.924984, 0., 1.94517303
677, 31.9786167, 0., 2.01621079
678, 30.020134, 0., -1.91253936
679, 29.9865799, 0., 2.05736661
680, 28.0442543, 0., -1.91975224
681, 25.9306622, 0., 2.24273562
682, 26.069088, 0., -1.92956066
683, 22.1146545, 0., -1.94633174
684, 24.0912838, 0., -1.9365108
685, 21.7196655, 0., 2.49032044
686, 19.6907291, 0., 2.32665992
687, 16.1769638, 0., -1.94801259
688, 12.2238436, 0., -1.9574517
689, 11.7874002, 0., 1.84431696
690, 9.82320023, 0., 1.83007157
691, 6.31264544, 0., -2.0763123
692, 8.27901363, 0., -2.01162624
693, 3.89656639, 0., 1.87338877
694, 0.657436311, 0., -2.68436694
695, 47.6313705, 0., 4.04413843
696, 47.3796196, 0., 8.00258923
697, 47.277504, 0., 9.9405489
698, 45.8894196, 0., 14.9978905
699, 44.3391953, 0., 18.58148
700, 43.5356712, 0., 20.3652706
701, 40.7455101, 0., 25.4927635
702, 37.3285637, 0., 30.2189045
703, 33.3822479, 0., 34.5486565
704, 29.0015163, 0., 38.3199081
705, 20.8181591, 0., 43.2266388
706, 19.08881, 0., 44.0528641
707, 10.0351706, 0., 47.0119896
708, 8.16099644, 0., 47.3843155
709, 4.36019516, 0., 47.9073982
710, 2.44479394, 0., 48.054615
711, -1.40624273, 0., 48.1129494
712, -5.24520731, 0., 47.8617058
713, -7.1466732, 0., 47.6265373
714, -12.7847881, 0., 46.497757
715, -16.44063, 0., 45.3340645
716, -18.2265778, 0., 44.5945587
717, -31.4243336, 0., 36.4601898
718, -35.5632095, 0., 32.5784187
719, -43.0359459, 0., 21.3242149
720, -45.3864403, 0., 16.046545
721, -46.5812035, 0., 12.4217777
722, -47.047596, 0., 10.5716677
723, -47.7178345, 0., 6.83145618
724, -47.9314804, 0., 4.93581104
725, -48.1397972, 0., 1.11998248
726, -48.1215172, 0., -0.80200243
727, -47.6207809, 0., -6.54662085
728, -46.9109688, 0., -10.3459063
729, -44.6081352, 0., -17.7375221
730, -35.5099907, 0., -32.4942856
731, -31.385004, 0., -36.4334373
732, -21.9065018, 0., -42.8450966
733, -16.6368732, 0., -45.1419983
734, -11.100728, 0., -46.752552
735, -7.31772089, 0., -47.4623032
736, -5.39972353, 0., -47.7142982
737, -1.53691995, 0., -48.0044441
738, 2.33725858, 0., -48.0079231
739, 4.26674891, 0., -47.904068
740, 9.97518444, 0., -47.1197472
741, 19.0520344, 0., -44.2613373
742, 30.273344, 0., -36.7085152
743, 34.9073219, 0., -32.8844452
744, 38.839138, 0., -28.6300812
745, 41.987709, 0., -23.910387
746, 45.1969299, 0., -16.9687901
747, 45.999649, 0., -15.3634481
748, 46.8874054, 0., -9.83100414
749, 47.1962929, 0., -7.86831522
750, -45.0684929, 0., -9.79334068
751, -42.8124847, 0., -16.9409809
752, -17.8399563, 0., -42.6887131
753, -16.119997, 0., -43.3408127
754, 31.9902496, 0., -3.83947182
755, -45.9095955, 0., 6.68924379
756, -46.2840538, 0., 1.23092771
757, 31.9910278, 0., 4.01951218
758, 19.1724148, 0., 4.58393383
759, 43.5886383, 0., 3.76029134
760, 40.1665344, 0., 22.8376923
761, 11.4121752, 0., 44.7120705
762, 24.1635017, 0., 41.4232864
763, 42.6537628, 0., 17.7001343
764, 38.1200752, 0., 26.0254536
765, 27.7873726, 0., 36.867588
766, 4.2314539, 0., 46.0453949
767, 0.539832354, 0., 46.2752495
768, -38.7433128, 0., 21.2125301
769, -43.6601295, 0., 15.3876724
770, -34.1855621, 0., 31.4671574
771, -28.7568741, 0., 35.8516121
772, -46.0247574, 0., 14.2493687
773, -39.0812492, 0., -28.0171967
774, -34.1956024, 0., -33.8786049
775, 35.1796303, 0., -30.1139393
776, 38.6693344, 0., -25.9375267
777, 30.0606117, 0., -33.1431122
778, 5.80830002, 0., 3.75146317
779, 6.6795187, 0., -4.11307192
780, 43.631958, 0., -3.81302595
781, 44.3267517, 0., 14.0656004
782, -42.9383965, 0., 17.0690651
783, 16.5679169, 0., 43.0229988
784, -26.6179981, 0., 39.7417603
785, 34.5980606, 0., 30.4829464
786, 31.980896, 0., 33.2526779
787, -12.2418795, 0., 44.8102379
788, -15.7270432, 0., 43.7469902
789, 40.5997238, 0., -22.9789181
790, -43.473896, 0., -15.167491
791, 25.8675194, 0., -37.8347664
792, 22.9483776, 0., -40.0587196
793, 18.1675167, 0., -42.7023926
794, 14.7999001, 0., -43.975563
795, -24.3017063, 0., -39.279995
796, 4.05650759, 0., -46.0617104
797, 0.319755763, 0., -46.1492157
798, 39.6050797, 0., -3.7665596
799, 1.73502958, 0., 3.7435925
800, 2.95927572, 0., -4.56210089
801, 43.4408989, 0., 15.8781586
802, 34.7515602, 0., 33.1595764
803, -10.9204636, 0., 46.9463387
804, -32.9025307, 0., 35.2999039
805, -38.4604645, 0., 25.3992863
806, -45.7610741, 0., -6.12942505
807, -46.4439316, 0., -12.2296209
808, -42.0898666, 0., -18.7071819
809, -40.4970741, 0., -22.1548309
810, -30.1864147, 0., -34.9399071
811, -14.3685102, 0., -43.910923
812, -12.9629345, 0., -46.2907181
813, 20.7874165, 0., -43.4459724
814, 33.3616753, 0., -34.1206779
815, 43.433876, 0., -15.9072571
816, 35.8217392, 0., -3.84646916
817, 14.4025021, 0., -3.91324401
818, 18.312952, 0., -3.91438699
819, 15.324048, 0., 3.91856742
820, 10.5191402, 0., -3.95208812
821, 35.9410629, 0., 3.96941495
822, 39.8036995, 0., 3.84734321
823, 36.9926186, 0., 27.5292053
824, 30.614233, 0., 34.527195
825, 24.6662865, 0., 38.8306313
826, 7.86479807, 0., 45.5120735
827, -42.1544876, 0., 18.754488
828, -39.5831299, 0., -23.817091
829, -26.8290691, 0., -39.889637
830, -27.3077908, 0., -37.1826744
831, -19.5148125, 0., -41.9537354
832, -3.43542242, 0., -45.9670105
833, 37.6047668, 0., -27.3885078
834, 28.6277084, 0., -35.0406914
835, 42.7596512, 0., -17.9648075
836, 44.6024284, 0., -9.83890915
837, -0.41963926, 0., 1.64801705
838, -45.3163872, 0., 10.2247105
839, 45.4260178, 0., -5.7928381
840, 14.8812656, 0., 43.6637573
841, -22.1881123, 0., 40.0744553
842, -20.6256447, 0., 41.1464272
843, -8.64613056, 0., 45.5423203
844, 13.0703325, 0., -44.5117302
845, -34.1250992, 0., -31.2684326
846, 11.5533829, 0., 3.67318583
847, -1.07178485, 0., -3.27343249
848, 45.5810471, 0., 10.1363678
849, 39.1885872, 0., 24.4567795
850, 19.8680267, 0., 41.4614182
851, -4.99600887, 0., 46.0341835
852, -13.9978437, 0., 44.3294716
853, -17.4159966, 0., 43.0179787
854, -46.223587, 0., 3.05884719
855, -46.2562408, 0., -0.611535907
856, -46.1574478, 0., -2.45567703
857, -10.7963333, 0., -44.8398972
858, -7.1548934, 0., -45.521225
859, 9.53133106, 0., -45.3673401
860, 44.8099289, 0., -14.9356375
861, 43.4120445, 0., -5.64773989
862, 39.4352455, 0., -5.62279034
863, 35.7501678, 0., -5.91996622
864, 14.6003866, 0., -5.87318659
865, 10.7888346, 0., -5.91206932
866, 7.06302834, 0., -6.08742857
867, 3.45601416, 0., -6.58251381
868, -43.9306488, 0., -5.74692965
869, -38.8511772, 0., -21.3018112
870, -22.7427826, 0., -40.2452011
871, -43.2116508, 0., 11.5302095
872, 13.0877771, 0., 5.58271551
873, 43.2861099, 0., 7.58315897
874, 43.2386551, 0., 5.43876505
875, 35.4566116, 0., 26.3556423
876, 27.9351387, 0., 34.3626633
877, 23.7667694, 0., 37.1986885
878, 9.28270245, 0., 43.2975464
879, 26.6119766, 0., 35.4438133
880, 34.3314323, 0., 27.8343296
881, -39.6214828, 0., 19.5648499
882, -39.4633255, 0., 23.7784023
883, -25.4034977, 0., 37.9195862
884, -31.8234406, 0., 34.0505638
885, -31.8167763, 0., 31.817934
886, -35.275322, 0., -29.8836441
887, -37.9435005, 0., -29.5608711
888, 40.0599022, 0., -20.689621
889, 29.9310513, 0., -30.5828876
890, 41.4211388, 0., -13.8618803
891, 43.2885971, 0., -12.2025814
892, 43.1219597, 0., -7.42727566
893, 39.8833733, 0., 5.87083721
894, 35.9338951, 0., 5.96193981
895, 9.48538113, 0., 5.45299435
896, 5.7754693, 0., 5.66625452
897, 1.73789728, 0., 5.74291515
898, -44.0741768, 0., 6.57129812
899, -44.412899, 0., 1.32323277
900, -2.8258779, 0., 3.59992003
901, -43.8686829, 0., 8.25703144
902, 20.3606472, 0., 38.7726669
903, -20.8883438, 0., 38.3344727
904, 23.0298481, 0., 39.6234322
905, 15.8357706, 0., 41.2962189
906, 7.58468914, 0., 43.6689453
907, 4.11703682, 0., 44.212429
908, 0.581130266, 0., 44.4511757
909, -8.25436115, 0., 43.7571144
910, -43.2715263, 0., -9.26396942
911, -5.17705727, 0., -43.8792343
912, -44.0713272, 0., -13.3980675
913, -8.74134064, 0., -43.2822304
914, 21.4104881, 0., -41.0302773
915, 14.1054344, 0., -42.3329391
916, 11.3124485, 0., -44.979744
917, -3.35960531, 0., -44.1020012
918, 0.267629921, 0., -44.332592
919, 3.86413884, 0., -44.2902718
920, -44.310688, 0., 13.7003307
921, -37.4978676, 0., -26.9743309
922, -44.3866081, 0., -0.442131013
923, 31.916914, 0., 30.6915455
924, -35.2694778, 0., 30.0178185
925, -25.822319, 0., -38.2595253
926, -31.5668526, 0., -33.7938423
927, 33.7826805, 0., -31.308527
928, 39.6687088, 0., -24.4694023
929, -15.0332003, 0., 42.2121849
930, 16.4961624, 0., -43.3845749
931, 40.2227402, 0., 18.6162109
932, 18.2402763, 0., 42.2951546
933, -31.6619949, 0., -31.3574772
934, -28.7660084, 0., -36.0751152
935, 39.2349548, 0., -22.030283
936, -42.8013687, 0., -11.0032406
937, -18.8304443, 0., -40.2495537
938, -13.9271965, 0., -42.0918427
939, 31.9719505, 0., -5.7712059
940, -44.2395554, 0., 4.83944035
941, 32.0315285, 0., 6.00161362
942, 18.2370262, 0., 6.6308217
943, 45.0475159, 0., 6.23838949
944, 39.4592133, 0., 20.3006859
945, 37.7075958, 0., 23.4674091
946, -41.9530334, 0., 14.6949701
947, -27.087841, 0., 36.8736992
948, 36.4454536, 0., -28.7867222
949, -40.4429665, 0., 17.9116211
950, 30.6173401, 0., 31.9851456
951, -41.6677208, 0., -14.4175062
952, 27.2561283, 0., -36.5341835
953, 18.8526497, 0., -40.4386406
954, 5.62810421, 0., -44.1642494
955, 2.07463193, 0., -44.3518677
956, 41.7296638, 0., 15.0256109
957, -37.415226, 0., 26.9761868
958, -43.6477699, 0., -7.50639868
959, -39.6009789, 0., -19.6336021
960, -38.0239563, 0., -22.9093437
961, -12.2075233, 0., -42.5447273
962, 12.6841202, 0., -5.87664747
963, 18.4636822, 0., -5.88262224
964, 14.8286295, 0., 5.80670929
965, 8.91214275, 0., -5.96907854
966, 37.8968468, 0., 6.04815578
967, 41.681282, 0., 5.41089249
968, 5.86394405, 0., 43.9766273
969, -1.54854405, 0., -44.255825
970, 36.382103, 0., -26.1629276
971, 13.161602, 0., 44.2256699
972, -19.4609795, 0., 39.5569
973, -11.723917, 0., 43.117218
974, 11.310256, 0., 5.45263958
975, -1.87908065, 0., -1.0621773
976, 45.5225525, 0., 12.2388401
977, -4.73370409, 0., 44.214119
978, -18.0695457, 0., 40.6366348
979, -44.2910309, 0., -2.21483088
980, 7.36858606, 0., -43.9568443
981, 20.4037189, 0., -5.88362217
982, -0.580883503, 0., -5.43363762
983, -35.936039, 0., -25.9152737
984, -30.3614178, 0., -32.3443069
985, -27.6321774, 0., -34.5162697
986, 30.5627975, 0., 29.5214405
987, 29.2232437, 0., 35.7331963
988, -39.4925232, 0., 15.4407454
989, -31.065382, 0., 32.9615173
990, -1.48646212, 0., -42.4850578
991, 1.18596077, 0., -4.95014954
992, 43.2423706, 0., -10.928257
993, 40.0158653, 0., 14.469758
994, 15.1411896, 0., 39.6163177
995, 18.8977337, 0., 39.7840958
996, 24.2556648, 0., 35.0871544
997, 36.3348236, 0., 22.5421715
998, 38.5496559, 0., 17.8522835
999, -25.9916611, 0., 35.0475349
1000, -18.1029701, 0., 38.140255
1001, -34.7346458, 0., 27.4706669
1002, -14.4141407, 0., 40.7439194
1003, -22.4139652, 0., 37.075634
1004, 10.9664841, 0., 42.8838654
1005, -9.99938107, 0., 43.4603462
1006, -39.8544426, 0., -13.6555395
1007, -37.8435516, 0., -18.8682652
1008, 33.087059, 0., -27.4522705
1009, 39.4469986, 0., -15.4421835
1010, 25.6724205, 0., -35.1928673
1011, 40.9740219, 0., -17.4885731
1012, -34.8106079, 0., -27.3311691
1013, 9.09362984, 0., -43.6611557
1014, -23.3629913, 0., -37.6435356
1015, -15.1040287, 0., -39.8386803
1016, 5.37037945, 0., -42.4957733
1017, 14.9778919, 0., -40.1855202
1018, -36.770298, 0., 31.1033192
1019, -41.0245323, 0., -10.3886805
1020, 2.35616207, 0., 44.372673
1021, -2.96643138, 0., 44.3646393
1022, -37.8001404, 0., 22.8268547
1023, 31.5650158, 0., -30.3954659
1024, 7.65760231, 0., 5.54262018
1025, 5.24519682, 0., -6.28382349
1026, 38.3144226, 0., -23.3573303
1027, 21.7191772, 0., -38.6146202
1028, 37.6033554, 0., -5.83872223
1029, 3.7980895, 0., 5.71993113
1030, -36.559948, 0., -22.070797
1031, -26.2304306, 0., -35.6018105
1032, 26.8179798, 0., -33.7774963
1033, 42.6516571, 0., -9.08696365
1034, -3.10826945, 0., 1.03058386
1035, -41.6722336, 0., 11.1130009
1036, -2.7531662, 0., -3.9941051
1037, -6.49515676, 0., 44.0098228
1038, -10.4781046, 0., -42.931778
1039, -6.9627223, 0., -43.6041336
1040, 41.4214478, 0., -5.56195974
1041, 11.0395374, 0., -7.84287071
1042, -20.3701954, 0., -39.4616394
1043, -21.8801613, 0., -38.5884476
1044, 15.8095999, 0., 8.02509117
1045, 9.37357616, 0., 7.12433815
1046, 35.3056831, 0., 23.8949814
1047, 26.6457596, 0., 33.0012817
1048, 32.8340034, 0., 26.739748
1049, -31.1713696, 0., 29.526495
1050, 28.0969009, 0., -30.2768402
1051, 40.4267921, 0., 8.06056404
1052, -0.407045841, 0., 5.74837208
1053, -42.1861954, 0., 6.49390602
1054, -42.5227089, 0., -0.307973355
1055, 5.68678713, 0., 42.1633453
1056, -41.8933449, 0., -7.08809805
1057, -4.97468138, 0., -42.029808
1058, 1.99214816, 0., -42.6312943
1059, 37.883728, 0., 19.5366936
1060, -31.2344837, 0., -29.035408
1061, -16.6326447, 0., -39.2628174
1062, 30.0577145, 0., -5.75269079
1063, -42.4838371, 0., 3.09461164
1064, 30.1105309, 0., 6.08381701
1065, 19.7020569, 0., 7.37495613
1066, -40.2463531, 0., 13.9201765
1067, -26.7068596, 0., 32.3155289
1068, -38.7482491, 0., 17.0636711
1069, -37.9641991, 0., 18.6991596
1070, 29.2945538, 0., 30.7356052
1071, -39.242054, 0., -15.3932962
1072, 17.8846359, 0., -39.0502777
1073, -35.7797813, 0., 25.9475231
1074, -38.5642471, 0., -17.1462212
1075, 14.7831526, 0., -7.81239939
1076, 35.8426361, 0., 7.82011271
1077, 36.0389519, 0., -23.6115379
1078, -16.9956322, 0., 39.3021698
1079, -44.140522, 0., -3.98814583
1080, -42.4344292, 0., -2.0193491
1081, 33.8725777, 0., -5.84374857
1082, 22.3498955, 0., -5.87835884
1083, 18.6001625, 0., -7.83771324
1084, -40.2014694, 0., -6.74771881
1085, -39.5350075, 0., 11.6325836
1086, 35.9884682, 0., 9.36768055
1087, 15.0705109, 0., 9.76299667
1088, 9.41888809, 0., 8.44900322
1089, 38.2802925, 0., 10.6114502
1090, 10.5500822, 0., 41.0796661
1091, -6.15444565, 0., 42.2083855
1092, -37.9295654, 0., 29.5785656
1093, -2.3713057, 0., -5.95152283
1094, 14.9435101, 0., -9.72805309
1095, 35.6215019, 0., -8.18472385
1096, 28.1752319, 0., 6.22398376
1097, 18.5739174, 0., 9.14077187
1098, -40.2527657, 0., 6.45229053
1099, -4.5321331, 0., -3.13502479
1100, -2.58799458, 0., 5.83314943
1101, 25.3364754, 0., 31.6436901
1102, 31.3681698, 0., 25.8590946
1103, -25.8530006, 0., 30.5142117
1104, 7.07536077, 0., 40.0588875
1105, 11.2566233, 0., -9.74747849
1106, -39.3007202, 0., -9.69975185
1107, -6.38870859, 0., -39.8218918
1108, -13.4901667, 0., -40.3239174
1109, -35.0937347, 0., -19.9194202
1110, -18.1201572, 0., -38.585743
1111, 25.8597603, 0., -31.3185196
1112, 36.9251556, 0., -22.1435375
1113, -35.5811615, 0., -23.4726143
1114, -32.04179, 0., -27.5352345
1115, 31.1130962, 0., -26.7247696
1116, -27.8505459, 0., -31.8925705
1117, -1.34952164, 0., -40.7857895
1118, 1.9612571, 0., -40.9774399
1119, 5.14427137, 0., -40.8918495
1120, 10.2596636, 0., -41.6317558
1121, 39.450676, 0., -7.27978039
1122, 5.6804862, 0., -8.16803741
1123, 25.3872852, 0., 34.0719223
1124, 22.1707039, 0., 35.5293732
1125, 38.9019585, 0., -20.1235714
1126, 29.8895397, 0., -28.5624142
1127, 33.9658928, 0., 5.95048094
1128, 5.8336978, 0., 7.62080669
1129, 1.81084669, 0., 7.76833153
1130, 17.9203949, 0., 38.2689018
1131, 13.656352, 0., 40.1593857
1132, 2.33975458, 0., 42.5747299
1133, -1.05502594, 0., 42.6470032
1134, 20.3128071, 0., -39.5716476
1135, 16.4962578, 0., -39.781189
1136, -15.8208361, 0., 40.2211075
1137, 42.1971588, 0., 6.66873312
1138, -10.8231249, 0., 39.6861954
1139, 40.2964134, 0., 10.4627924
1140, 30.4098511, 0., 27.1884708
1141, -37.7205162, 0., 14.5624161
1142, -28.1902905, 0., 31.3843784
1143, 1.67612171, 0., -7.00471354
1144, 41.9923286, 0., -10.6063347
1145, 38.4868011, 0., 12.5470886
1146, 35.0033226, 0., 21.7457237
1147, 35.709816, 0., 20.3805485
1148, 39.2448158, 0., 16.1376648
1149, -17.4384174, 0., 35.5891495
1150, -33.0975952, 0., 26.4185581
1151, -13.9877367, 0., 39.277504
1152, -20.7748947, 0., 34.8965645
1153, -40.4374619, 0., -11.9937201
1154, -36.0667801, 0., -18.1251049
1155, 24.076767, 0., -33.9644699
1156, -33.1840439, 0., -26.1439877
1157, -14.5838289, 0., -38.1981277
1158, 12.7052879, 0., -39.0329552
1159, -36.1734848, 0., 21.8775463
1160, -23.7790718, 0., -35.0535011
1161, -5.58963776, 0., 1.7263509
1162, -4.70166063, 0., -1.01481438
1163, -10.1491108, 0., -41.0031967
1164, -22.4040394, 0., -36.0363998
1165, 26.6977119, 0., 30.5544434
1166, -32.0704651, 0., 27.9581776
1167, -40.5926628, 0., -1.86938345
1168, -40.6886597, 0., 1.43260121
1169, 36.3283157, 0., 18.9308033
1170, 28.1441956, 0., -5.77536488
1171, 22.4217625, 0., 7.52571535
1172, -35.5357742, 0., 19.4246387
1173, -37.4827843, 0., -14.6748924
1174, -35.176796, 0., 23.405035
1175, 33.9569778, 0., -24.0550804
1176, -42.3004494, 0., -3.73428035
1177, -3.00220418, 0., -40.556366
1178, 12.0941582, 0., 9.13922977
1179, 28.0388699, 0., 4.20434523
1180, 5.5270195, 0., 40.3836021
1181, -31.4572601, 0., 25.3366585
1182, 0.31405735, 0., -40.9297943
1183, 3.58432555, 0., -40.9684181
1184, 26.3161831, 0., -29.7691841
1185, 39.7804871, 0., -11.8703976
1186, 31.8971939, 0., -7.62597942
1187, 32.1139374, 0., 7.97947121
1188, 1.91831195, 0., 9.7887125
1189, -2.37085581, 0., 7.94858742
1190, -38.8936844, 0., -0.145345002
1191, -40.4463768, 0., 10.7717552
1192, -35.4062347, 0., 15.581727
1193, -34.8271828, 0., 17.1207275
1194, -34.6040688, 0., 20.9188271
1195, -33.5833664, 0., 22.3768635
1196, 35.1207657, 0., 16.998888
1197, 34.3073845, 0., 19.7826309
1198, -18.3079147, 0., 34.0543175
1199, 24.0443611, 0., 30.224844
1200, -10.4488564, 0., 37.9877663
1201, -5.79964209, 0., 40.4223671
1202, -9.1462183, 0., 39.9452057
1203, -35.8010902, 0., -14.0812035
1204, -34.4591789, 0., -17.2376595
1205, -34.299015, 0., -22.3847504
1206, -26.5039101, 0., -32.9780273
1207, -22.7133045, 0., -33.4857101
1208, 9.48002529, 0., -9.7902174
1209, 22.5589905, 0., -32.8014183
1210, -33.4611282, 0., -18.6169624
1211, 31.5998764, 0., -24.8674831
1212, 19.1631832, 0., -38.1808434
1213, -17.3830204, 0., -36.9880829
1214, 6.68191624, 0., -40.7507172
1215, 22.9261837, 0., -35.1350594
1216, 22.2320194, 0., -3.90621138
1217, 17.2942543, 0., 8.54708385
1218, 22.4545784, 0., -7.84235334
1219, 14.5212898, 0., 37.9907646
1220, 22.9045925, 0., 34.0072212
1221, -15.1752806, 0., 39.2218361
1222, -23.0954838, 0., 34.0458488
1223, 8.63145733, 0., 39.6966324
1224, 29.9082661, 0., -25.0528717
1225, 14.4146175, 0., -38.2949219
1226, -7.32908678, 0., 4.20183992
1227, 33.237236, 0., -9.66513348
1228, 15.6715679, 0., 11.4414425
1229, -40.4622116, 0., 4.73710299
1230, -38.716198, 0., -7.85136986
1231, 26.1417179, 0., -3.87211084
1232, 28.3694839, 0., 8.22793102
1233, 23.8648415, 0., 4.72995663
1234, 13.0846395, 0., -9.71652317
1235, -40.4526443, 0., -3.54460907
1236, 16.5257053, 0., -5.86886215
1237, 18.7118092, 0., -9.79200459
1238, -40.3183136, 0., -5.17833662
1239, 32.2547531, 0., 9.9821434
1240, 8.11289024, 0., 9.47111702
1241, 11.6656818, 0., 38.8709183
1242, -4.20164824, 0., -6.32536125
1243, -2.04611993, 0., -8.07799911
1244, 16.8155041, 0., -9.74757767
1245, -6.45497131, 0., -0.341163903
1246, -6.03129339, 0., -4.56584454
1247, -4.78892136, 0., 6.05195093
1248, 26.8383274, 0., 28.1526794
1249, 29.962038, 0., 25.0277882
1250, -24.219696, 0., 31.299036
1251, -38.5467377, 0., -11.1820507
1252, -11.5142517, 0., -38.8692245
1253, 24.2556992, 0., -30.4918556
1254, 35.477684, 0., -20.9254456
1255, -31.6106167, 0., -24.8169765
1256, 29.7768002, 0., -26.7563992
1257, 39.3427048, 0., -8.56762505
1258, 6.07359314, 0., -9.96755695
1259, 18.065443, 0., 36.351593
1260, 36.7299347, 0., -19.0528316
1261, 5.97029495, 0., 9.61240292
1262, 2.35193419, 0., 39.1134491
1263, 4.02772713, 0., 42.4082146
1264, -2.51027775, 0., 40.7795563
1265, 28.102314, 0., 27.2163849
1266, -27.4478703, 0., 29.8088665
1267, 38.6441765, 0., 14.0488844
1268, 33.0481071, 0., 23.0687313
1269, 37.3367424, 0., 15.1556616
1270, -15.6031723, 0., 34.5651093
1271, -14.022501, 0., -36.6475906
1272, 10.4297066, 0., -38.0003624
1273, -21.4119377, 0., -34.4642029
1274, -8.10546398, 0., -39.3589172
1275, -30.3852043, 0., 26.951601
1276, 26.3166885, 0., -7.75738716
1277, 24.7462635, 0., 8.89905453
1278, -6.0867672, 0., -6.48198509
1279, -7.46783733, 0., 40.1959
1280, 28.3127174, 0., -9.56293774
1281, 17.8328896, 0., 11.3297825
1282, -7.0599165, 0., 6.33680058
1283, 30.3836479, 0., 10.0483313
1284, 23.4745426, 0., 11.3565187
1285, 35.0177002, 0., 13.3868847
1286, -35.8730316, 0., 13.805582
1287, -34.0618744, 0., 18.5630035
1288, 25.7593155, 0., 26.6509113
1289, 32.0828362, 0., 20.514246
1290, 20.6248608, 0., 34.6939392
1291, -22.4171638, 0., 31.9889793
1292, -14.2381907, 0., 35.9322929
1293, 18.7806797, 0., -11.7422676
1294, 34.6670837, 0., -18.0211353
1295, -24.0340042, 0., -32.4865608
1296, 22.213728, 0., -30.6425743
1297, 17.7130127, 0., -34.6565742
1298, -7.261868, 0., -2.34823108
1299, 24.287962, 0., -5.85266447
1300, -38.5158463, 0., -6.6412878
1301, -38.4300575, 0., 10.2619619
1302, 34.4945908, 0., 11.5825891
1303, 14.4765167, 0., 11.3468275
1304, 15.0608921, 0., -11.5885286
1305, 35.0077095, 0., -10.8578701
1306, 26.2354259, 0., 6.46670628
1307, -38.3838272, 0., 6.34178209
1308, 24.0255814, 0., 32.7710495
1309, -34.4227295, 0., -24.7906265
1310, -31.9073544, 0., -22.2020073
1311, -29.9102707, 0., -26.263237
1312, -0.69644177, 0., 39.1375961
1313, -10.099535, 0., 36.3480225
1314, -18.4695663, 0., 30.4262047
1315, 21.4612255, 0., -33.8836899
1316, -7.79235458, 0., 2.11987114
1317, -9.81217957, 0., -38.9850502
1318, -20.0852623, 0., -35.3959122
1319, 26.2182426, 0., -5.80946922
1320, 24.290308, 0., 6.87522459
1321, -35.2256813, 0., -15.727972
1322, -34.1455421, 0., 24.9049835
1323, -4.25893116, 0., -38.5134773
1324, 11.4021759, 0., 10.8629313
1325, 3.88293982, 0., 38.9297066
1326, 5.36911678, 0., 38.6316986
1327, -29.8198414, 0., 24.1796494
1328, -1.11063075, 0., -39.1649551
1329, 3.52613544, 0., -39.3550835
1330, 26.5021191, 0., -28.0357647
1331, 37.1155472, 0., -13.7681494
1332, 30.1151924, 0., -9.42500496
1333, 3.93834114, 0., 9.70443726
1334, -0.109925479, 0., 9.86787128
1335, -2.15626931, 0., 9.99635029
1336, -38.8223228, 0., -1.75937676
1337, -33.7637482, 0., 15.1959743
1338, 33.0306053, 0., 18.7168179
1339, 22.8342571, 0., 28.6831093
1340, -7.06899691, 0., 38.4366074
1341, -34.3587914, 0., -12.1024876
1342, -26.666563, 0., -30.4552078
1343, -21.57798, 0., -31.9292641
1344, 7.75614357, 0., -9.85293961
1345, 9.69372177, 0., -11.6803875
1346, -30.840086, 0., -18.4652901
1347, 20.2902851, 0., -34.9144859
1348, -15.3138094, 0., -36.1168709
1349, 7.75982141, 0., -38.9878464
1350, 22.5507507, 0., -9.81000328
1351, 14.0296154, 0., 36.4220467
1352, 16.5834503, 0., 39.0052986
1353, 11.2658644, 0., 37.1217918
1354, 14.1778755, 0., -35.6866608
1355, 31.7599163, 0., -9.30147171
1356, -38.8574715, 0., 1.41025686
1357, 28.5673008, 0., 10.1624947
1358, 19.747015, 0., 11.0262136
1359, 20.6218681, 0., -9.81114769
1360, -38.6120033, 0., -3.41213965
1361, 5.99799871, 0., 11.6225519
1362, -1.62325621, 0., -10.5420885
1363, -7.96638441, 0., -6.49449062
1364, 28.2328873, 0., 25.4605942
1365, 29.130146, 0., 23.017004
1366, -36.3531647, 0., -10.0903864
1367, 4.42781353, 0., -10.1780386
1368, -4.1475234, 0., 40.6243019
1369, 33.4476776, 0., 13.8356571
1370, -13.0924683, 0., 34.2870636
1371, 11.9186916, 0., -35.579464
1372, 9.70653439, 0., -40.0470886
1373, -27.7093372, 0., 27.3197289
1374, -36.8813629, 0., -7.09363079
1375, -6.0572772, 0., -8.48454762
1376, 30.4233837, 0., 11.9469147
1377, 25.1293259, 0., 10.8167439
1378, 2.03125858, 0., 11.7867975
1379, -36.4379234, 0., 11.6141405
1380, -30.9053421, 0., 22.6494465
1381, -21.8563156, 0., 30.0257568
1382, -3.95629001, 0., -10.4258938
1383, 26.416605, 0., -9.66403484
1384, 24.482645, 0., -9.74860477
1385, 30.3369236, 0., -11.1544991
1386, -6.81434155, 0., 8.48296928
1387, -8.44348812, 0., 0.0480390266
1388, -37.1819153, 0., -0.172179133
1389, 26.8176842, 0., 10.4174337
1390, -1.93995619, 0., 12.0270939
1391, 12.6853704, 0., 36.7446442
1392, 17.0765381, 0., 36.85495
1393, 30.8878765, 0., 17.8636723
1394, 23.2967625, 0., 26.0750408
1395, -8.35446167, 0., 36.5030899
1396, 15.1075563, 0., -13.3693676
1397, -34.1149445, 0., -10.3981781
1398, -30.9330635, 0., -16.4981384
1399, -30.8599606, 0., -20.82967
1400, -17.8736343, 0., -34.7422295
1401, 6.37939119, 0., -11.7183552
1402, 22.98592, 0., -29.2814503
1403, -30.398634, 0., -23.2669487
1404, 39.4464417, 0., -13.6843948
1405, -37.0439873, 0., 1.3036238
1406, -2.65279531, 0., -38.8999252
1407, 12.9574604, 0., 11.1892767
1408, 0.434998512, 0., -39.3362007
1409, 4.98720407, 0., -39.3253593
1410, -32.7072639, 0., 17.7214031
1411, 22.5811577, 0., 31.3990421
1412, -33.70718, 0., -15.0562477
1413, -25.3703003, 0., -31.4413357
1414, 18.8919735, 0., -33.6414413
1415, -0.151992932, 0., -7.54710913
1416, -13.0904417, 0., -38.6444168
1417, 0.977204323, 0., 37.5099678
1418, -2.24500608, 0., 39.0251236
1419, 29.1878643, 0., 26.2396564
1420, -13.3013716, 0., -35.2005844
1421, -9.34044361, 0., 6.51968718
1422, 21.7978268, 0., 12.0430326
1423, 19.3347588, 0., 33.6028328
1424, -20.1887131, 0., 30.3029423
1425, -11.9604435, 0., 36.2042694
1426, 18.7787876, 0., -13.7091713
1427, 31.9283905, 0., -19.3093929
1428, 20.0931721, 0., -30.5252991
1429, -9.1445179, 0., -2.06541753
1430, 14.3491144, 0., 12.9787865
1431, 35.3131256, 0., -13.0911732
1432, -36.7045746, 0., 6.05741262
1433, -40.0740967, 0., 8.1601944
1434, -27.6065769, 0., -26.5279408
1435, -16.8827457, 0., 31.9453144
1436, -9.88205433, 0., 2.37491226
1437, -9.56340599, 0., -36.5948982
1438, 5.16018105, 0., 36.8728905
1439, -28.1818104, 0., 23.0305691
1440, 24.7780685, 0., -27.7566128
1441, -4.22246742, 0., 10.2046232
1442, -32.079319, 0., 15.4697742
1443, 32.7824936, 0., 15.4570723
1444, -6.66857195, 0., 36.6919785
1445, -19.2829914, 0., -31.6620598
1446, -22.9160786, 0., -30.995224
1447, 9.88312912, 0., -13.5918083
1448, 7.26996374, 0., -35.875946
1449, 15.321888, 0., 36.0695686
1450, 16.594553, 0., -35.7031631
1451, 12.8474016, 0., -34.5741119
1452, 22.6398411, 0., -11.7824678
1453, -36.8490143, 0., -3.1927259
1454, 6.08907175, 0., 13.5790062
1455, -0.133693278, 0., -12.3725929
1456, -9.87726498, 0., -6.48598337
1457, 27.7198486, 0., 22.376915
1458, 28.3491154, 0., 21.1392651
1459, -35.2890396, 0., -7.95849562
1460, 2.21708965, 0., -8.88140869
1461, -26.1007748, 0., 26.3536034
1462, 31.4864712, 0., 13.9368238
1463, -14.1751976, 0., 33.3910408
1464, 8.10856152, 0., -34.6627617
1465, -27.1363602, 0., 24.6877232
1466, 8.10795021, 0., 13.4031
1467, -25.5337181, 0., 23.5983047
1468, 35.5609932, 0., -15.8978214
1469, -36.5514297, 0., 7.40032005
1470, -10.4498167, 0., 0.341495126
1471, -11.5777454, 0., 4.4606638
1472, -35.2081146, 0., 1.05460584
1473, -8.34066772, 0., 11.1327753
1474, 29.885828, 0., 15.7881584
1475, 30.1686859, 0., 13.7562971
1476, -30.7955074, 0., 17.9362698
1477, -30.6971455, 0., 20.0785275
1478, -26.5939999, 0., 22.004879
1479, 21.7451897, 0., 27.0868568
1480, 25.2143059, 0., 22.4247074
1481, 26.7703133, 0., 21.1320839
1482, -18.0807533, 0., 28.6643982
1483, -13.5326185, 0., 31.0474892
1484, -21.3910732, 0., 28.1077614
1485, 3.59976816, 0., 36.0976067
1486, -15.1615105, 0., 30.5286236
1487, 1.19523692, 0., 35.9127617
1488, -6.26455116, 0., 34.9259148
1489, -9.72733784, 0., 34.6801071
1490, -9.9888401, 0., -8.6384325
1491, -28.3756638, 0., -18.540205
1492, -18.3020458, 0., -29.8498459
1493, -12.7549963, 0., -37.1327553
1494, -26.8227882, 0., -24.7210445
1495, 2.13258266, 0., -12.5673866
1496, 6.50085402, 0., -13.4398813
1497, 33.5098534, 0., -14.6608152
1498, -32.288784, 0., -14.2653208
1499, 31.2870502, 0., -21.3018169
1500, -27.7229633, 0., -28.2982559
1501, -23.0057755, 0., -28.7323475
1502, 21.1451645, 0., -28.7696819
1503, -16.9654369, 0., -33.3682518
1504, 18.8234406, 0., -31.3587418
1505, 4.52554798, 0., -35.9592628
1506, -8.05365372, 0., -10.6259031
1507, 16.4259262, 0., 14.1872816
1508, 13.3629274, 0., -13.302598
1509, -29.4342632, 0., -21.7419605
1510, -5.18105412, 0., -36.353138
1511, 10.3658609, 0., 12.8737993
1512, -1.65331078, 0., -35.8645172
1513, 2.01059151, 0., -36.4844017
1514, 26.5719242, 0., -26.2202797
1515, 37.9481506, 0., -15.3480883
1516, 10.9088688, 0., 35.4107437
1517, 15.1932335, 0., -34.5376282
1518, 27.0643826, 0., 12.2147398
1519, -35.4850082, 0., -0.437547147
1520, -2.4453187, 0., -12.4149637
1521, -5.42871428, 0., 38.6587982
1522, 10.6110306, 0., -34.6759605
1523, -6.02206373, 0., -10.5233555
1524, 18.2614002, 0., 13.4352236
1525, 2.14386916, 0., 13.7704077
1526, 26.5442429, 0., -11.5140915
1527, 30.7088776, 0., -12.9312382
1528, -1.72353864, 0., 14.0192137
1529, 13.7712498, 0., 34.8431587
1530, 23.7110672, 0., 23.454277
1531, 16.7293072, 0., -15.3495064
1532, -32.1809845, 0., -10.8399477
1533, 19.6487808, 0., 30.8212566
1534, -1.58548176, 0., 35.5710793
1535, -14.8422718, 0., -32.7565956
1536, -11.831892, 0., 8.17789745
1537, 22.2050667, 0., 13.7898703
1538, 20.7211952, 0., -13.8123598
1539, 30.8057461, 0., -16.7657585
1540, 19.3712788, 0., -29.1033649
1541, -9.68523407, 0., -4.28366089
1542, 12.4409657, 0., 14.9534044
1543, -34.9616585, 0., 4.3946743
1544, -8.19590569, 0., -34.6819
1545, 6.58544302, 0., 36.5212326
1546, -5.86482859, 0., 12.5625877
1547, 8.14936733, 0., -13.6597013
1548, 18.1643581, 0., 34.8477898
1549, 22.7427692, 0., -13.7914772
1550, -36.2667923, 0., -5.10441065
1551, 4.10536528, 0., 13.6780205
1552, -34.5366325, 0., -6.26423502
1553, 1.26572168, 0., -11.2356157
1554, -23.4779625, 0., 26.8628712
1555, 10.3721542, 0., 15.0704956
1556, 1.49711263, 0., 34.4953728
1557, 0.204162434, 0., 13.8689623
1558, -4.62582684, 0., 35.1261177
1559, -24.0196533, 0., 22.4234772
1560, 1.65888178, 0., -35.3270149
1561, -34.9342651, 0., 6.081182
1562, -11.5199366, 0., 6.338974
1563, -30.2059841, 0., 15.4429207
1564, -29.6868134, 0., 18.7254944
1565, 17.9728603, 0., 31.7927628
1566, 26.754612, 0., 17.4293003
1567, 27.2980938, 0., 19.1035595
1568, 24.0612564, 0., 20.8156929
1569, 18.5081024, 0., 28.9973755
1570, -11.8712749, 0., 30.8042908
1571, 22.966692, 0., -26.1533089
1572, -11.777524, 0., -6.5955224
1573, -31.5639229, 0., -9.11820889
1574, -10.9158697, 0., -34.7893753
1575, -2.97854519, 0., -35.4356613
1576, -25.9829941, 0., -26.889246
1577, -30.3906307, 0., -11.5442944
1578, 22.8407173, 0., -15.8252563
1579, 30.9633675, 0., -14.8121939
1580, 29.8843498, 0., -18.7429409
1581, -19.864151, 0., -28.1983624
1582, -35.6959534, 0., 9.49776649
1583, 28.2562771, 0., -26.5177498
1584, -29.2379227, 0., -30.5712662
1585, 24.5935059, 0., -11.671154
1586, -6.33436871, 0., 10.5547657
1587, -11.1432209, 0., -1.78825057
1588, -35.0591316, 0., 2.70245647
1589, 15.0123425, 0., -15.017293
1590, 5.1159606, 0., -14.4829168
1591, 18.6504078, 0., -15.7030067
1592, 14.4664497, 0., 14.7064352
1593, -12.4315481, 0., 0.65030843
1594, 4.61608267, 0., 34.9442749
1595, -33.419899, 0., 0.692784011
1596, 6.1924243, 0., 15.5196056
1597, -10.0562735, 0., 12.1427727
1598, 28.7487545, 0., 14.9852676
1599, -27.5356998, 0., 20.5340252
1600, 20.1527863, 0., 28.019289
1601, -17.5524845, 0., 27.0041523
1602, -19.263998, 0., 26.4530506
1603, -14.2683163, 0., 27.6404572
1604, 0.209327951, 0., 34.2012749
1605, -7.6199708, 0., 32.9603615
1606, -27.1846809, 0., -17.790163
1607, -27.8309956, 0., -22.2877331
1608, 3.75548649, 0., -13.5255623
1609, -21.6255951, 0., -28.2169075
1610, 21.151104, 0., -26.9460373
1611, -17.2897797, 0., -31.428978
1612, 17.7372742, 0., -29.934557
1613, -5.99599123, 0., -12.5857754
1614, 18.6604328, 0., 15.3928432
1615, 11.6206245, 0., -13.3980551
1616, -0.281769425, 0., -36.0524712
1617, 26.6817474, 0., -24.2836971
1618, 38.8270493, 0., -18.8331871
1619, 8.94526672, 0., 33.6679916
1620, 14.760376, 0., -32.1499672
1621, -35.2269096, 0., -2.53559184
1622, -1.44156504, 0., -14.2784605
1623, 11.5431585, 0., -32.3345947
1624, 20.4866657, 0., 14.5541744
1625, 26.6978912, 0., -13.2430477
1626, 28.648428, 0., -13.1740255
1627, -3.37660933, 0., 16.1795044
1628, 14.0436506, 0., 33.2336845
1629, 24.2799969, 0., 14.8147974
1630, -6.69660234, 0., -35.6234055
1631, -5.52201128, 0., 14.5523376
1632, 10.1830683, 0., -15.4511118
1633, -32.7911606, 0., -6.80682564
1634, 5.99390125, 0., -33.4901962
1635, -30.9271317, 0., -7.234622
1636, -5.62773705, 0., -34.0807114
1637, -7.97650623, 0., -14.7680216
1638, 6.84872293, 0., 32.5334435
1639, -5.22416639, 0., 16.5020599
1640, -2.08661795, 0., -34.0796585
1641, -3.79369307, 0., -14.5822277
1642, -13.1106853, 0., -1.30675066
1643, -33.6795273, 0., -1.33513772
1644, -11.1751585, 0., 10.8268337
1645, 27.29673, 0., 13.8813066
1646, 22.6701031, 0., 15.464221
1647, 17.9098701, 0., 27.4868584
1648, 21.1885414, 0., 23.2461548
1649, -29.6788254, 0., -9.77429485
1650, -27.2268257, 0., -16.4061985
1651, -15.351573, 0., -30.8067036
1652, -26.0534477, 0., -22.8484192
1653, -22.2204399, 0., -25.2139435
1654, 25.2810955, 0., -15.7362432
1655, 2.63997221, 0., -15.4185715
1656, -27.1867809, 0., -20.184309
1657, 14.9612818, 0., -29.6376495
1658, 18.7421265, 0., -27.4666481
1659, -10.8832541, 0., -32.0442696
1660, 4.58310127, 0., -31.4957199
1661, -33.5564346, 0., 9.90004063
1662, 23.0460644, 0., -27.6297989
1663, -11.9212723, 0., 2.56699276
1664, -31.8871765, 0., 13.7230577
1665, 6.26645088, 0., 17.5202084
1666, -22.6579075, 0., 21.1453915
1667, -33.2728729, 0., 2.51760244
1668, -11.0378609, 0., 29.4697113
1669, -11.1281052, 0., 33.1004982
1670, -17.1826725, 0., -26.2459641
1671, 30.8004646, 0., -23.3787575
1672, -23.7878857, 0., -27.3701515
1673, 26.2421112, 0., 15.9043303
1674, 2.24185848, 0., 15.7438269
1675, -1.51322961, 0., 15.9627628
1676, -1.13317859, 0., 33.8653908
1677, -13.4971972, 0., 6.11730528
1678, 9.45116615, 0., 35.7523689
1679, -22.7765732, 0., 24.0412388
1680, 10.4150305, 0., 17.1331673
1681, 1.7362498, 0., 33.3318443
1682, -3.06915045, 0., 35.3463211
1683, 2.42949748, 0., -32.8532257
1684, -33.0952797, 0., 6.16298532
1685, -28.3193455, 0., 15.2797737
1686, -27.4650822, 0., 18.1216602
1687, 23.7937012, 0., 18.5346985
1688, 24.4647732, 0., 19.477787
1689, 22.5873566, 0., -24.3858299
1690, -13.6157494, 0., -6.83289862
1691, -29.4862919, 0., -14.4080048
1692, -10.0568113, 0., -10.7322569
1693, -10.0752535, 0., -12.8150396
1694, 22.8596325, 0., -17.8279686
1695, 28.0465736, 0., -18.8355236
1696, -19.7712288, 0., -26.4654865
1697, -13.9366674, 0., -3.17520189
1698, 13.5165052, 0., -16.0725136
1699, 6.56789875, 0., -17.5581341
1700, 18.2910614, 0., -17.7240772
1701, 14.6163788, 0., 16.6544704
1702, 4.63363314, 0., 32.8125076
1703, -26.2490082, 0., 19.3803425
1704, 18.956852, 0., 26.1283436
1705, -15.8697691, 0., 27.4022636
1706, -18.3121777, 0., 24.650177
1707, -12.6736698, 0., 27.8696957
1708, -7.26126814, 0., 31.1376095
1709, -5.3994441, 0., 31.3185101
1710, 0.742823482, 0., -15.1616955
1711, 13.2486219, 0., -30.864603
1712, 19.2584305, 0., 17.2009487
1713, 28.9411049, 0., -22.7915115
1714, 24.6877422, 0., -24.1052971
1715, 11.9717731, 0., 32.8383636
1716, -32.9250603, 0., -3.25033569
1717, 8.04682159, 0., -31.8386021
1718, 9.27664566, 0., -17.7799892
1719, 2.29281902, 0., 17.7566967
1720, -32.4474678, 0., -5.02968645
1721, -12.4908609, 0., 12.2466135
1722, 5.94840622, 0., 30.7072067
1723, 8.40436935, 0., 19.3771973
1724, 4.23593569, 0., 17.6691399
1725, -6.71866465, 0., 29.3436108
1726, -7.37100649, 0., 14.95084
1727, -26.414608, 0., 16.6300488
1728, -0.910328686, 0., -32.6025581
1729, 26.9789448, 0., -22.3622513
1730, 22.1967068, 0., -22.4503613
1731, -31.1840038, 0., 8.17239189
1732, -15.5290689, 0., 4.58950663
1733, -15.0648584, 0., -0.84692955
1734, -31.3391266, 0., 4.22165203
1735, -31.6544609, 0., 0.520868838
1736, 23.1971588, 0., 17.0642586
1737, 19.6960602, 0., 22.446455
1738, 12.9359951, 0., 30.7464008
1739, -9.85767555, 0., 28.2292595
1740, -3.68174481, 0., 31.5179863
1741, -5.89841413, 0., -14.6829472
1742, -13.8784781, 0., -8.78753757
1743, -5.60111952, 0., -31.8091183
1744, -25.9712315, 0., -18.4338112
1745, 17.7884655, 0., -25.5562019
1746, 27.1930008, 0., -16.750246
1747, -27.0740299, 0., -14.5857573
1748, -10.041687, 0., -14.8965807
1749, -1.60083163, 0., -16.8369007
1750, 27.5849876, 0., -20.5291348
1751, 1.17520678, 0., -31.2597008
1752, 6.67565155, 0., -30.0491276
1753, 10.1675444, 0., 39.3014603
1754, -33.8589668, 0., 13.5631533
1755, -14.415081, 0., 0.9668805
1756, 25.4693527, 0., 12.6059065
1757, -13.6344481, 0., -31.5479584
1758, -21.3604355, 0., 22.5701981
1759, -9.42170525, 0., 30.8551044
1760, -31.1484947, 0., -13.0897932
1761, -6.7387476, 0., -30.5668507
1762, -31.5700836, 0., 2.34724665
1763, -15.3734121, 0., 25.9701538
1764, -2.57564449, 0., -32.6029282
1765, 10.0488596, 0., 31.815527
1766, 10.0724745, 0., -30.6453056
1767, 26.8653488, 0., -14.6366396
1768, -28.3471832, 0., -6.21161604
1769, -4.91160679, 0., 18.3797913
1770, -31.6911182, 0., -1.22460556
1771, -13.9054794, 0., 11.3163996
1772, 16.3320351, 0., 27.3076477
1773, -27.951685, 0., -10.528614
1774, -24.1747189, 0., -23.3772297
1775, 3.20562243, 0., -17.6485786
1776, 13.8286724, 0., -28.3027325
1777, 15.6951818, 0., -27.0995655
1778, -31.3783112, 0., 10.1508608
1779, -33.8588638, 0., 11.7498589
1780, -23.7900677, 0., 19.6421852
1781, -14.7986917, 0., -29.5328369
1782, -19.4530678, 0., -22.1424599
1783, -1.32373428, 0., 17.8532505
1784, -15.1725559, 0., 7.24150991
1785, 12.5458965, 0., 18.9672756
1786, 0.208254248, 0., 30.4032745
1787, 4.25853872, 0., 31.0034008
1788, -26.9015942, 0., 13.1821699
1789, 22.5354786, 0., 19.614151
1790, 20.0913773, 0., -23.0352116
1791, -14.8493137, 0., -4.8281517
1792, -12.0627098, 0., -10.8217335
1793, 20.5721817, 0., -18.2537422
1794, 24.6612587, 0., -19.1804619
1795, 11.662281, 0., -18.7635822
1796, 17.1212215, 0., -18.8336906
1797, 5.33470535, 0., -19.0303402
1798, 7.95682955, 0., -18.7625141
1799, 17.1506138, 0., 18.6043282
1800, -18.7480659, 0., 22.0690346
1801, 0.45510751, 0., 17.7979469
1802, -31.2835464, 0., -2.81724477
1803, -26.240591, 0., -3.40451813
1804, -29.1861343, 0., 10.428236
1805, 10.4824133, 0., 19.1869202
1806, 2.14617348, 0., 31.1552868
1807, -2.8809166, 0., 19.8168526
1808, -24.9856644, 0., 18.1259003
1809, -11.3432026, 0., 13.6723776
1810, -1.75917161, 0., -30.9232025
1811, 0.386085302, 0., -19.3650818
1812, -31.1105938, 0., 6.16489458
1813, -15.3308105, 0., 6.06917524
1814, -25.1200676, 0., 15.2307835
1815, 6.3178792, 0., 19.5564289
1816, -12.4847822, 0., 26.5495625
1817, -6.27914572, 0., 27.6364918
1818, -14.1117029, 0., -10.8756046
1819, -12.1351643, 0., -15.0461283
1820, -15.4308939, 0., -6.69711065
1821, -26.5916615, 0., -8.74171352
1822, -26.7525845, 0., -11.2836676
1823, -14.8862352, 0., -25.1963902
1824, -23.5697365, 0., -21.4536724
1825, 14.3775215, 0., -25.8451633
1826, 13.6483145, 0., -18.2038746
1827, 16.4876957, 0., -23.3640881
1828, 23.8644447, 0., 13.1359406
1829, -7.73720598, 0., 13.0322723
1830, -4.21591949, 0., -30.7649136
1831, 9.94815731, 0., 27.4617462
1832, -1.7461679, 0., -19.0313206
1833, 19.0638771, 0., 24.1081047
1834, -22.2462063, 0., -23.5787392
1835, -10.6961288, 0., -29.5844574
1836, -2.60590005, 0., 33.5754471
1837, 23.3469353, 0., -19.8149738
1838, -15.8065615, 0., -2.64879131
1839, 7.00017023, 0., -20.0311527
1840, 18.9989052, 0., -19.4391327
1841, 14.694499, 0., 18.7274628
1842, -1.48791349, 0., 29.9297905
1843, 20.1951885, 0., 18.643259
1844, 18.9065666, 0., 19.966795
1845, -29.9555264, 0., 0.414503247
1846, 10.1186514, 0., -19.209425
1847, 2.23982501, 0., 19.8793354
1848, 6.47545671, 0., 26.9986897
1849, -9.21907043, 0., 15.3629789
1850, -16.3632698, 0., 1.29113317
1851, -30.02635, 0., 2.16535687
1852, 13.7948313, 0., 28.7908497
1853, -7.80250263, 0., 27.4119778
1854, -11.1101971, 0., 27.8281784
1855, -5.84126282, 0., -18.8232155
1856, -24.3709507, 0., -19.055151
1857, 26.4881096, 0., -18.2690353
1858, -24.6424694, 0., -14.6974459
1859, -9.96286964, 0., -16.9491863
1860, 1.51008213, 0., -28.3140583
1861, 5.25695705, 0., -27.801897
1862, -20.1813717, 0., 21.0949078
1863, -15.2008944, 0., 22.9087009
1864, 10.8844328, 0., -27.9940777
1865, -6.74520445, 0., 18.836256
1866, -29.8154411, 0., -1.62392104
1867, -15.006218, 0., 12.7866564
1868, 2.56028819, 0., -19.8963737
1869, 12.7056704, 0., -26.9488087
1870, -14.2952623, 0., -26.3878345
1871, -20.5129967, 0., -22.1313419
1872, -14.5100737, 0., 9.06871033
1873, -26.9800873, 0., 10.6463718
1874, 18.0367088, 0., -23.3903446
1875, -16.3873959, 0., 21.0599499
1876, -28.7741184, 0., -3.50859213
1877, -25.6263733, 0., -5.92931128
1878, -7.85496473, 0., -18.8653793
1879, 8.21845531, 0., 27.0641022
1880, -8.67533398, 0., 19.3669415
1881, -17.6802883, 0., -2.21618342
1882, -26.5942688, 0., 1.77260971
1883, -16.7231064, 0., 9.67041206
1884, 14.3504343, 0., 26.7153187
1885, 4.74259424, 0., 27.5381393
1886, -2.68046761, 0., 27.5576096
1887, -25.4107685, 0., -10.5953074
1888, -23.6511135, 0., -17.3277779
1889, -22.7216511, 0., -19.5760231
1890, -1.92994452, 0., -21.0744362
1891, -9.98694515, 0., -28.2719364
1892, 2.85958052, 0., -26.5647888
1893, -18.9402275, 0., -23.0151253
1894, 17.4235802, 0., 23.6008453
1895, 6.36497831, 0., 21.571701
1896, -15.8756466, 0., 2.97461867
1897, -16.9814472, 0., -0.442775965
1898, -28.0621471, 0., 3.09063482
1899, -2.07031989, 0., 31.7774086
1900, -5.1912837, 0., -29.6567135
1901, -3.95332742, 0., -29.0810223
1902, -4.5483489, 0., 20.1705914
1903, -1.20885217, 0., 19.6695175
1904, 10.562129, 0., 21.2999077
1905, -23.5395508, 0., 14.1046171
1906, 17.7170963, 0., -21.6306419
1907, 6.41632938, 0., -21.5061207
1908, -27.5513687, 0., -1.0228976
1909, -27.1134815, 0., 8.54963017
1910, 2.9758656, 0., 27.3649883
1911, -23.618536, 0., 16.8727055
1912, -13.3707581, 0., 14.4806089
1913, -1.75102091, 0., -28.2278709
1914, 2.09530377, 0., -21.9396915
1915, -28.8436623, 0., 5.99771547
1916, -17.0452805, 0., 6.43202066
1917, -20.3900757, 0., 18.9676266
1918, -12.171648, 0., 24.3779202
1919, -4.5639987, 0., 27.6055107
1920, -16.2571201, 0., -10.8492203
1921, -17.1814327, 0., -6.36800957
1922, -15.2906141, 0., -23.657505
1923, 14.5204315, 0., -23.5514832
1924, 13.7310743, 0., -21.653368
1925, 15.6490622, 0., -22.0282784
1926, 11.7830324, 0., 28.0422249
1927, -3.80520535, 0., -18.868969
1928, 14.4982605, 0., 20.8187828
1929, 10.4734039, 0., -20.4927883
1930, 2.13600373, 0., 22.0960369
1931, -11.0615749, 0., 15.6791945
1932, -7.39105844, 0., 26.2678814
1933, -11.865202, 0., -19.1583786
1934, 0.00650706049, 0., -27.095356
1935, 7.73168421, 0., -25.3522625
1936, -19.2389317, 0., 19.6036243
1937, -13.6329031, 0., 23.4896908
1938, 11.5973587, 0., -25.5408554
1939, -18.8566666, 0., -21.1486435
1940, -24.6742592, 0., 10.4842548
1941, -14.6949635, 0., 21.3747768
1942, -2.59040308, 0., 21.51721
1943, -25.5680656, 0., -1.85002327
1944, -22.6804333, 0., 9.87905407
1945, 6.43920326, 0., 25.3421555
1946, 8.47976494, 0., 23.4217796
1947, 2.91894245, 0., 25.8773651
1948, 4.40566969, 0., 23.7417278
1949, -0.0871217325, 0., 22.3191357
1950, -23.4262257, 0., 11.7725477
1951, -17.1886539, 0., 18.8843002
1952, -15.7242699, 0., 14.7649441
1953, -0.236895636, 0., -23.277153
1954, -18.90481, 0., 6.70420456
1955, -18.8680134, 0., -0.0234621037
1956, -24.8959522, 0., -0.279455632
1957, -18.4585648, 0., 10.4982481
1958, -14.7974234, 0., 16.5749969
1959, -22.0863953, 0., 15.6139736
1960, 10.3650331, 0., 25.5418377
1961, -6.72040653, 0., 24.5815849
1962, -17.7468376, 0., -8.38794613
1963, -14.239316, 0., -13.0140142
1964, -5.87355757, 0., -20.856123
1965, -5.77273846, 0., -28.2339497
1966, -18.2653255, 0., -22.1171494
1967, -23.0278912, 0., -11.9530973
1968, -18.542923, 0., -13.0756111
1969, 5.61833525, 0., -25.2458954
1970, 13.5438995, 0., -22.8023071
1971, -12.3497124, 0., -26.5959034
1972, -25.8327255, 0., 3.43291235
1973, -10.8169041, 0., 17.6678829
1974, -17.7488327, 0., 3.24452519
1975, -10.8475008, 0., 25.8162613
1976, -9.85747147, 0., -18.9722404
1977, 1.03455937, 0., -25.5731773
1978, 9.3774786, 0., -25.3017883
1979, -10.6626253, 0., 19.8043938
1980, -22.896492, 0., -5.13853168
1981, -18.3731823, 0., -4.05099249
1982, -27.228817, 0., 4.50525093
1983, -14.1904678, 0., -17.3741035
1984, -2.1266892, 0., -22.9684143
1985, -7.91635084, 0., -26.7164307
1986, 15.7975626, 0., 23.0226765
1987, -6.31728935, 0., 20.6753979
1988, 12.9316616, 0., 23.568449
1989, 4.05453873, 0., -22.6176548
1990, 8.21592331, 0., -22.0037136
1991, -26.8138294, 0., 6.98083305
1992, 1.61186302, 0., 26.7427959
1993, -2.23766208, 0., -26.4101868
1994, -18.6751881, 0., 8.42205238
1995, -2.44517994, 0., 25.0636787
1996, -0.928551435, 0., -26.1422615
1997, -10.6125021, 0., 22.2884636
1998, 12.2374392, 0., -23.274498
1999, -19.3491669, 0., -20.0430107
2000, -14.3146524, 0., 19.7805653
2001, -3.53639793, 0., 23.4842854
2002, -23.8230114, 0., -2.539819
2003, -22.0801659, 0., -3.14586496
2004, 10.6149044, 0., 23.4589214
2005, -26.0068455, 0., 5.61214209
2006, -17.7177486, 0., 13.576479
2007, -15.4658365, 0., 18.3940735
2008, 6.41721582, 0., 23.507309
2009, 2.35973072, 0., 24.1993427
2010, -9.29246521, 0., 24.0832195
2011, -18.639658, 0., -15.2651262
2012, -19.0021248, 0., -5.9853816
2013, -9.94768906, 0., -26.6029301
2014, -21.513979, 0., -7.65049696
2015, -18.637661, 0., -10.6834707
2016, -13.8642874, 0., -19.4505844
2017, 5.99059772, 0., -23.2307873
2018, 1.63600361, 0., -23.851387
2019, -2.28030777, 0., -24.7081051
2020, -18.2550354, 0., 1.6390543
2021, -13.0933695, 0., -24.7992897
2022, -24.5012379, 0., 1.40528369
2023, -12.5558367, 0., 19.8556957
2024, -19.5433064, 0., -1.78349948
2025, -19.4762135, 0., 12.4517698
2026, -21.4893875, 0., -9.64299965
2027, -14.2744675, 0., -15.2107706
2028, 18.0635033, 0., 21.7111893
2029, -4.00414181, 0., -26.4438362
2030, -22.5993919, 0., 1.01194274
2031, -22.4093914, 0., 18.4078178
2032, -17.1560326, 0., -22.1604805
2033, -9.76257515, 0., -20.9613686
2034, -17.891098, 0., 20.4047565
2035, -2.09582806, 0., 23.0710945
2036, -22.4702053, 0., 11.0507088
2037, -18.5757599, 0., 18.0080013
2038, -24.1030674, 0., 3.04582667
2039, -19.071207, 0., 15.3099365
2040, -16.4566784, 0., -15.3277521
2041, -5.92160273, 0., -22.8315659
2042, -20.6875801, 0., -15.2446356
2043, -5.94362164, 0., -26.5674038
2044, -23.4958649, 0., -9.92066193
2045, -19.4568672, 0., 3.54474378
2046, -19.0579281, 0., -18.4047356
2047, -4.01660013, 0., -22.8467941
2048, -5.12249422, 0., 24.0489025
2049, -20.8152809, 0., 6.74962044
2050, -20.960537, 0., -5.61631346
2051, -7.83119106, 0., -22.8550758
2052, -22.6773033, 0., 6.60570097
2053, -17.4482155, 0., 16.3873119
2054, -15.7611809, 0., -19.9002953
2055, -5.96079111, 0., -24.7401314
2056, -13.3431959, 0., -23.2042809
2057, -9.78450871, 0., -24.8109837
2058, -21.3767147, 0., -1.29824615
2059, -7.51661587, 0., 23.0490475
2060, -22.0341549, 0., 2.92916489
2061, -20.738842, 0., 10.0514822
2062, -14.2659836, 0., 18.1552868
2063, -18.0660496, 0., -19.2063141
2064, -24.4472809, 0., 6.31120348
2065, -22.80933, 0., 8.27596283
2066, -18.909771, 0., -17.1305923
2067, -15.4380093, 0., -21.8581104
2068, -20.7321415, 0., 0.465328962
2069, -22.4525032, 0., 4.88538027
2070, -11.5687237, 0., -22.9736118
2071, -20.0927753, 0., 2.08246398
2072, -20.7662792, 0., 3.91614771
2073, -40.1265488, 0., 26.3926907
2074, -42.1608696, 0., -23.0475101
2075, 47.8814545, 0., -1.98878217
2076, 9.64346695, 0., 3.65339708
2077, -3.45035958, 0., -2.24924397
2078, -40.4150543, 0., 22.1222153
2079, 26.294136, 0., 37.9030075
2080, -38.5709496, 0., -25.426672
2081, 35.8204765, 0., 29.0146046
2082, 44.9094772, 0., -11.8566732
2083, 44.8280487, 0., -13.557869
2084, 28.0908966, 0., -3.84681296
2085, 41.0515289, 0., 21.1768627
2086, -30.3503685, 0., 34.9017029
2087, 42.1387367, 0., -19.7560921
2088, -3.15219808, 0., 46.1875954
2089, 24.4238071, 0., -38.993824
2090, 5.89528036, 0., -45.9180336
2091, 16.5548801, 0., 6.14554071
2092, 34.0986633, 0., -28.7245007
2093, 33.1544724, 0., 29.3040848
2094, 35.3046188, 0., -27.4936047
2095, -41.0177498, 0., -16.1612206
2096, 24.4040699, 0., -36.4389954
2097, -32.7348938, 0., 30.4237175
2098, 38.6359062, 0., 21.9231777
2099, -44.3528709, 0., 3.07887626
2100, -43.6070366, 0., 9.8993988
2101, -42.6380081, 0., 13.1319971
2102, -27.7318802, 0., 34.0520744
2103, 43.8021545, 0., 8.74933815
2104, 23.0380669, 0., 9.51617622
2105, 21.3853645, 0., 10.3062496
2106, 14.2353382, 0., 7.65200996
2107, 11.0469666, 0., 7.15992832
2108, 34.2329102, 0., -26.3008175
2109, 31.6384354, 0., -28.5237007
2110, 43.2168465, 0., -13.8429909
2111, -5.67687845, 0., -2.7373848
2112, 40.5623055, 0., -19.1726551
2113, 27.9762325, 0., 31.885746
2114, 43.8878326, 0., 10.3162909
2115, 35.177475, 0., -25.0250607
2116, 44.0069237, 0., 11.7788763
2117, 21.6973248, 0., -36.2187691
2118, 19.6274948, 0., 9.58429527
2119, -32.7438507, 0., -30.0793209
2120, 40.9489784, 0., -8.76357746
2121, 40.445076, 0., -10.3444862
2122, 15.7185202, 0., -41.8002701
2123, -24.175972, 0., 36.0199013
2124, 10.7890482, 0., -43.2890816
2125, -42.5361786, 0., 1.38491952
2126, -41.92313, 0., 9.64875507
2127, -13.4012699, 0., 42.7113266
2128, -1.19003737, 0., 44.4450912
2129, -30.4730377, 0., 31.1315327
2130, 12.6266127, 0., 42.4223557
2131, -17.2339344, 0., -40.9564667
2132, 9.21255302, 0., -7.88849449
2133, 40.3545532, 0., 12.5577917
2134, 42.1726265, 0., 10.5711708
2135, 13.5836716, 0., 9.43280602
2136, 10.6366453, 0., 8.80142307
2137, 34.142849, 0., 9.72004986
2138, 33.2536697, 0., -25.2443848
2139, 39.1062431, 0., -17.1783409
2140, 23.5099316, 0., -31.6423264
2141, 32.1324654, 0., 24.4445572
2142, 28.0284233, 0., 29.4753952
2143, 2.82518959, 0., -10.5692215
2144, -36.3576012, 0., 17.8706055
2145, 13.4164686, 0., -40.6742744
2146, 11.836401, 0., -41.1857185
2147, 19.0967751, 0., -35.9088745
2148, 17.9185314, 0., -36.8735199
2149, 34.6377258, 0., -22.5886192
2150, -29.2342472, 0., 28.7706318
2151, 15.9549074, 0., -38.6183052
2152, -35.3216858, 0., -21.4687099
2153, 30.058157, 0., -7.60911131
2154, 8.65810585, 0., -42.0181427
2155, -39.9533844, 0., -8.27626801
2156, -6.71229076, 0., -41.7023201
2157, -40.6790924, 0., -0.21973452
2158, -40.6063995, 0., 3.06602859
2159, 39.1837311, 0., -9.91466808
2160, -11.2430305, 0., 41.4115829
2161, -9.56075478, 0., 41.7045631
2162, -20.9961472, 0., -36.9695015
2163, -2.74902177, 0., 42.560215
2164, 0.647243083, 0., 42.6531143
2165, 9.94110012, 0., 10.234581
2166, 3.3860209, 0., -12.0951338
2167, 4.82769775, 0., -11.8107376
2168, 36.7652664, 0., 13.0018635
2169, 34.456543, 0., 22.9192677
2170, -12.7948923, 0., 9.83866501
2171, -13.9217234, 0., 2.75035906
2172, 37.6589088, 0., -10.8971176
2173, 21.2193298, 0., -31.6884613
2174, 30.660038, 0., 23.6789513
2175, -13.5333061, 0., -5.31091595
2176, 31.385128, 0., 22.2268906
2177, -32.0605888, 0., 21.2890282
2178, -36.1375198, 0., -12.2601147
2179, 9.38544273, 0., 11.5525694
2180, 23.3981171, 0., 35.9290352
2181, -32.1669388, 0., -19.7753258
2182, 30.8556328, 0., -25.4795341
2183, 32.4378815, 0., -24.4975662
2184, 32.5771141, 0., -23.3874817
2185, 7.32717657, 0., 41.8542938
2186, -40.1982498, 0., 9.6510191
2187, 12.1295252, 0., 40.6477356
2188, -30.7047024, 0., -30.3048058
2189, 19.1199989, 0., 37.3273048
2190, 19.9490299, 0., 36.0930557
2191, 11.1758986, 0., -39.5838356
2192, 8.2221365, 0., -40.461113
2193, -4.66536856, 0., -40.2298508
2194, 15.5075626, 0., -36.8233147
2195, 13.2359371, 0., -11.5563135
2196, 16.8996849, 0., -11.6499138
2197, -18.7374249, 0., -36.2448311
2198, -27.8336525, 0., -29.7733822
2199, 33.7756348, 0., -19.9987259
2200, -38.7554321, 0., 2.98932886
2201, -38.6095009, 0., 4.62105131
2202, 2.51245046, 0., -13.7881498
2203, -15.6799412, 0., 38.2408867
2204, -12.4617491, 0., 39.451088
2205, -0.888519228, 0., 40.8753319
2206, 2.34131598, 0., 40.8150253
2207, 29.833168, 0., 21.5909958
2208, 27.1207466, 0., 25.8566132
2209, -32.9445534, 0., -16.3089561
2210, -34.2614517, 0., -13.6695156
2211, 30.4470501, 0., 19.8959446
2212, -15.4428482, 0., 10.4944925
2213, -5.84186268, 0., -16.7588844
2214, 24.3331413, 0., 27.6296787
2215, -23.505394, 0., 29.4598331
2216, -26.7828121, 0., 28.4946594
2217, -31.8417606, 0., 18.9440155
2218, -18.600481, 0., 32.256691
2219, 16.2834549, 0., -33.4171944
2220, 32.0195198, 0., -10.712409
2221, -3.63591909, 0., 14.2444391
2222, -29.7142792, 0., -19.5246601
2223, 34.7927284, 0., 18.5423489
2224, 11.8396721, 0., -37.5691833
2225, 9.09314156, 0., -38.5012016
2226, 6.38352633, 0., -39.3292847
2227, 1.98899591, 0., -39.3976936
2228, 35.3337631, 0., 15.2525387
2229, -5.87251139, 0., -38.0227051
2230, -16.597105, 0., -35.4829407
2231, -19.1241169, 0., -33.9259453
2232, -24.2430077, 0., -29.928318
2233, -14.0009336, 0., 37.7330933
2234, -16.7670574, 0., 30.4358883
2235, 4.12200069, 0., -15.0093451
2236, -33.0536919, 0., -13.4098301
2237, -31.4026184, 0., -15.3609982
2238, -22.7731819, 0., 28.0995674
2239, 28.8375282, 0., 18.2474842
2240, 27.6382637, 0., 15.4312
2241, 21.7252464, 0., 17.8123379
2242, -36.9116974, 0., 2.86287403
2243, -3.82342148, 0., 38.8603172
2244, 0.831298351, 0., 39.174633
2245, -31.5324287, 0., 16.9711266
2246, -28.5095329, 0., 19.5499153
2247, -8.96045971, 0., 17.3318157
2248, 16.1916752, 0., -30.9880409
2249, 24.8218155, 0., 25.0326729
2250, 25.8538456, 0., -19.958271
2251, 19.6353493, 0., -21.1346703
2252, -12.6229906, 0., 17.9254398
2253, -19.4978371, 0., -7.86068678
2254, 6.20137215, 0., -15.0873537
2255, -19.1236019, 0., 5.10372114
2256, -37.2144661, 0., -1.65090442
2257, 28.7682362, 0., 13.6403103
2258, 6.84000587, 0., 38.3012581
2259, 9.8086338, 0., 37.5359802
2260, 33.8095894, 0., 15.3934879
2261, -33.2323265, 0., 8.03664684
2262, 16.5532265, 0., 35.4454193
2263, 32.3118401, 0., 14.603817
2264, 11.1965542, 0., -36.3991776
2265, 8.33671188, 0., -37.0128021
2266, 7.17645979, 0., -37.6822014
2267, 5.07016563, 0., -37.5792084
2268, 3.50635409, 0., -37.7827873
2269, 0.620850086, 0., -37.8282509
2270, -0.756197989, 0., -37.616478
2271, -3.66986394, 0., -36.9116745
2272, 13.4461451, 0., -14.8403959
2273, -5.04364061, 0., 36.8989601
2274, -1.94815218, 0., 37.289341
2275, 3.80306411, 0., 37.3382683
2276, -11.4613981, 0., 34.6167679
2277, -14.9395561, 0., 32.4163933
2278, 14.9266691, 0., 31.602663
2279, -9.56884193, 0., -33.3955612
2280, -12.1132984, 0., -35.9705696
2281, -14.5819874, 0., -34.737648
2282, -18.1525879, 0., -32.6276321
2283, -21.9045143, 0., -29.5937862
2284, -21.9734688, 0., -21.8844223
2285, 25.2637768, 0., 17.8757896
2286, 21.0671749, 0., 19.7732506
2287, -21.3330421, 0., 25.7914543
2288, 17.3920155, 0., -20.0507832
2289, -13.5803404, 0., -21.4205704
2290, 22.31497, 0., 24.5638275
2291, -28.8897858, 0., 17.2296085
2292, 10.8996401, 0., -17.1856384
2293, 15.5676012, 0., 34.0883217
2294, -15.6052532, 0., 31.6546268
2295, -21.8987141, 0., -26.7609386
2296, 24.8097839, 0., -17.7213573
2297, 12.4703751, 0., -16.6580048
2298, 8.04819012, 0., 36.2399788
2299, 29.336338, 0., -16.5172024
2300, 28.5765495, 0., -17.6251945
2301, 25.5537491, 0., 20.3817253
2302, -23.1558247, 0., -0.774433136
2303, 22.3813953, 0., 21.7331047
2304, 14.6324072, 0., -16.599041
2305, -14.7088299, 0., 29.1164188
2306, -29.9582901, 0., 14.1047907
2307, -12.3964691, 0., 33.1933899
2308, -7.98070335, 0., 34.7702827
2309, 11.632494, 0., -33.8413544
2310, -20.6561985, 0., -13.2910099
2311, 14.878808, 0., 34.970192
2312, -18.287756, 0., -30.9536228
2313, -17.9268379, 0., -28.2657146
2314, -14.0037289, 0., -33.5880966
2315, -0.183591545, 0., 35.7745056
2316, 2.51983452, 0., 35.9736137
2317, -16.8320866, 0., 25.4110241
2318, 6.36870575, 0., -36.6772041
2319, 20.3465137, 0., 24.314127
2320, -20.6914425, 0., 14.1331844
2321, -22.2018452, 0., 12.9722948
2322, -8.16415501, 0., -31.9063377
2323, -4.28850794, 0., -34.8577499
2324, 0.912939966, 0., -36.4293671
2325, 3.3477757, 0., -36.2790146
2326, 9.01814365, 0., -19.802433
2327, -9.39953804, 0., -30.639534
2328, 14.452219, 0., 22.4760342
2329, -9.72541523, 0., -22.8966846
2330, 15.6748466, 0., -18.5605659
2331, -20.0382328, 0., -24.9187679
2332, -20.1194477, 0., -20.9079971
2333, 14.9944029, 0., 24.747776
2334, 13.7500858, 0., -20.1102219
2335, 8.34228992, 0., 17.333353
2336, 5.95190001, 0., -35.460041
2337, -26.8690796, 0., -12.7485189
2338, -26.8069839, 0., -6.97324896
2339, 31.3901577, 0., 15.2914877
2340, 32.157135, 0., 16.4228954
2341, 7.75806761, 0., 34.8228722
2342, -5.85116196, 0., 33.1226463
2343, 10.0017452, 0., -26.5329266
2344, 10.2674084, 0., -23.8997097
2345, -35.9435654, 0., -1.53192484
2346, 10.5852289, 0., 33.9808388
2347, -20.3363819, 0., -19.0207691
2348, -33.8627052, 0., -5.06762886
2349, -11.3275557, 0., 31.7555408
2350, -16.7627621, 0., -30.193594
2351, 11.9978914, 0., -21.8009377
2352, 9.48166084, 0., -20.7449188
2353, 2.89033961, 0., 34.5691071
2354, 9.33192253, 0., 29.2374077
2355, -11.9515429, 0., -30.682066
2356, -27.2654858, 0., -4.78295374
2357, 10.0557652, 0., -21.8853302
2358, -22.0910969, 0., -15.0002117
2359, -22.9965954, 0., -16.0398979
2360, -15.9068861, 0., 24.0860672
2361, -14.6714907, 0., 24.8145447
2362, -1.32122219, 0., 21.1768532
2363, -5.76327467, 0., 22.388382
2364, -15.366313, 0., -27.488802
2365, -25.3013344, 0., 4.56865788
2366, -27.5484924, 0., -2.64645886
2367, 8.35941029, 0., 30.9071789
2368, -26.32374, 0., 0.163296878
2369, -4.4914484, 0., -32.7875175
2370, -22.5954494, 0., -13.6761103
2371, -16.0762291, 0., -32.0638428
2372, -13.8362207, 0., -28.2702923
2373, -28.7885284, 0., 2.0181067
2374, -1.19950461, 0., -34.6931763
2375, 7.95439386, 0., -27.2141819
2376, -12.7586203, 0., -29.3661671
2377, 7.07887316, 0., 29.8752003
2378, -9.20372295, 0., 26.6915607
2379, 4.27236652, 0., 21.8020992
2380, -28.2546616, 0., 0.759730816
2381, -11.5303011, 0., -28.4444389
2382, -3.17208838, 0., 29.6413307
2383, 6.67604923, 0., 28.2047234
2384, 0.857947111, 0., 32.668457
2385, -6.21675062, 0., 26.0441494
2386, 4.21685648, 0., 29.2742176
2387, -3.22587895, 0., -31.7338924
2388, -2.87792277, 0., -29.7790089
2389, 2.51958251, 0., 29.0753078
2390, -0.87806952, 0., 27.822752
*Element, type=S3
1, 1086, 1076, 112
2, 1809, 1597, 145
3, 1950, 149, 1940
4, 1866, 1770, 1802
5, 2223, 1197, 1338
6, 1457, 1481, 1458
7, 2386, 1885, 225
8, 1402, 1253, 409
9, 1580, 2300, 1695
10, 601, 976, 66
11, 1137, 967, 874
12, 2103, 111, 873
13, 2109, 1023, 411
14, 2141, 1268, 198
15, 290, 1257, 1121
16, 1423, 238, 1290
17, 1662, 1571, 1610
18, 1442, 157, 1337
19, 434, 2280, 1493
20, 2245, 158, 1476
21, 2246, 1599, 192
22, 1560, 2324, 1513
23, 1789, 1568, 2303
24, 1840, 1793, 1700
25, 225, 2377, 1722
26, 1854, 1739, 1668
27, 2359, 1888, 338
28, 1991, 127, 1909
29, 1992, 1947, 1910
30, 2332, 1939, 1999
31, 2021, 1971, 386
32, 2202, 1495, 322
33, 2220, 1227, 1355
34, 1567, 2239, 178
35, 2283, 1609, 1501
36, 2336, 2318, 1448
37, 2352, 2326, 364
38, 2339, 1462, 2263
39, 1685, 1563, 2306
40, 2352, 2357, 1929
41, 2360, 210, 1863
42, 2361, 209, 1763
43, 1505, 422, 2325
44, 2381, 1835, 1891
45, 1995, 2001, 2035
*Element, type=S4R
46, 586, 584, 585, 2075
47, 861, 780, 108, 1040
48, 798, 862, 1040, 108
49, 816, 863, 1028, 107
50, 1170, 1062, 105, 2084
51, 103, 981, 1082, 1216
52, 981, 963, 1083, 294
53, 817, 101, 962, 864
54, 101, 820, 865, 962
55, 100, 779, 866, 965
56, 99, 800, 867, 1025
57, 694, 847, 982, 991
58, 300, 1243, 1093, 1242
59, 301, 1363, 1456, 1490
60, 302, 1572, 1690, 1742
61, 303, 1820, 1921, 1962
62, 2014, 2050, 1980, 305
63, 1803, 2356, 1877, 93
64, 306, 1635, 1573, 1649
65, 90, 1300, 1374, 1550
66, 89, 1056, 1084, 1238
67, 910, 958, 310, 750
68, 727, 536, 38, 658
69, 658, 728, 750, 310
70, 659, 588, 790, 912
71, 627, 808, 751, 729
72, 809, 828, 960, 869
73, 921, 983, 392, 2080
74, 414, 984, 926, 810
75, 934, 830, 1031, 985
76, 446, 870, 664, 732
77, 631, 752, 831, 632
78, 753, 752, 631, 733
79, 555, 812, 589, 47
80, 734, 556, 48, 590
81, 590, 48, 557, 735
82, 590, 735, 858, 459
83, 1039, 913, 459, 858
84, 1057, 450, 1177, 2193
85, 2323, 420, 2369, 1636
86, 402, 1965, 1900, 1901
87, 360, 2051, 2041, 1964
88, 341, 1878, 1855, 2213
89, 1613, 320, 1637, 1741
90, 1278, 1375, 300, 1242
91, 1363, 1278, 1246, 97
92, 471, 472, 678, 591
93, 754, 591, 678, 105
94, 682, 1231, 2084, 680
95, 473, 4, 592, 681
96, 103, 1216, 683, 593
97, 475, 476, 595, 593
98, 6, 477, 594, 687
99, 591, 596, 3, 471
100, 596, 591, 754, 106
101, 6, 476, 606, 597
102, 7, 478, 598, 688
103, 478, 479, 692, 598
104, 480, 481, 600, 599
105, 601, 486, 487, 698
106, 697, 848, 110, 696
107, 1239, 135, 1376, 1283
108, 1357, 1232, 114, 1283
109, 1277, 115, 1389, 1377
110, 117, 1087, 1044, 1217
111, 1178, 2136, 2107, 118
112, 1088, 1240, 119, 1045
113, 1378, 1188, 1333, 142
114, 1188, 1334, 121, 1129
115, 1441, 144, 1546, 1586
116, 2170, 1771, 2212, 1872
117, 147, 1957, 1883, 2212
118, 1940, 1944, 2036, 1950
119, 149, 1788, 1873, 1940
120, 151, 1778, 1804, 150
121, 1301, 1379, 152, 1085
122, 1085, 153, 1035, 1191
123, 901, 2100, 838, 132
124, 530, 722, 721, 529
125, 647, 723, 755, 132
126, 648, 725, 756, 854
127, 535, 587, 602, 37
128, 1171, 116, 1065, 73
129, 1096, 1179, 71, 1064
130, 471, 3, 603, 677
131, 603, 70, 757, 677
132, 603, 604, 821, 70
133, 604, 603, 3, 470
134, 821, 69, 966, 894
135, 1076, 1086, 2137, 113
136, 1171, 73, 1233, 1320
137, 474, 473, 681, 605
138, 606, 686, 758, 74
139, 74, 758, 942, 2091
140, 1087, 2135, 2106, 1044
141, 964, 819, 74, 2091
142, 75, 819, 964, 872
143, 974, 846, 75, 872
144, 2, 469, 607, 676
145, 822, 68, 967, 893
146, 1089, 112, 1051, 1139
147, 467, 466, 609, 608
148, 609, 482, 483, 695
149, 67, 695, 610, 943
150, 2116, 976, 781, 133
151, 943, 873, 1137, 874
152, 608, 67, 759, 650
153, 469, 468, 671, 607
154, 484, 696, 610, 11
155, 66, 12, 486, 601
156, 2085, 760, 2098, 944
157, 880, 875, 823, 2081
158, 986, 923, 950, 1070
159, 876, 237, 824, 987
160, 762, 904, 825, 267
161, 706, 501, 20, 280
162, 280, 20, 502, 652
163, 761, 611, 707, 282
164, 282, 707, 708, 826
165, 878, 906, 2185, 271
166, 272, 1180, 1055, 1263
167, 1545, 1438, 1594, 241
168, 1722, 1638, 1702, 1787
169, 205, 1945, 1848, 1885
170, 1895, 183, 1946, 2008
171, 1665, 2335, 1723, 1815
172, 141, 1466, 1454, 1361
173, 1551, 1454, 1596, 165
174, 1511, 1466, 141, 2179
175, 1466, 1511, 1555, 166
176, 1805, 1785, 182, 1904
177, 2004, 1988, 203, 1960
178, 224, 1879, 1831, 2354
179, 241, 1638, 1619, 2341
180, 2298, 1678, 2259, 257
181, 2187, 2130, 1004, 1090
182, 761, 282, 878, 1004
183, 611, 21, 504, 707
184, 705, 500, 501, 706
185, 19, 612, 762, 499
186, 617, 18, 498, 267
187, 786, 950, 923, 236
188, 2081, 823, 217, 702
189, 701, 491, 15, 614
190, 667, 14, 490, 196
191, 781, 801, 956, 133
192, 175, 763, 699, 700
193, 701, 614, 764, 849
194, 492, 217, 614, 15
195, 494, 802, 615, 16
196, 496, 252, 616, 17
197, 253, 2079, 825, 877
198, 618, 22, 506, 709
199, 766, 709, 710, 284
200, 907, 766, 284, 1020
201, 272, 2206, 1262, 1325
202, 1556, 2353, 2316, 1487
203, 2384, 1806, 242, 1681
204, 1885, 1910, 1947, 205
205, 1930, 2379, 1948, 2009
206, 165, 1724, 1719, 1674
207, 142, 1551, 1525, 1378
208, 1674, 1525, 1551, 165
209, 619, 23, 508, 711
210, 767, 619, 711, 285
211, 908, 767, 285, 2128
212, 1418, 1312, 2205, 1264
213, 260, 1682, 1534, 2274
214, 1740, 1709, 227, 2382
215, 1842, 2382, 1886, 2390
216, 1942, 2362, 1949, 2035
217, 164, 1801, 1783, 1675
218, 143, 1557, 1528, 1390
219, 1528, 1675, 1627, 2221
220, 712, 509, 510, 713
221, 977, 1037, 1091, 274
222, 1091, 275, 1279, 1201
223, 1488, 1558, 2273, 1444
224, 228, 1725, 1708, 1759
225, 1725, 228, 1853, 1817
226, 1932, 208, 1961, 2385
227, 163, 1807, 1902, 1769
228, 1639, 1627, 163, 1769
229, 1726, 1631, 1639, 162
230, 1686, 1727, 1808, 1703
231, 215, 1073, 957, 805
232, 1092, 31, 523, 625
233, 195, 881, 768, 2078
234, 622, 720, 769, 782
235, 827, 782, 155, 949
236, 527, 622, 623, 33
237, 153, 1066, 946, 2101
238, 988, 155, 946, 1066
239, 827, 949, 881, 195
240, 621, 2078, 882, 216
241, 1092, 625, 957, 235
242, 1465, 1439, 1478, 1467
243, 214, 1181, 1150, 1322
244, 624, 718, 770, 251
245, 718, 521, 522, 1018
246, 624, 30, 521, 718
247, 524, 2073, 625, 523
248, 1275, 213, 1373, 2150
249, 885, 989, 884, 251
250, 1166, 1049, 2097, 234
251, 883, 265, 653, 784
252, 804, 884, 2086, 717
253, 626, 29, 519, 717
254, 770, 2097, 885, 251
255, 233, 2150, 1266, 1142
256, 212, 1467, 1559, 1679
257, 146, 1912, 1952, 1867
258, 1597, 1809, 1721, 1644
259, 1849, 1726, 162, 2247
260, 1865, 1880, 2247, 162
261, 1941, 188, 1937, 1863
262, 2317, 1706, 210, 2360
263, 1381, 1291, 1250, 2215
264, 2102, 999, 947, 771
265, 717, 519, 520, 804
266, 529, 721, 772, 34
267, 628, 541, 542, 2074
268, 541, 628, 627, 40
269, 629, 543, 544, 773
270, 845, 886, 668, 730
271, 548, 731, 633, 547
272, 630, 549, 550, 829
273, 445, 45, 551, 664
274, 554, 733, 631, 553
275, 553, 631, 632, 46
276, 393, 41, 543, 629
277, 887, 42, 545, 668
278, 774, 43, 547, 633
279, 430, 44, 549, 630
280, 736, 460, 858, 735
281, 634, 49, 559, 737
282, 917, 969, 990, 450
283, 990, 451, 1182, 1117
284, 1640, 2374, 421, 1728
285, 403, 1810, 1728, 1751
286, 1993, 1996, 383, 2019
287, 2019, 1984, 2047, 384
288, 1890, 1832, 1927, 361
289, 321, 1641, 1622, 1520
290, 1382, 300, 1375, 1523
291, 847, 1036, 1093, 982
292, 738, 560, 561, 739
293, 797, 462, 955, 918
294, 1058, 452, 1183, 1118
295, 2325, 422, 1560, 1513
296, 1751, 1683, 1660, 404
297, 1977, 383, 1996, 1934
298, 1914, 362, 1953, 2018
299, 1775, 343, 1811, 1868
300, 322, 1495, 1553, 1455
301, 694, 991, 800, 600
302, 295, 1075, 1094, 1244
303, 327, 1293, 1426, 1538
304, 1578, 1694, 2296, 1654
305, 1713, 1729, 1617, 376
306, 1008, 375, 1115, 2109
307, 775, 636, 412, 948
308, 574, 412, 636, 57
309, 744, 637, 776, 833
310, 637, 58, 576, 373
311, 59, 640, 745, 577
312, 888, 372, 2087, 2112
313, 330, 1497, 1431, 1305
314, 2220, 1385, 1527, 330
315, 1170, 292, 2153, 1062
316, 1280, 292, 1276, 1383
317, 1383, 1276, 293, 1384
318, 1218, 1350, 1384, 293
319, 1082, 981, 294, 1218
320, 348, 1591, 1700, 1793
321, 1714, 368, 1730, 1689
322, 410, 1330, 1184, 1050
323, 429, 1023, 889, 777
324, 572, 814, 638, 56
325, 636, 775, 927, 743
326, 429, 777, 638, 814
327, 428, 777, 889, 1050
328, 428, 1032, 834, 777
329, 570, 444, 639, 55
330, 742, 638, 777, 834
331, 640, 59, 578, 641
332, 579, 642, 641, 578
333, 863, 816, 106, 1081
334, 863, 1095, 290, 1028
335, 329, 1385, 1332, 1280
336, 2110, 815, 860, 2083
337, 992, 891, 2082, 836
338, 862, 798, 107, 1028
339, 1257, 2159, 2121, 2120
340, 643, 61, 582, 748
341, 839, 861, 892, 288
342, 331, 891, 992, 1144
343, 69, 822, 893, 966
344, 70, 821, 894, 1127
345, 1064, 941, 1187, 114
346, 1096, 1064, 114, 1232
347, 71, 757, 941, 1064
348, 1097, 1065, 116, 2118
349, 1097, 1281, 117, 1217
350, 597, 644, 477, 6
351, 76, 2076, 895, 1024
352, 1261, 1128, 119, 1240
353, 896, 778, 76, 1024
354, 77, 778, 896, 1029
355, 897, 799, 77, 1029
356, 479, 478, 690, 645
357, 778, 649, 645, 76
358, 481, 480, 693, 646
359, 78, 799, 897, 1052
360, 1052, 121, 1189, 1100
361, 1247, 122, 1386, 1282
362, 1282, 1421, 80, 1226
363, 1562, 1677, 81, 1471
364, 1813, 1916, 82, 1732
365, 2052, 2049, 126, 2065
366, 1915, 1982, 2005, 1991
367, 1684, 1812, 1731, 2261
368, 1543, 1561, 1432, 87
369, 131, 1053, 1098, 1433
370, 132, 755, 898, 901
371, 723, 531, 532, 724
372, 755, 65, 940, 898
373, 854, 756, 899, 2099
374, 725, 726, 855, 756
375, 648, 36, 533, 725
376, 10, 975, 847, 694
377, 98, 1036, 2077, 1099
378, 1099, 2077, 1162, 2111
379, 1436, 1470, 1387, 1316
380, 1536, 1562, 1421, 123
381, 1100, 900, 78, 1052
382, 837, 78, 900, 1034
383, 645, 649, 8, 479
384, 1470, 1593, 1642, 1587
385, 1994, 1954, 1916, 125
386, 1974, 2020, 1850, 1896
387, 95, 1838, 1881, 1981
388, 1908, 1943, 1956, 2368
389, 83, 2049, 2052, 2069
390, 1784, 1813, 1677, 124
391, 1642, 1593, 1755, 1733
392, 1316, 1387, 1245, 1161
393, 1866, 1876, 2366, 1908
394, 1684, 86, 1734, 1812
395, 1621, 1643, 1519, 2345
396, 1762, 1734, 86, 1667
397, 1472, 1405, 1388, 1519
398, 1469, 1432, 1561, 129
399, 1812, 1915, 128, 1731
400, 93, 2002, 1943, 1803
401, 1054, 1080, 1167, 2157
402, 1168, 2157, 1190, 1356
403, 1098, 1053, 88, 1229
404, 1453, 1360, 90, 1550
405, 599, 99, 779, 691
406, 608, 650, 1, 467
407, 780, 669, 672, 108
408, 584, 586, 651, 62
409, 478, 7, 689, 690
410, 1283, 114, 1187, 1239
411, 1232, 1357, 1389, 115
412, 2105, 2104, 1284, 1422
413, 1334, 143, 1390, 1335
414, 1473, 123, 1386, 1586
415, 1536, 123, 1644, 2170
416, 1872, 2212, 1883, 125
417, 125, 1883, 1957, 1994
418, 1944, 1940, 127, 2065
419, 1873, 1788, 150, 1804
420, 129, 2261, 1661, 1582
421, 1301, 130, 1582, 1379
422, 1191, 1035, 2126, 2186
423, 698, 487, 13, 613
424, 781, 976, 601, 698
425, 993, 956, 174, 1148
426, 1148, 1269, 1267, 993
427, 1393, 1474, 2339, 2340
428, 136, 2257, 1645, 1518
429, 1646, 1629, 170, 1736
430, 1507, 1524, 1614, 168
431, 139, 1430, 1303, 1228
432, 1430, 140, 1407, 1303
433, 956, 993, 2133, 133
434, 1369, 1285, 2228, 2260
435, 1475, 1474, 1598, 2257
436, 2240, 1673, 137, 1645
437, 138, 1422, 1537, 1624
438, 139, 1281, 1524, 1507
439, 1912, 161, 1958, 1952
440, 160, 2053, 1952, 1958
441, 2321, 1905, 149, 1950
442, 2006, 147, 1867, 1952
443, 1685, 1788, 1814, 1727
444, 1814, 1788, 149, 1905
445, 1563, 158, 2245, 1442
446, 156, 1141, 1286, 1192
447, 1286, 1141, 152, 1379
448, 1754, 1664, 1442, 1337
449, 623, 622, 782, 827
450, 156, 1192, 1193, 2144
451, 1193, 1287, 1172, 2144
452, 1195, 1174, 1159, 1194
453, 215, 1022, 1159, 1174
454, 2217, 1476, 1564, 1477
455, 1477, 1564, 2246, 192
456, 190, 1666, 1780, 2031
457, 1559, 1467, 1478, 191
458, 188, 1941, 2000, 2023
459, 2000, 189, 2007, 2062
460, 1815, 1723, 183, 1895
461, 1680, 1805, 1723, 2335
462, 1592, 1701, 167, 1542
463, 1799, 1841, 1701, 168
464, 2328, 1986, 2333, 1988
465, 223, 1926, 1852, 1738
466, 2278, 239, 2293, 1628
467, 1353, 1391, 256, 1241
468, 269, 905, 994, 1352
469, 840, 652, 281, 971
470, 652, 502, 503, 281
471, 168, 1614, 1712, 1799
472, 1844, 1799, 1712, 1843
473, 1647, 1569, 222, 1772
474, 1565, 1423, 1548, 239
475, 255, 1392, 1130, 1352
476, 902, 268, 850, 995
477, 995, 850, 932, 269
478, 1789, 1687, 1688, 1568
479, 1530, 2290, 1648, 2303
480, 1479, 1339, 221, 1600
481, 1123, 1308, 1101, 1047
482, 996, 253, 877, 2180
483, 2180, 877, 254, 1124
484, 1567, 1566, 171, 2239
485, 179, 1567, 1481, 2301
486, 1457, 200, 1480, 1481
487, 1288, 1248, 220, 2214
488, 220, 1165, 1101, 1199
489, 2211, 1393, 1338, 1289
490, 1338, 1197, 177, 1289
491, 1249, 199, 1365, 2174
492, 1102, 1048, 218, 1140
493, 1048, 1102, 2141, 198
494, 1147, 1197, 2223, 1169
495, 945, 197, 1046, 997
496, 997, 176, 2098, 945
497, 944, 931, 175, 2085
498, 931, 944, 1059, 998
499, 2174, 1365, 2207, 2176
500, 1568, 1480, 1530, 2303
501, 1648, 1737, 180, 2303
502, 1841, 1928, 182, 1785
503, 2008, 1946, 204, 1945
504, 1904, 2004, 1946, 183
505, 1847, 185, 1801, 1719
506, 1903, 1783, 1801, 185
507, 1865, 1769, 1902, 1987
508, 1865, 1987, 187, 1880
509, 187, 1997, 1979, 1880
510, 1707, 1603, 209, 1816
511, 1424, 231, 1482, 1314
512, 265, 1003, 903, 841
513, 784, 517, 518, 266
514, 947, 999, 2123, 883
515, 1800, 210, 1706, 211
516, 1862, 1800, 211, 1758
517, 191, 1478, 1599, 1703
518, 216, 32, 525, 621
519, 667, 196, 760, 2085
520, 1419, 1364, 199, 1249
521, 2214, 1394, 2249, 1288
522, 202, 1772, 1884, 2333
523, 225, 1885, 1848, 2383
524, 1926, 1831, 1960, 203
525, 2009, 1948, 205, 1947
526, 1942, 2035, 2001, 186
527, 2385, 1961, 2048, 207
528, 1918, 1997, 2010, 1975
529, 1975, 1854, 1707, 1816
530, 1486, 1483, 2277, 2294
531, 1198, 1152, 248, 2218
532, 654, 515, 516, 279
533, 653, 28, 517, 784
534, 1484, 1381, 2215, 2238
535, 1461, 212, 1554, 232
536, 1181, 1327, 213, 1275
537, 615, 785, 2081, 702
538, 1423, 1565, 1533, 238
539, 222, 2278, 1738, 1852
540, 1765, 1715, 2346, 1619
541, 227, 1725, 1817, 1919
542, 1668, 1739, 228, 1759
543, 1483, 1570, 2349, 246
544, 1270, 247, 2277, 1463
545, 264, 1000, 972, 903
546, 515, 654, 655, 27
547, 842, 841, 903, 972
548, 1486, 2305, 229, 1483
549, 230, 1482, 1601, 1705
550, 249, 1067, 1103, 1250
551, 250, 1142, 1067, 2102
552, 924, 235, 1001, 234
553, 786, 703, 616, 824
554, 2190, 1290, 1124, 254
555, 2311, 1529, 1628, 2293
556, 1438, 2275, 1485, 1594
557, 1545, 2298, 257, 2258
558, 1556, 1681, 242, 2353
559, 1709, 1740, 244, 2342
560, 1605, 2342, 1488, 2308
561, 1570, 1483, 229, 1668
562, 2308, 1489, 245, 1605
563, 929, 277, 1136, 1002
564, 714, 787, 287, 803
565, 716, 853, 788, 715
566, 1463, 2277, 1483, 246
567, 2218, 1314, 2234, 1435
568, 1291, 1222, 249, 1250
569, 994, 905, 270, 1131
570, 271, 2185, 1104, 1223
571, 271, 1090, 1004, 878
572, 1417, 259, 2315, 1487
573, 2274, 259, 1312, 1418
574, 2308, 1488, 1444, 1395
575, 1313, 1425, 2276, 1489
576, 2204, 262, 1200, 1138
577, 1002, 276, 2127, 929
578, 1292, 2233, 2203, 263
579, 1149, 263, 1000, 264
580, 264, 903, 1003, 1152
581, 877, 825, 904, 254
582, 905, 783, 840, 270
583, 878, 282, 826, 906
584, 761, 1004, 2130, 971
585, 2206, 272, 1263, 1132
586, 274, 1091, 1201, 1368
587, 1202, 1138, 1200, 261
588, 276, 2160, 973, 2127
589, 656, 26, 513, 715
590, 715, 513, 514, 716
591, 853, 278, 978, 277
592, 907, 968, 283, 766
593, 284, 767, 908, 1020
594, 2088, 851, 977, 1021
595, 287, 1005, 909, 843
596, 657, 25, 511, 803
597, 2088, 620, 712, 851
598, 1237, 1244, 2196, 1293
599, 295, 1244, 1237, 1083
600, 296, 1041, 1105, 1234
601, 1304, 1396, 326, 2196
602, 1538, 1426, 1591, 348
603, 1075, 864, 962, 296
604, 297, 1122, 1258, 1344
605, 325, 1345, 1447, 1615
606, 1698, 2304, 1589, 2272
607, 1745, 1874, 1827, 379
608, 377, 1571, 1662, 1440
609, 409, 1184, 1330, 1440
610, 820, 100, 965, 865
611, 779, 99, 1025, 866
612, 1506, 301, 1490, 1692
613, 301, 1375, 1278, 1363
614, 1818, 1742, 303, 1920
615, 319, 1819, 1748, 1693
616, 1572, 1456, 1541, 96
617, 1920, 303, 1962, 2015
618, 1819, 319, 1963, 2027
619, 1748, 1859, 341, 1637
620, 1964, 1855, 1878, 360
621, 1791, 1820, 1690, 2175
622, 317, 1967, 2370, 2310
623, 318, 1968, 2011, 2040
624, 1983, 339, 2054, 2016
625, 2033, 360, 1878, 1976
626, 2051, 385, 2055, 2041
627, 1962, 1921, 2012, 2253
628, 1887, 1821, 1773, 1822
629, 1888, 2359, 1858, 337
630, 2347, 2046, 2066, 338
631, 2067, 1922, 2056, 2289
632, 1985, 2013, 1891, 401
633, 1965, 401, 1761, 1900
634, 1532, 1577, 1649, 1573
635, 315, 2337, 1822, 1773
636, 1888, 1856, 1889, 338
637, 1782, 1893, 1966, 1939
638, 1823, 1670, 2364, 1870
639, 1574, 2279, 1659, 418
640, 1743, 419, 1636, 2369
641, 306, 1821, 2338, 1768
642, 1397, 1341, 314, 1532
643, 1656, 1744, 1606, 1491
644, 1774, 1834, 2284, 1824
645, 1492, 2313, 1581, 398
646, 2371, 1651, 2350, 1611
647, 2271, 1575, 2323, 1510
648, 307, 1633, 1552, 1459
649, 309, 1019, 1106, 2155
650, 313, 1173, 1203, 2178
651, 1491, 336, 1346, 2222
652, 1652, 1494, 389, 1774
653, 1672, 2295, 1653, 389
654, 2282, 1503, 2371, 1611
655, 1271, 1493, 2280, 1420
656, 1252, 1317, 1437, 434
657, 449, 2156, 1107, 1274
658, 308, 1374, 1300, 1230
659, 936, 910, 750, 311
660, 312, 951, 1006, 1153
661, 1210, 1204, 1154, 1109
662, 1310, 1403, 1509, 1399
663, 1434, 1576, 389, 1494
664, 416, 1343, 1207, 1273
665, 1318, 2197, 1400, 2231
666, 448, 1108, 938, 961
667, 857, 1038, 961, 458
668, 858, 460, 911, 1039
669, 1056, 309, 2155, 1084
670, 868, 958, 1056, 89
671, 537, 728, 658, 38
672, 869, 353, 1007, 959
673, 1030, 1113, 1205, 2152
674, 1114, 1060, 396, 1311
675, 415, 1206, 985, 1031
676, 1160, 1164, 1273, 1207
677, 1042, 937, 1110, 432
678, 589, 811, 753, 733
679, 857, 459, 913, 1038
680, 312, 1153, 1019, 936
681, 2178, 1203, 2210, 1341
682, 1577, 1532, 314, 1760
683, 2370, 1967, 316, 1858
684, 319, 1792, 1818, 1963
685, 1455, 1362, 1520, 1622
686, 1495, 2166, 2143, 1553
687, 1344, 1258, 1401, 324
688, 324, 1401, 1496, 1547
689, 1718, 2292, 1632, 345
690, 1923, 1925, 1924, 1970
691, 1610, 378, 1745, 1658
692, 1032, 428, 1111, 427
693, 1041, 2132, 1208, 1105
694, 1094, 1075, 296, 1234
695, 1350, 1218, 294, 1359
696, 348, 1578, 1549, 1538
697, 1175, 2184, 2183, 2138
698, 2108, 2094, 970, 2115
699, 1077, 374, 1026, 1112
700, 1112, 1026, 935, 371
701, 373, 745, 789, 928
702, 372, 789, 745, 640
703, 1654, 328, 1549, 1578
704, 1579, 1539, 350, 1497
705, 1497, 330, 1527, 1579
706, 1331, 1431, 1497, 1468
707, 1009, 352, 890, 1404
708, 1404, 890, 331, 1185
709, 539, 588, 659, 39
710, 751, 790, 588, 729
711, 951, 2095, 1071, 1006
712, 1173, 334, 1321, 1203
713, 1412, 2209, 2237, 1498
714, 1747, 1650, 337, 1858
715, 317, 2310, 1968, 2015
716, 1693, 1748, 1637, 320
717, 1641, 342, 1749, 1622
718, 323, 1496, 1401, 2167
719, 1846, 1929, 365, 1795
720, 1776, 1777, 1825, 1869
721, 1428, 1540, 1612, 1504
722, 1209, 1155, 427, 2140
723, 791, 639, 444, 952
724, 952, 1010, 2096, 791
725, 1615, 1447, 1632, 346
726, 1396, 1304, 2195, 1508
727, 1539, 1580, 1427, 350
728, 369, 1499, 1427, 1580
729, 2199, 1294, 350, 1427
730, 1294, 1260, 351, 1468
731, 640, 641, 2087, 372
732, 352, 1011, 835, 815
733, 808, 63, 959, 333
734, 1210, 1109, 354, 2181
735, 2181, 1399, 2222, 1346
736, 1607, 1656, 355, 1509
737, 357, 1889, 1824, 2284
738, 357, 2332, 1999, 2347
739, 2016, 1933, 340, 1983
740, 1976, 1933, 359, 2033
741, 1811, 1832, 1890, 362
742, 1868, 1811, 362, 1914
743, 1839, 1798, 1699, 1797
744, 364, 1839, 1907, 1990
745, 1869, 1938, 2343, 1864
746, 407, 1657, 2248, 1612
747, 1347, 2147, 442, 2117
748, 661, 457, 792, 914
749, 568, 457, 661, 54
750, 660, 569, 55, 639
751, 1846, 1718, 1798, 2326
752, 1698, 2297, 1826, 2304
753, 1840, 1700, 1796, 2288
754, 1837, 1794, 2296, 1694
755, 369, 1750, 1729, 1713
756, 1211, 375, 2138, 2183
757, 377, 1514, 1617, 1714
758, 1571, 1689, 378, 1610
759, 1923, 380, 1825, 379
760, 1969, 382, 1892, 1861
761, 1623, 1766, 1717, 423
762, 1451, 1354, 1517, 424
763, 1212, 1072, 953, 1134
764, 457, 660, 2089, 792
765, 1938, 380, 1998, 2344
766, 2017, 381, 1990, 1907
767, 2018, 1953, 383, 1977
768, 1984, 2019, 383, 1953
769, 2057, 2329, 2070, 386
770, 1823, 1922, 387, 1670
771, 1670, 387, 2331, 1696
772, 1774, 389, 1653, 1834
773, 1434, 1494, 390, 1311
774, 391, 1255, 1403, 1310
775, 1113, 392, 983, 1309
776, 828, 393, 629, 2080
777, 394, 1012, 983, 921
778, 1114, 395, 2119, 1060
779, 2198, 1584, 1116, 1342
780, 397, 2232, 1501, 1672
781, 2364, 399, 1781, 2372
782, 401, 1891, 1835, 2327
783, 402, 1901, 2388, 1913
784, 1860, 403, 1751, 404
785, 1969, 1861, 2375, 1935
786, 404, 1660, 1752, 1861
787, 1464, 439, 1522, 423
788, 1135, 1017, 2122, 455
789, 741, 566, 567, 813
790, 663, 741, 793, 930
791, 1864, 405, 1766, 406
792, 1776, 406, 1711, 1657
793, 1402, 1502, 408, 1296
794, 2109, 1115, 1256, 1126
795, 374, 970, 833, 776
796, 933, 413, 926, 984
797, 1116, 414, 985, 1206
798, 1207, 1295, 415, 1160
799, 417, 1503, 1400, 2230
800, 2314, 1535, 417, 2281
801, 1640, 1728, 1764, 420
802, 1683, 1751, 1728, 421
803, 1660, 1634, 1717, 1752
804, 1505, 2336, 1634, 422
805, 2124, 1120, 2154, 1013
806, 794, 930, 2122, 915
807, 662, 564, 565, 465
808, 663, 53, 566, 741
809, 1623, 423, 1522, 2309
810, 1620, 2248, 1657, 1711
811, 1414, 426, 1504, 425
812, 2140, 1296, 2173, 1209
813, 430, 630, 830, 934
814, 431, 1014, 1164, 1160
815, 432, 1110, 1213, 2197
816, 433, 1157, 1271, 1348
817, 1512, 436, 2270, 1616
818, 2267, 1505, 2325, 2268
819, 1016, 453, 1214, 1119
820, 859, 1013, 980, 463
821, 464, 52, 564, 662
822, 465, 794, 844, 662
823, 439, 2264, 1371, 1522
824, 1354, 440, 1225, 2194
825, 2148, 441, 1072, 1212
826, 1215, 1155, 1209, 1315
827, 925, 795, 1014, 431
828, 795, 445, 664, 870
829, 664, 551, 552, 732
830, 446, 831, 937, 1042
831, 1015, 447, 938, 1108
832, 1038, 1163, 448, 961
833, 450, 990, 1117, 1177
834, 451, 1058, 1118, 1182
835, 452, 1016, 1119, 1183
836, 919, 954, 1016, 452
837, 563, 740, 665, 562
838, 916, 464, 662, 844
839, 1017, 2145, 915, 2122
840, 953, 455, 793, 456
841, 917, 911, 460, 832
842, 461, 797, 918, 969
843, 796, 2090, 954, 919
844, 2090, 666, 665, 463
845, 562, 665, 666, 51
846, 797, 635, 738, 462
847, 643, 332, 581, 61
848, 748, 749, 288, 836
849, 469, 2, 673, 674
850, 668, 545, 546, 730
851, 466, 9, 482, 609
852, 467, 1, 669, 670
853, 670, 669, 780, 109
854, 671, 650, 759, 68
855, 672, 669, 1, 468
856, 2, 470, 675, 673
857, 798, 674, 673, 107
858, 596, 675, 470, 3
859, 677, 679, 472, 471
860, 680, 678, 472, 4
861, 682, 680, 4, 473
862, 593, 683, 5, 475
863, 683, 684, 474, 5
864, 605, 685, 5, 474
865, 685, 686, 475, 5
866, 593, 595, 818, 103
867, 477, 7, 688, 594
868, 644, 689, 7, 477
869, 599, 691, 8, 480
870, 691, 692, 479, 8
871, 799, 646, 693, 77
872, 649, 693, 480, 8
873, 694, 600, 481, 10
874, 11, 610, 695, 483
875, 696, 484, 485, 697
876, 763, 801, 613, 699
877, 488, 699, 613, 13
878, 700, 489, 14, 667
879, 196, 490, 491, 701
880, 217, 492, 493, 702
881, 16, 615, 702, 493
882, 495, 703, 802, 494
883, 17, 616, 703, 495
884, 252, 496, 497, 704
885, 704, 497, 18, 617
886, 267, 498, 499, 762
887, 500, 705, 612, 19
888, 281, 503, 21, 611
889, 22, 618, 708, 505
890, 23, 619, 710, 507
891, 285, 711, 620, 2088
892, 509, 712, 620, 24
893, 713, 510, 25, 657
894, 512, 714, 803, 511
895, 714, 512, 26, 656
896, 27, 655, 716, 514
897, 278, 655, 654, 842
898, 279, 516, 28, 653
899, 266, 518, 29, 626
900, 30, 624, 804, 520
901, 1018, 522, 31, 1092
902, 625, 2073, 805, 957
903, 32, 216, 2073, 524
904, 526, 719, 621, 525
905, 33, 623, 719, 526
906, 772, 920, 769, 720
907, 528, 720, 622, 527
908, 35, 647, 722, 530
909, 531, 723, 647, 35
910, 36, 648, 724, 532
911, 37, 602, 726, 534
912, 587, 727, 806, 64
913, 727, 658, 310, 806
914, 538, 807, 728, 537
915, 807, 538, 39, 659
916, 628, 2074, 809, 63
917, 41, 393, 2074, 542
918, 629, 773, 921, 2080
919, 42, 887, 773, 544
920, 887, 668, 886, 394
921, 43, 774, 730, 546
922, 810, 731, 430, 934
923, 44, 430, 731, 548
924, 45, 445, 829, 550
925, 732, 552, 46, 632
926, 812, 555, 556, 734
927, 49, 634, 736, 558
928, 461, 737, 635, 797
929, 560, 738, 635, 50
930, 51, 666, 739, 561
931, 463, 665, 740, 859
932, 52, 464, 740, 563
933, 465, 565, 53, 663
934, 54, 661, 813, 567
935, 457, 568, 569, 660
936, 444, 570, 571, 742
937, 56, 638, 742, 571
938, 814, 572, 573, 743
939, 57, 636, 743, 573
940, 412, 574, 575, 744
941, 58, 637, 744, 575
942, 373, 576, 577, 745
943, 746, 747, 860, 815
944, 60, 746, 642, 579
945, 581, 332, 747, 580
946, 748, 582, 583, 749
947, 62, 651, 749, 583
948, 651, 586, 109, 839
949, 9, 466, 2075, 585
950, 466, 467, 670, 2075
951, 602, 587, 64, 856
952, 587, 535, 536, 727
953, 588, 539, 540, 729
954, 729, 540, 40, 627
955, 47, 589, 733, 554
956, 735, 557, 558, 736
957, 734, 590, 459, 857
958, 596, 106, 816, 675
959, 4, 472, 679, 592
960, 817, 594, 688, 101
961, 687, 102, 818, 595
962, 687, 595, 476, 6
963, 74, 819, 597, 606
964, 644, 597, 819, 75
965, 820, 598, 692, 100
966, 101, 688, 598, 820
967, 599, 600, 800, 99
968, 801, 781, 698, 613
969, 922, 899, 756, 855
970, 470, 2, 676, 604
971, 821, 604, 676, 69
972, 685, 605, 1233, 73
973, 476, 475, 686, 606
974, 607, 671, 68, 822
975, 69, 676, 607, 822
976, 608, 609, 695, 67
977, 943, 610, 696, 110
978, 707, 504, 505, 708
979, 612, 268, 904, 762
980, 699, 488, 489, 700
981, 764, 614, 217, 823
982, 785, 236, 923, 2093
983, 2081, 785, 2093, 880
984, 703, 786, 236, 802
985, 267, 825, 2079, 617
986, 765, 704, 617, 2079
987, 709, 506, 507, 710
988, 826, 708, 618, 283
989, 711, 508, 24, 620
990, 720, 528, 34, 772
991, 718, 1018, 924, 770
992, 804, 624, 251, 884
993, 266, 626, 771, 947
994, 751, 808, 333, 2095
995, 627, 628, 63, 808
996, 393, 828, 809, 2074
997, 630, 829, 925, 830
998, 447, 2131, 752, 753
999, 732, 632, 831, 446
1000, 810, 926, 633, 731
1001, 633, 926, 413, 774
1002, 737, 559, 50, 635
1003, 832, 634, 737, 461
1004, 637, 373, 928, 776
1005, 660, 639, 791, 2089
1006, 641, 642, 835, 2087
1007, 746, 60, 580, 747
1008, 815, 835, 642, 746
1009, 748, 836, 2082, 643
1010, 689, 644, 75, 846
1011, 837, 646, 799, 78
1012, 10, 481, 646, 837
1013, 132, 838, 722, 647
1014, 724, 65, 755, 723
1015, 725, 533, 534, 726
1016, 693, 649, 778, 77
1017, 468, 1, 650, 671
1018, 749, 651, 839, 288
1019, 652, 840, 783, 280
1020, 653, 265, 841, 279
1021, 279, 841, 842, 654
1022, 714, 656, 852, 787
1023, 843, 657, 803, 287
1024, 286, 713, 657, 843
1025, 807, 659, 912, 311
1026, 813, 456, 793, 741
1027, 462, 738, 739, 796
1028, 849, 764, 197, 945
1029, 700, 667, 2085, 175
1030, 413, 845, 730, 774
1031, 670, 109, 586, 2075
1032, 468, 469, 674, 672
1033, 672, 674, 798, 108
1034, 107, 673, 675, 816
1035, 679, 677, 757, 71
1036, 679, 71, 1179, 592
1037, 105, 678, 680, 2084
1038, 681, 592, 1179, 72
1039, 72, 1233, 605, 681
1040, 473, 474, 684, 682
1041, 2084, 1231, 1319, 1170
1042, 684, 683, 1216, 104
1043, 684, 104, 1231, 682
1044, 686, 685, 73, 758
1045, 687, 594, 817, 102
1046, 690, 689, 846, 2076
1047, 645, 690, 2076, 76
1048, 692, 691, 779, 100
1049, 697, 485, 12, 66
1050, 848, 697, 66, 976
1051, 763, 175, 931, 174
1052, 850, 705, 706, 932
1053, 268, 612, 705, 850
1054, 280, 783, 932, 706
1055, 283, 618, 709, 766
1056, 284, 710, 619, 767
1057, 851, 712, 713, 286
1058, 715, 788, 852, 656
1059, 655, 278, 853, 716
1060, 2086, 884, 989, 250
1061, 719, 195, 2078, 621
1062, 153, 2101, 871, 1035
1063, 721, 722, 838, 154
1064, 772, 721, 154, 920
1065, 724, 648, 854, 65
1066, 311, 750, 728, 807
1067, 413, 933, 2119, 845
1068, 458, 811, 589, 812
1069, 734, 857, 458, 812
1070, 460, 736, 634, 832
1071, 796, 739, 666, 2090
1072, 859, 740, 464, 916
1073, 429, 814, 743, 927
1074, 372, 888, 935, 789
1075, 891, 2110, 2083, 2082
1076, 936, 311, 912, 312
1077, 910, 936, 1019, 309
1078, 831, 752, 2131, 937
1079, 753, 811, 938, 447
1080, 939, 754, 105, 1062
1081, 941, 757, 70, 1127
1082, 942, 758, 73, 1065
1083, 67, 943, 874, 759
1084, 849, 945, 2098, 760
1085, 611, 761, 971, 281
1086, 801, 763, 174, 956
1087, 879, 876, 987, 765
1088, 704, 765, 987, 252
1089, 285, 2088, 1021, 2128
1090, 1022, 768, 194, 1159
1091, 805, 882, 1022, 215
1092, 769, 920, 2101, 946
1093, 155, 782, 769, 946
1094, 2102, 771, 2086, 250
1095, 771, 626, 717, 2086
1096, 921, 773, 887, 394
1097, 833, 948, 412, 744
1098, 927, 775, 2092, 411
1099, 1023, 429, 927, 411
1100, 839, 109, 780, 861
1101, 783, 905, 269, 932
1102, 883, 784, 266, 947
1103, 236, 785, 615, 802
1104, 824, 616, 252, 987
1105, 973, 1005, 287, 787
1106, 277, 929, 788, 853
1107, 1026, 928, 789, 935
1108, 2095, 951, 790, 751
1109, 912, 790, 951, 312
1110, 952, 444, 742, 834
1111, 2089, 791, 2096, 443
1112, 443, 1027, 792, 2089
1113, 914, 792, 1027, 1134
1114, 663, 930, 794, 465
1115, 844, 794, 915, 454
1116, 795, 870, 1043, 1014
1117, 955, 919, 452, 1058
1118, 867, 800, 991, 1143
1119, 216, 882, 805, 2073
1120, 910, 309, 1056, 958
1121, 869, 959, 63, 809
1122, 961, 938, 811, 458
1123, 813, 661, 914, 456
1124, 963, 818, 102, 1236
1125, 875, 880, 1048, 198
1126, 197, 764, 823, 875
1127, 786, 824, 237, 950
1128, 2079, 253, 879, 765
1129, 968, 906, 826, 283
1130, 827, 195, 719, 623
1131, 1030, 960, 392, 1113
1132, 445, 795, 925, 829
1133, 431, 1031, 830, 925
1134, 833, 970, 2094, 948
1135, 952, 834, 1032, 1010
1136, 2112, 1011, 2139, 1618
1137, 288, 892, 1033, 836
1138, 1035, 871, 2100, 2126
1139, 886, 845, 2119, 395
1140, 974, 895, 2076, 846
1141, 975, 10, 837, 1034
1142, 1036, 847, 975, 2077
1143, 2134, 111, 2103, 2114
1144, 849, 760, 196, 701
1145, 909, 1037, 286, 843
1146, 1037, 977, 851, 286
1147, 852, 788, 929, 2127
1148, 972, 978, 278, 842
1149, 856, 855, 726, 602
1150, 979, 856, 64, 1079
1151, 979, 922, 855, 856
1152, 980, 954, 2090, 463
1153, 747, 332, 2083, 860
1154, 890, 2110, 891, 331
1155, 892, 861, 1040, 289
1156, 1121, 862, 1028, 290
1157, 862, 1121, 289, 1040
1158, 1083, 963, 1236, 295
1159, 102, 817, 864, 1236
1160, 865, 965, 2132, 1041
1161, 962, 865, 1041, 296
1162, 866, 1025, 1122, 297
1163, 866, 297, 2132, 965
1164, 1025, 867, 298, 1122
1165, 64, 806, 868, 1079
1166, 871, 154, 838, 2100
1167, 2107, 974, 872, 118
1168, 110, 2103, 873, 943
1169, 68, 759, 874, 967
1170, 879, 1123, 1047, 876
1171, 2180, 1124, 1220, 996
1172, 253, 996, 1123, 879
1173, 218, 1048, 880, 2093
1174, 1069, 881, 949, 1068
1175, 194, 768, 881, 1069
1176, 768, 1022, 882, 2078
1177, 885, 2097, 1049, 2129
1178, 2112, 1618, 1125, 888
1179, 935, 888, 1125, 371
1180, 1126, 889, 1023, 2109
1181, 1050, 889, 1126, 410
1182, 352, 815, 2110, 890
1183, 289, 2120, 1033, 892
1184, 1076, 894, 966, 112
1185, 895, 974, 2107, 1045
1186, 1128, 896, 1024, 119
1187, 1029, 896, 1128, 120
1188, 1129, 897, 1029, 120
1189, 1052, 897, 1129, 121
1190, 1053, 898, 940, 88
1191, 131, 901, 898, 1053
1192, 899, 922, 1054, 2125
1193, 2099, 940, 65, 854
1194, 1034, 900, 79, 1161
1195, 902, 995, 1130, 2189
1196, 902, 254, 904, 268
1197, 249, 1222, 2123, 999
1198, 968, 1055, 2185, 906
1199, 1020, 1132, 1263, 907
1200, 968, 907, 1263, 1055
1201, 908, 2128, 1133, 2164
1202, 275, 1091, 1037, 909
1203, 1039, 911, 1057, 2156
1204, 1134, 953, 456, 914
1205, 1072, 1135, 455, 953
1206, 844, 454, 2124, 916
1207, 832, 461, 969, 917
1208, 911, 917, 450, 1057
1209, 918, 955, 1058, 451
1210, 969, 918, 451, 990
1211, 462, 796, 919, 955
1212, 920, 154, 871, 2101
1213, 1012, 394, 886, 395
1214, 922, 979, 1080, 1054
1215, 218, 2093, 923, 986
1216, 235, 957, 1073, 1001
1217, 770, 924, 234, 2097
1218, 374, 776, 928, 1026
1219, 1078, 1136, 277, 978
1220, 793, 455, 2122, 930
1221, 2188, 1060, 2119, 933
1222, 414, 810, 934, 985
1223, 1015, 1061, 2131, 447
1224, 1061, 1110, 937, 2131
1225, 106, 754, 939, 1081
1226, 940, 2099, 1063, 88
1227, 941, 1127, 113, 1187
1228, 1097, 1217, 942, 1065
1229, 1137, 873, 111, 1051
1230, 173, 998, 1059, 1169
1231, 1046, 197, 875, 198
1232, 944, 2098, 176, 1059
1233, 999, 2102, 1067, 249
1234, 775, 948, 2094, 2092
1235, 155, 988, 1068, 949
1236, 1070, 950, 237, 2113
1237, 453, 1016, 954, 980
1238, 998, 1148, 174, 931
1239, 958, 868, 806, 310
1240, 1074, 1071, 2095, 333
1241, 392, 960, 828, 2080
1242, 353, 869, 960, 1030
1243, 103, 818, 963, 981
1244, 2091, 942, 1217, 1044
1245, 964, 2091, 1044, 2106
1246, 112, 966, 893, 1051
1247, 1051, 893, 967, 1137
1248, 970, 374, 1077, 2115
1249, 2108, 2138, 375, 1008
1250, 270, 840, 971, 2130
1251, 978, 972, 1000, 1078
1252, 2127, 973, 787, 852
1253, 2161, 2160, 1138, 1202
1254, 2114, 2116, 133, 2134
1255, 1021, 977, 274, 2163
1256, 1080, 979, 1079, 1176
1257, 1013, 859, 916, 2124
1258, 982, 1093, 1243, 1415
1259, 991, 982, 1415, 1143
1260, 1012, 1156, 1309, 983
1261, 1116, 1584, 984, 414
1262, 2188, 1584, 396, 1060
1263, 1141, 988, 1066, 152
1264, 1068, 988, 1141, 156
1265, 1142, 250, 2129, 233
1266, 992, 836, 1033, 1144
1267, 133, 2133, 1139, 2134
1268, 1219, 994, 1131, 256
1269, 995, 269, 1352, 1130
1270, 1123, 996, 1220, 1308
1271, 997, 1046, 2169, 1146
1272, 997, 1146, 1147, 176
1273, 1148, 998, 173, 1269
1274, 2123, 1003, 265, 883
1275, 1078, 1000, 263, 2203
1276, 1001, 1073, 1322, 1150
1277, 1002, 1136, 1221, 1151
1278, 1003, 2123, 1222, 1152
1279, 264, 1152, 1198, 1149
1280, 1090, 271, 1223, 1753
1281, 909, 1005, 2161, 275
1282, 1006, 1071, 1173, 313
1283, 1106, 1019, 1153, 1251
1284, 1154, 1007, 353, 1109
1285, 1074, 1007, 1154, 334
1286, 1115, 2182, 1224, 1256
1287, 411, 2092, 1008, 2109
1288, 1009, 1404, 1331, 1515
1289, 1515, 351, 2139, 1009
1290, 427, 1155, 1010, 1032
1291, 2096, 1010, 1155, 1215
1292, 1011, 352, 1009, 2139
1293, 395, 1114, 1156, 1012
1294, 2146, 1120, 2124, 454
1295, 453, 980, 1013, 2154
1296, 1014, 1043, 2162, 1164
1297, 1015, 1108, 1416, 1157
1298, 1061, 1015, 1157, 433
1299, 1017, 1135, 2151, 1225
1300, 1225, 1158, 2145, 1017
1301, 235, 924, 1018, 1092
1302, 2164, 1132, 1020, 908
1303, 2128, 1021, 2163, 1133
1304, 119, 1024, 895, 1045
1305, 2096, 1215, 2117, 443
1306, 1134, 1027, 442, 1212
1307, 391, 1205, 1113, 1309
1308, 1031, 431, 1160, 415
1309, 1111, 428, 1050, 1184
1310, 1161, 79, 1226, 1316
1311, 1093, 1036, 98, 1242
1312, 975, 1034, 1162, 2077
1313, 1038, 913, 449, 1163
1314, 913, 1039, 2156, 449
1315, 1095, 291, 1227, 1305
1316, 291, 1095, 863, 1081
1317, 1043, 1042, 432, 2162
1318, 870, 446, 1042, 1043
1319, 1087, 117, 1228, 1303
1320, 2106, 118, 872, 964
1321, 2136, 1088, 1045, 2107
1322, 2169, 1046, 198, 1268
1323, 1047, 1101, 1165, 2113
1324, 876, 1047, 2113, 237
1325, 218, 986, 219, 1140
1326, 1150, 1166, 234, 1001
1327, 1139, 1051, 111, 2134
1328, 1080, 1176, 1235, 1167
1329, 1063, 2125, 1168, 2158
1330, 1180, 1104, 2185, 1055
1331, 176, 1147, 1169, 1059
1332, 1110, 1061, 433, 1213
1333, 1081, 939, 1186, 291
1334, 2125, 1063, 2099, 899
1335, 1066, 153, 1085, 152
1336, 1103, 1067, 1142, 1266
1337, 1069, 1068, 156, 2144
1338, 1069, 2144, 1172, 194
1339, 219, 986, 1070, 2142
1340, 1074, 333, 959, 1007
1341, 1173, 1071, 1074, 334
1342, 1135, 1072, 441, 2151
1343, 1075, 295, 1236, 864
1344, 134, 1086, 112, 1089
1345, 1076, 113, 1127, 894
1346, 2149, 1077, 1112, 1254
1347, 2115, 1175, 2138, 2108
1348, 1136, 1078, 2203, 1221
1349, 1079, 868, 89, 1176
1350, 1176, 89, 1238, 1235
1351, 939, 1062, 2153, 1186
1352, 1299, 1082, 1218, 293
1353, 1216, 1082, 1299, 104
1354, 1230, 1300, 1084, 2155
1355, 1238, 1084, 1300, 90
1356, 1191, 2186, 1301, 1085
1357, 135, 1302, 1285, 1369
1358, 1239, 2137, 1302, 135
1359, 2135, 1178, 118, 2106
1360, 1324, 2165, 2136, 1178
1361, 2165, 1240, 1088, 2136
1362, 1089, 1139, 2133, 1145
1363, 1090, 1753, 1241, 2187
1364, 1131, 2187, 1241, 256
1365, 1202, 261, 1340, 1279
1366, 1304, 1094, 1234, 2195
1367, 1244, 1094, 1304, 2196
1368, 1095, 1305, 2172, 290
1369, 1306, 1096, 1232, 115
1370, 1179, 1096, 1306, 72
1371, 1098, 1229, 2201, 1307
1372, 1301, 2186, 1433, 130
1373, 1161, 1245, 1162, 1034
1374, 98, 1099, 2111, 1246
1375, 122, 1247, 1100, 1189
1376, 79, 900, 1100, 1247
1377, 1165, 220, 1248, 2142
1378, 1419, 1249, 1102, 1140
1379, 1103, 232, 2215, 1250
1380, 1104, 1180, 1326, 2258
1381, 1223, 1104, 2258, 257
1382, 1105, 1208, 1345, 325
1383, 1234, 1105, 325, 2195
1384, 308, 1106, 1251, 1366
1385, 1107, 2193, 1323, 2229
1386, 1163, 449, 1274, 1317
1387, 1252, 448, 1163, 1317
1388, 1204, 1210, 335, 2209
1389, 353, 1030, 2152, 1109
1390, 1253, 1111, 1184, 409
1391, 1254, 1112, 371, 1260
1392, 2149, 1254, 2199, 370
1393, 1205, 391, 1310, 354
1394, 1114, 1311, 1255, 1156
1395, 1224, 376, 1583, 1256
1396, 1342, 1116, 1206, 1413
1397, 1117, 1182, 1408, 1328
1398, 1406, 1177, 1117, 1328
1399, 1183, 1329, 2227, 1118
1400, 1182, 1118, 2227, 1408
1401, 1214, 2192, 1349, 2226
1402, 1183, 1119, 1409, 1329
1403, 1372, 2191, 1272, 2225
1404, 2192, 2154, 1120, 1372
1405, 1258, 1122, 298, 1367
1406, 2190, 2189, 1259, 1548
1407, 238, 1220, 1124, 1290
1408, 1188, 1129, 120, 1333
1409, 1392, 1259, 2189, 1130
1410, 2187, 1131, 270, 2130
1411, 273, 2205, 1312, 2244
1412, 1133, 2163, 1264, 2205
1413, 273, 2164, 1133, 2205
1414, 2204, 1151, 2233, 262
1415, 1265, 219, 2142, 1248
1416, 1265, 1419, 1140, 219
1417, 2129, 250, 989, 885
1418, 298, 1460, 2143, 1367
1419, 867, 1143, 1460, 298
1420, 1121, 1257, 2120, 289
1421, 993, 1267, 1145, 2133
1422, 134, 1089, 1145, 2168
1423, 1147, 1146, 177, 1197
1424, 1269, 173, 1196, 2228
1425, 1270, 1149, 1198, 247
1426, 1166, 1150, 1181, 1275
1427, 276, 1002, 1151, 2204
1428, 1313, 1200, 262, 1425
1429, 1314, 2218, 248, 1424
1430, 1153, 1006, 313, 1251
1431, 1315, 1209, 2173, 426
1432, 391, 1309, 1156, 1255
1433, 1271, 1157, 1416, 1493
1434, 2146, 2145, 1158, 2191
1435, 440, 2224, 1158, 1225
1436, 1159, 194, 1172, 1194
1437, 1174, 1195, 214, 1322
1438, 2113, 1165, 2142, 1070
1439, 1166, 1275, 2150, 1049
1440, 1190, 1388, 1405, 1356
1441, 1319, 1299, 293, 1276
1442, 1299, 1319, 1231, 104
1443, 1320, 1306, 115, 1277
1444, 72, 1306, 1320, 1233
1445, 1194, 1172, 1287, 193
1446, 1204, 1321, 334, 1154
1447, 1073, 215, 1174, 1322
1448, 370, 1499, 1671, 2184
1449, 1406, 1323, 2193, 1177
1450, 1178, 2135, 1407, 1324
1451, 1325, 1326, 1180, 272
1452, 1327, 1181, 214, 1380
1453, 1256, 1583, 410, 1126
1454, 1331, 1404, 1185, 2172
1455, 1185, 331, 1144, 2121
1456, 1280, 1332, 2153, 292
1457, 1239, 1187, 113, 2137
1458, 1334, 1188, 1378, 143
1459, 121, 1334, 1335, 1189
1460, 1336, 1167, 1235, 1360
1461, 2242, 2200, 1356, 1405
1462, 1192, 1286, 1754, 1337
1463, 1193, 1192, 1337, 157
1464, 157, 1410, 1287, 1193
1465, 1194, 193, 2177, 1195
1466, 2177, 1380, 214, 1195
1467, 1196, 173, 1169, 2223
1468, 172, 1196, 2223, 1338
1469, 1308, 1411, 1199, 1101
1470, 1339, 1199, 1411, 221
1471, 1521, 1340, 1444, 2273
1472, 1368, 1264, 2163, 274
1473, 2161, 1202, 1279, 275
1474, 1203, 1321, 1412, 2210
1475, 1321, 1204, 2209, 1412
1476, 2152, 1205, 354, 1109
1477, 1206, 415, 1295, 1413
1478, 1295, 1207, 1343, 1446
1479, 1208, 1344, 324, 1345
1480, 1253, 2140, 427, 1111
1481, 1210, 2181, 1346, 335
1482, 1671, 1211, 2183, 2184
1483, 1211, 1671, 1224, 2182
1484, 426, 1414, 1347, 1315
1485, 1213, 433, 1348, 2230
1486, 1318, 1273, 1164, 2162
1487, 453, 2154, 2192, 1214
1488, 2192, 1372, 2225, 1349
1489, 2117, 442, 1027, 443
1490, 2117, 1215, 1315, 1347
1491, 1237, 1359, 294, 1083
1492, 1351, 1219, 256, 1391
1493, 1219, 255, 1352, 994
1494, 1308, 1220, 238, 1411
1495, 1270, 1292, 263, 1149
1496, 2233, 1151, 1221, 2203
1497, 248, 1152, 1222, 1291
1498, 1241, 1753, 2259, 1353
1499, 1330, 410, 1583, 1514
1500, 2194, 1225, 2151, 441
1501, 79, 1247, 1282, 1226
1502, 1316, 1226, 80, 1436
1503, 1355, 1186, 2153, 1332
1504, 1281, 1097, 2118, 1358
1505, 2158, 1229, 88, 1063
1506, 2105, 1358, 2118, 116
1507, 1524, 1281, 1358, 138
1508, 1302, 134, 2168, 1285
1509, 1360, 1235, 1238, 90
1510, 1240, 141, 1361, 1261
1511, 1242, 98, 1246, 1278
1512, 1362, 1243, 300, 1382
1513, 299, 1415, 1243, 1362
1514, 2159, 1257, 290, 2172
1515, 2111, 1162, 1245, 1298
1516, 2208, 1288, 2249, 200
1517, 1249, 2174, 2141, 1102
1518, 2178, 1366, 1251, 313
1519, 1106, 308, 1230, 2155
1520, 1416, 1252, 434, 1493
1521, 1108, 448, 1252, 1416
1522, 1253, 1402, 1296, 2140
1523, 2149, 370, 2184, 1175
1524, 1260, 371, 1125, 1618
1525, 1258, 1367, 2167, 1401
1526, 1548, 1259, 1392, 2262
1527, 1333, 1261, 1361, 142
1528, 120, 1128, 1261, 1333
1529, 1417, 258, 1262, 2244
1530, 1264, 1368, 2243, 1418
1531, 1364, 1419, 1265, 2208
1532, 2150, 1373, 2216, 1266
1533, 1103, 1266, 2216, 232
1534, 1267, 1269, 2168, 1145
1535, 1268, 177, 1146, 2169
1536, 2168, 1269, 2228, 1285
1537, 1370, 1292, 1270, 1463
1538, 1348, 1271, 1420, 2281
1539, 2264, 2224, 440, 1371
1540, 1274, 1107, 2229, 435
1541, 1317, 1274, 435, 1437
1542, 1276, 292, 1170, 1319
1543, 1277, 1377, 1284, 2104
1544, 301, 1506, 1523, 1375
1545, 1280, 1383, 1526, 329
1546, 1281, 139, 1228, 117
1547, 123, 1421, 1282, 1386
1548, 1357, 1283, 1376, 136
1549, 1828, 1284, 1377, 1756
1550, 1358, 2105, 1422, 138
1551, 2214, 220, 1199, 1339
1552, 1364, 2208, 200, 199
1553, 1289, 177, 1268, 2176
1554, 1548, 1423, 1290, 2190
1555, 1291, 1381, 1424, 248
1556, 1425, 1292, 1370, 2276
1557, 262, 2233, 1292, 1425
1558, 326, 1426, 1293, 2196
1559, 1293, 327, 1359, 1237
1560, 1260, 1294, 2199, 1254
1561, 1446, 2232, 1413, 1295
1562, 1296, 408, 1428, 2173
1563, 1414, 1297, 2147, 1347
1564, 1387, 1429, 1298, 1245
1565, 97, 1246, 2111, 1298
1566, 1459, 1374, 308, 1366
1567, 1582, 130, 1469, 129
1568, 1086, 134, 1302, 2137
1569, 1430, 139, 1507, 1592
1570, 1331, 2172, 1305, 1431
1571, 87, 1432, 1307, 2201
1572, 1307, 130, 1433, 1098
1573, 1434, 1311, 396, 1500
1574, 1255, 1311, 390, 1403
1575, 1417, 2244, 1312, 259
1576, 261, 1200, 1313, 1395
1577, 2230, 1400, 2197, 1213
1578, 1273, 1318, 2231, 416
1579, 1171, 1320, 1277, 2104
1580, 436, 2271, 1323, 1406
1581, 2229, 1323, 2271, 1510
1582, 140, 1511, 1324, 1407
1583, 2179, 2165, 1324, 1511
1584, 258, 2275, 1325, 1262
1585, 2275, 1438, 1326, 1325
1586, 1439, 1327, 1380, 192
1587, 2270, 2269, 2324, 1616
1588, 1406, 1328, 2270, 436
1589, 1408, 2227, 437, 2269
1590, 1440, 1330, 1514, 377
1591, 1355, 1332, 1385, 2220
1592, 1441, 1335, 1390, 144
1593, 122, 1189, 1335, 1441
1594, 1167, 1336, 1190, 2157
1595, 1410, 2217, 193, 1287
1596, 1339, 1479, 1394, 2214
1597, 1340, 261, 1395, 1444
1598, 1201, 1279, 1340, 1521
1599, 1341, 1397, 1366, 2178
1600, 1500, 2198, 1342, 397
1601, 1343, 416, 1445, 398
1602, 297, 1344, 1208, 2132
1603, 1447, 1345, 324, 1547
1604, 1346, 336, 1398, 335
1605, 2266, 2265, 1448, 2318
1606, 1409, 2226, 438, 2267
1607, 1350, 1359, 327, 1452
1608, 1452, 1585, 1384, 1350
1609, 1392, 255, 1449, 2262
1610, 255, 1219, 1351, 1449
1611, 1391, 1353, 1516, 240
1612, 441, 2148, 1450, 2194
1613, 1517, 1354, 2194, 1450
1614, 1355, 1227, 291, 1186
1615, 1356, 2200, 2158, 1168
1616, 1357, 136, 1518, 1389
1617, 1389, 1518, 1756, 1377
1618, 2345, 2256, 1453, 1621
1619, 1362, 1382, 321, 1520
1620, 1456, 1363, 97, 1541
1621, 199, 200, 1457, 1365
1622, 1365, 1457, 1458, 2207
1623, 178, 2211, 2207, 1458
1624, 1459, 1366, 1397, 307
1625, 1368, 1201, 1521, 2243
1626, 2216, 1373, 1461, 232
1627, 2260, 2228, 1196, 172
1628, 2263, 1369, 2260, 1443
1629, 1451, 1371, 440, 1354
1630, 1371, 1451, 2309, 1522
1631, 2191, 1372, 1120, 2146
1632, 1373, 213, 1465, 1461
1633, 1374, 1459, 1552, 1550
1634, 1523, 1506, 320, 1613
1635, 1462, 1475, 1376, 135
1636, 1379, 1582, 1661, 1779
1637, 231, 1424, 1381, 1484
1638, 1585, 1526, 1383, 1384
1639, 1385, 329, 1626, 1527
1640, 2220, 330, 1305, 1227
1641, 1470, 1587, 1429, 1387
1642, 1405, 1472, 1588, 2242
1643, 1388, 1190, 1336, 2256
1644, 1391, 240, 1529, 1351
1645, 1474, 1393, 2239, 171
1646, 2290, 1530, 2249, 1394
1647, 1396, 1508, 2272, 1589
1648, 1396, 1589, 1531, 326
1649, 2237, 1691, 1760, 1498
1650, 1491, 2222, 355, 1656
1651, 1310, 1399, 2181, 354
1652, 2312, 1611, 2350, 1492
1653, 1496, 323, 1590, 2254
1654, 1403, 390, 1607, 1509
1655, 1303, 1407, 2135, 1087
1656, 2226, 1409, 1119, 1214
1657, 2245, 1410, 157, 1442
1658, 2236, 2210, 1412, 1498
1659, 1342, 1413, 2232, 397
1660, 1428, 1504, 426, 2173
1661, 1297, 1414, 425, 2219
1662, 1143, 1415, 299, 1460
1663, 259, 2274, 1534, 2315
1664, 1562, 1536, 124, 1677
1665, 1828, 1537, 1422, 1284
1666, 1569, 1533, 1565, 222
1667, 1482, 230, 2234, 1314
1668, 1426, 326, 1531, 1591
1669, 2199, 1427, 1499, 370
1670, 408, 1502, 1540, 1428
1671, 1541, 1429, 1587, 96
1672, 97, 1298, 1429, 1541
1673, 1430, 1592, 1542, 140
1674, 130, 1307, 1432, 1469
1675, 1576, 397, 1672, 389
1676, 2218, 1435, 247, 1198
1677, 80, 1471, 1663, 1436
1678, 1544, 1437, 435, 1630
1679, 1574, 2280, 434, 1437
1680, 1438, 1545, 2258, 1326
1681, 213, 1327, 1439, 1465
1682, 351, 1515, 1331, 1468
1683, 1586, 1546, 1829, 1473
1684, 1442, 1664, 2306, 1563
1685, 1462, 2339, 1474, 1475
1686, 172, 2340, 1443, 2260
1687, 416, 2231, 2282, 1445
1688, 1446, 1343, 398, 2283
1689, 2283, 1501, 2232, 1446
1690, 325, 1615, 1508, 2195
1691, 1464, 1448, 2265, 439
1692, 1449, 1351, 1529, 2311
1693, 1450, 1297, 2219, 1517
1694, 327, 1538, 1549, 1452
1695, 1585, 1452, 1549, 328
1696, 1595, 1472, 1519, 1643
1697, 1596, 1454, 1466, 166
1698, 142, 1361, 1454, 1551
1699, 299, 1362, 1455, 1553
1700, 1572, 302, 1490, 1456
1701, 1484, 2238, 1554, 2287
1702, 1462, 135, 1369, 2263
1703, 246, 2307, 1370, 1463
1704, 1464, 423, 1717, 1634
1705, 212, 1461, 1465, 1467
1706, 1596, 166, 2335, 1665
1707, 1666, 1559, 191, 1780
1708, 350, 1294, 1468, 1497
1709, 2171, 1755, 1593, 1663
1710, 1663, 1593, 1470, 1436
1711, 1471, 80, 1421, 1562
1712, 1388, 2256, 2345, 1519
1713, 1667, 1588, 1472, 1595
1714, 1597, 1473, 1829, 145
1715, 1586, 1386, 122, 1441
1716, 1376, 1475, 2257, 136
1717, 1410, 2245, 1476, 2217
1718, 1477, 192, 1380, 2177
1719, 1478, 1439, 192, 1599
1720, 1569, 1600, 221, 1533
1721, 1394, 1479, 201, 2290
1722, 1530, 1480, 200, 2249
1723, 1567, 179, 2285, 1566
1724, 178, 1458, 1481, 1567
1725, 1601, 1482, 231, 1602
1726, 230, 2305, 1486, 2234
1727, 258, 1417, 1487, 2316
1728, 229, 2305, 1603, 1707
1729, 1604, 1556, 1487, 2315
1730, 1558, 1488, 2342, 244
1731, 1395, 1313, 1489, 2308
1732, 320, 1506, 1692, 1693
1733, 2313, 1670, 1696, 1581
1734, 1445, 2312, 1492, 398
1735, 1494, 1652, 1607, 390
1736, 2202, 1608, 2166, 1495
1737, 323, 2167, 2166, 1608
1738, 344, 2254, 1590, 2235
1739, 1547, 1496, 2254, 345
1740, 314, 2236, 1498, 1760
1741, 1224, 1671, 1713, 376
1742, 1581, 1609, 2283, 398
1743, 1662, 1610, 1502, 1402
1744, 1662, 1402, 409, 1440
1745, 1503, 2282, 2231, 1400
1746, 1505, 2267, 2318, 2336
1747, 1624, 1614, 1524, 138
1748, 1592, 1507, 168, 1701
1749, 1509, 355, 2222, 1399
1750, 435, 2229, 1510, 1630
1751, 1511, 140, 1542, 1555
1752, 1640, 1575, 1512, 2374
1753, 2268, 437, 2227, 1329
1754, 376, 1617, 1514, 1583
1755, 1618, 2139, 351, 1260
1756, 2248, 1620, 2219, 425
1757, 170, 1673, 1566, 2285
1758, 137, 1756, 1518, 1645
1759, 1621, 91, 1716, 1643
1760, 260, 2243, 1521, 2273
1761, 321, 1382, 1523, 1613
1762, 143, 1378, 1525, 1557
1763, 328, 1625, 1526, 1585
1764, 1579, 349, 2299, 1539
1765, 1675, 1528, 1557, 164
1766, 1390, 1528, 2221, 144
1767, 1598, 1474, 171, 2240
1768, 1591, 1531, 347, 1700
1769, 307, 1397, 1532, 1573
1770, 1533, 221, 1411, 238
1771, 1558, 1682, 260, 2273
1772, 1676, 1604, 2315, 1534
1773, 1757, 1651, 2371, 1535
1774, 1757, 1535, 2314, 418
1775, 1644, 123, 1473, 1597
1776, 1537, 1828, 1629, 1646
1777, 1624, 1537, 1646, 169
1778, 1658, 1540, 1502, 1610
1779, 407, 1612, 1540, 1658
1780, 1561, 1543, 86, 1684
1781, 1588, 1543, 87, 2242
1782, 2279, 1574, 1437, 1544
1783, 1678, 2298, 2341, 1619
1784, 1631, 1546, 144, 2221
1785, 1829, 1546, 1631, 1726
1786, 1547, 345, 1632, 1447
1787, 91, 1621, 1453, 1550
1788, 1633, 307, 1573, 1635
1789, 1550, 1552, 2348, 91
1790, 1460, 299, 1553, 2143
1791, 211, 2287, 1679, 1758
1792, 1448, 1464, 1634, 2336
1793, 167, 1680, 1555, 1542
1794, 2384, 1681, 1556, 1604
1795, 163, 1627, 1675, 1783
1796, 1676, 1534, 1682, 1836
1797, 1559, 1666, 1758, 1679
1798, 1560, 422, 1683, 421
1799, 158, 1563, 1685, 2291
1800, 1476, 158, 2291, 1564
1801, 1629, 137, 1673, 170
1802, 1687, 2285, 179, 1688
1803, 1568, 1688, 179, 2301
1804, 1600, 1569, 1647, 1704
1805, 245, 1759, 1708, 1605
1806, 1689, 1571, 377, 1714
1807, 1572, 96, 2175, 1690
1808, 2327, 2322, 1761, 401
1809, 2280, 1574, 418, 1420
1810, 436, 1512, 1575, 2271
1811, 1636, 1630, 1510, 2323
1812, 1434, 1500, 397, 1576
1813, 1649, 1577, 315, 1773
1814, 1694, 1578, 348, 1793
1815, 1579, 1527, 1626, 349
1816, 1654, 1767, 1625, 328
1817, 387, 1893, 388, 2331
1818, 1696, 2295, 1609, 1581
1819, 1587, 1642, 1697, 96
1820, 1531, 1589, 2304, 347
1821, 323, 1608, 2235, 1590
1822, 1699, 345, 2254, 344
1823, 2353, 1594, 1485, 2316
1824, 242, 1702, 1594, 2353
1825, 1735, 1595, 1643, 1770
1826, 1595, 1735, 1762, 1667
1827, 2240, 171, 1566, 1673
1828, 1599, 2246, 1686, 1703
1829, 201, 1479, 1600, 1704
1830, 1706, 2317, 1601, 1602
1831, 1602, 231, 1484, 2287
1832, 211, 1706, 1602, 2287
1833, 1705, 1603, 2305, 230
1834, 1603, 1705, 1763, 209
1835, 243, 2384, 1604, 1676
1836, 1708, 1709, 2342, 1605
1837, 1744, 337, 1650, 1606
1838, 336, 1491, 1606, 1650
1839, 1656, 1607, 1652, 356
1840, 1655, 2202, 322, 1710
1841, 2331, 1653, 2295, 1696
1842, 2371, 1503, 417, 1535
1843, 425, 1504, 1612, 2248
1844, 1613, 1741, 1641, 321
1845, 169, 1712, 1614, 1624
1846, 1615, 346, 2272, 1508
1847, 1714, 1617, 1729, 368
1848, 1619, 1638, 2367, 1765
1849, 1619, 2346, 1516, 1678
1850, 1620, 424, 1517, 2219
1851, 1710, 1622, 1749, 343
1852, 322, 1455, 1622, 1710
1853, 1711, 1623, 424, 1620
1854, 1766, 1623, 1711, 406
1855, 329, 1526, 1625, 1626
1856, 1627, 1639, 1631, 2221
1857, 1736, 170, 2285, 1687
1858, 419, 1544, 1630, 1636
1859, 1720, 1633, 1635, 92
1860, 2348, 1552, 1633, 1720
1861, 1635, 306, 1768, 92
1862, 1830, 1743, 2369, 2387
1863, 1637, 341, 2213, 1741
1864, 1702, 1638, 241, 1594
1865, 1575, 1640, 420, 2323
1866, 1832, 1749, 342, 1927
1867, 1697, 1642, 1733, 1838
1868, 1721, 1771, 2170, 1644
1869, 2278, 222, 1565, 239
1870, 1647, 1772, 202, 1704
1871, 1704, 1833, 2319, 201
1872, 1692, 1490, 302, 1792
1873, 1650, 1747, 1691, 336
1874, 400, 1781, 1651, 1757
1875, 2350, 1651, 1781, 399
1876, 388, 1834, 1653, 2331
1877, 1746, 1654, 2296, 1857
1878, 1767, 1654, 1746, 349
1879, 343, 1775, 1655, 1710
1880, 2235, 1655, 1775, 344
1881, 1744, 1656, 356, 1856
1882, 1657, 407, 1777, 1776
1883, 2327, 1835, 2355, 1659
1884, 422, 1634, 1660, 1683
1885, 1778, 1661, 2261, 1731
1886, 151, 1779, 1661, 1778
1887, 1663, 1471, 81, 2171
1888, 1731, 128, 1804, 1778
1889, 150, 2306, 1664, 151
1890, 1724, 1665, 1815, 184
1891, 165, 1596, 1665, 1724
1892, 1780, 191, 1703, 1808
1893, 1666, 190, 1862, 1758
1894, 1667, 86, 1543, 1588
1895, 1669, 245, 1489, 2276
1896, 388, 1893, 1782, 1871
1897, 1499, 369, 1713, 1671
1898, 2295, 1672, 1501, 1609
1899, 421, 1616, 2324, 1560
1900, 1674, 164, 1557, 1525
1901, 244, 1836, 1682, 1558
1902, 1678, 1516, 1353, 2259
1903, 1554, 212, 1679, 2287
1904, 166, 1555, 1680, 2335
1905, 1680, 167, 1785, 1805
1906, 2384, 243, 1786, 1806
1907, 242, 1806, 1787, 1702
1908, 1836, 244, 1740, 1899
1909, 1561, 1684, 2261, 129
1910, 1788, 1685, 2306, 150
1911, 1727, 1686, 2291, 1685
1912, 1736, 1687, 1789, 2241
1913, 1689, 1730, 1790, 378
1914, 1820, 303, 1742, 1690
1915, 1760, 1691, 315, 1577
1916, 1694, 1793, 367, 1837
1917, 1794, 2250, 1857, 2296
1918, 369, 1580, 1695, 1750
1919, 1791, 1697, 1838, 95
1920, 1795, 1826, 2297, 2292
1921, 2304, 1826, 2330, 347
1922, 1797, 1699, 344, 1775
1923, 1796, 1700, 347, 2330
1924, 1841, 1785, 167, 1701
1925, 1737, 1833, 1894, 2028
1926, 1759, 245, 1669, 2349
1927, 1709, 1708, 1725, 227
1928, 2382, 1842, 1899, 1740
1929, 2241, 1843, 1712, 169
1930, 1730, 368, 1837, 367
1931, 223, 1738, 1715, 1765
1932, 1715, 240, 1516, 2346
1933, 1720, 1716, 91, 2348
1934, 1845, 1735, 1770, 1866
1935, 405, 1752, 1717, 1766
1936, 1798, 1718, 345, 1699
1937, 1846, 1795, 2292, 1718
1938, 1847, 1719, 1724, 184
1939, 164, 1674, 1719, 1801
1940, 1720, 92, 1802, 1716
1941, 1726, 1849, 145, 1829
1942, 146, 1721, 1809, 1912
1943, 224, 2383, 1848, 1879
1944, 228, 1739, 2378, 1853
1945, 145, 1849, 1931, 1809
1946, 1911, 1808, 1727, 1814
1947, 1764, 1728, 1810, 2387
1948, 1790, 1730, 367, 2251
1949, 1755, 2171, 1896, 1850
1950, 1732, 81, 1677, 1813
1951, 1733, 1755, 1850, 1897
1952, 1897, 1881, 1838, 1733
1953, 1735, 1845, 1851, 1762
1954, 1812, 1734, 85, 1915
1955, 1770, 1643, 1716, 1802
1956, 1882, 1898, 2373, 2380
1957, 169, 1646, 1736, 2241
1958, 2028, 1894, 1986, 181
1959, 1737, 1648, 2319, 1833
1960, 1628, 1715, 1738, 2278
1961, 1772, 222, 1852, 1884
1962, 1854, 1668, 229, 1707
1963, 1899, 1842, 1786, 243
1964, 1641, 1741, 2213, 342
1965, 1742, 1818, 1792, 302
1966, 1743, 1830, 1900, 1761
1967, 378, 1790, 1874, 1745
1968, 1777, 1745, 379, 1825
1969, 349, 1746, 2300, 2299
1970, 340, 1859, 1748, 1819
1971, 1746, 1857, 1695, 2300
1972, 368, 1729, 1750, 2250
1973, 1861, 1752, 405, 2375
1974, 1753, 1223, 257, 2259
1975, 1779, 1754, 1286, 1379
1976, 151, 1664, 1754, 1779
1977, 1732, 1896, 2171, 81
1978, 1828, 1756, 137, 1629
1979, 1757, 418, 1659, 2355
1980, 1668, 1759, 2349, 1570
1981, 419, 1743, 1761, 2322
1982, 2317, 1763, 1705, 1601
1983, 349, 1626, 1625, 1767
1984, 162, 1639, 1769, 1865
1985, 146, 1867, 1771, 1721
1986, 1872, 125, 1784, 124
1987, 305, 1821, 1887, 2044
1988, 306, 1649, 1773, 1821
1989, 2284, 1871, 2332, 357
1990, 356, 1652, 1774, 1824
1991, 1797, 1775, 1868, 363
1992, 1777, 407, 1658, 1745
1993, 1780, 1808, 1911, 2031
1994, 400, 2376, 2372, 1781
1995, 1834, 388, 1871, 2284
1996, 2170, 1872, 124, 1536
1997, 1813, 1784, 125, 1916
1998, 1899, 243, 1676, 1836
1999, 1786, 226, 2389, 1806
2000, 225, 1722, 1787, 2386
2001, 180, 2286, 1789, 2303
2002, 1843, 2241, 1789, 2286
2003, 2251, 1906, 1874, 1790
2004, 96, 1697, 1791, 2175
2005, 1820, 1791, 95, 1921
2006, 1792, 319, 1693, 1692
2007, 1837, 368, 2250, 1794
2008, 1857, 2250, 1750, 1695
2009, 1795, 365, 2334, 1826
2010, 363, 1907, 1839, 1797
2011, 1841, 1799, 181, 1928
2012, 2034, 1800, 1862, 1936
2013, 2356, 1876, 92, 1768
2014, 2380, 1908, 2368, 1882
2015, 1876, 2356, 1803, 2366
2016, 1804, 128, 1909, 1873
2017, 183, 1723, 1805, 1904
2018, 2386, 2389, 1910, 1885
2019, 1806, 2389, 2386, 1787
2020, 1807, 163, 1783, 1903
2021, 1905, 1959, 1911, 1814
2022, 403, 1913, 2388, 1810
2023, 1830, 2388, 1901, 1900
2024, 1832, 1811, 343, 1749
2025, 1917, 190, 2031, 159
2026, 1816, 209, 1918, 1975
2027, 1817, 1853, 1932, 2385
2028, 1963, 1818, 1920, 318
2029, 1821, 305, 1877, 2338
2030, 316, 1887, 1822, 2337
2031, 2337, 315, 1691, 1747
2032, 1922, 1823, 2021, 2056
2033, 1869, 1825, 380, 1938
2034, 1970, 1924, 2351, 1998
2035, 2330, 1826, 2334, 366
2036, 1906, 1925, 1827, 1874
2037, 1831, 1879, 204, 1960
2038, 2354, 1831, 1926, 223
2039, 1833, 1704, 202, 1894
2040, 1971, 2372, 2376, 2381
2041, 2355, 1835, 2381, 2376
2042, 1798, 1839, 364, 2326
2043, 367, 1793, 1840, 2251
2044, 1919, 1886, 2382, 227
2045, 1786, 1842, 2390, 226
2046, 1844, 1843, 2286, 180
2047, 2028, 1844, 180, 1737
2048, 1799, 1844, 2028, 181
2049, 1898, 1882, 1972, 1982
2050, 85, 1734, 1762, 1851
2051, 1846, 2326, 2352, 1929
2052, 1847, 184, 2379, 1930
2053, 1879, 1848, 1945, 204
2054, 2383, 224, 2377, 225
2055, 1973, 2247, 1880, 1979
2056, 1912, 1809, 1931, 161
2057, 1897, 1850, 2020, 1955
2058, 1881, 1897, 1955, 2024
2059, 1884, 1852, 1926, 203
2060, 1975, 2378, 1739, 1854
2061, 208, 1932, 1853, 2378
2062, 1927, 1855, 1964, 361
2063, 342, 2213, 1855, 1927
2064, 337, 1744, 1856, 1888
2065, 1856, 356, 1824, 1889
2066, 1858, 316, 2337, 1747
2067, 1859, 340, 1933, 1976
2068, 1892, 1860, 404, 1861
2069, 1977, 1934, 1860, 1892
2070, 2375, 405, 1864, 2343
2071, 190, 1917, 1936, 1862
2072, 1951, 2034, 1936, 2037
2073, 1863, 210, 1875, 1941
2074, 1869, 1864, 406, 1776
2075, 1978, 2343, 1938, 2344
2076, 1802, 92, 1876, 1866
2077, 1870, 1971, 2021, 1823
2078, 1782, 1939, 2332, 1871
2079, 2212, 1771, 1867, 147
2080, 1940, 1873, 1909, 127
2081, 1875, 189, 2000, 1941
2082, 1875, 210, 1800, 2034
2083, 2362, 1903, 185, 1949
2084, 1943, 1908, 2366, 1803
2085, 2338, 1877, 2356, 1768
2086, 1877, 305, 1980, 93
2087, 1878, 341, 1859, 1976
2088, 1973, 1979, 2023, 2252
2089, 1931, 1973, 2252, 161
2090, 2025, 1957, 147, 2006
2091, 2333, 1884, 203, 1988
2092, 1995, 1886, 1919, 207
2093, 226, 1992, 1910, 2389
2094, 1887, 316, 1967, 2044
2095, 1967, 317, 2026, 2044
2096, 2040, 2027, 1963, 318
2097, 1819, 2027, 1983, 340
2098, 1984, 1890, 361, 2047
2099, 1985, 401, 1965, 2043
2100, 1891, 2013, 1971, 2381
2101, 1977, 1892, 382, 2018
2102, 1966, 1893, 387, 2032
2103, 202, 2333, 1986, 1894
2104, 1895, 2008, 1948, 2379
2105, 1815, 1895, 2379, 184
2106, 1896, 1732, 82, 1974
2107, 1898, 85, 1851, 2373
2108, 1993, 2029, 402, 1913
2109, 186, 1902, 1807, 1942
2110, 1987, 1902, 186, 2363
2111, 1942, 1807, 1903, 2362
2112, 1904, 182, 1988, 2004
2113, 2288, 1906, 2251, 1840
2114, 366, 1925, 1906, 2288
2115, 1907, 363, 1989, 2017
2116, 2030, 2302, 2058, 2068
2117, 128, 1915, 1991, 1909
2118, 1992, 226, 2390, 206
2119, 1934, 1913, 403, 1860
2120, 1913, 1934, 1996, 1993
2121, 1989, 1914, 2018, 382
2122, 363, 1868, 1914, 1989
2123, 1982, 1915, 85, 1898
2124, 2049, 1954, 1994, 126
2125, 2034, 1951, 189, 1875
2126, 1937, 1918, 209, 2361
2127, 1920, 2015, 1968, 318
2128, 1921, 95, 1981, 2012
2129, 1923, 379, 1827, 1925
2130, 2334, 1924, 1925, 366
2131, 1924, 2334, 365, 2351
2132, 2328, 1988, 182, 1928
2133, 1990, 2357, 2352, 364
2134, 1949, 1930, 2009, 206
2135, 185, 1847, 1930, 1949
2136, 1973, 1931, 1849, 2247
2137, 208, 2010, 2059, 1961
2138, 1969, 1935, 381, 2017
2139, 1979, 1997, 188, 2023
2140, 1970, 1998, 380, 1923
2141, 1956, 1943, 2002, 2302
2142, 206, 2009, 1947, 1992
2143, 206, 1995, 2035, 1949
2144, 2321, 1950, 2036, 148
2145, 2037, 1936, 1917, 159
2146, 1951, 160, 2007, 189
2147, 2039, 2053, 2037, 159
2148, 1984, 1953, 362, 1890
2149, 2020, 1974, 2045, 2071
2150, 82, 1916, 1954, 2255
2151, 2302, 2030, 2022, 1956
2152, 1981, 1881, 2024, 94
2153, 2072, 2060, 2071, 2045
2154, 1972, 1882, 2022, 2038
2155, 2061, 1957, 2025, 148
2156, 1994, 1957, 2061, 126
2157, 161, 2252, 2062, 1958
2158, 2039, 2320, 2025, 2006
2159, 2004, 1960, 204, 1946
2160, 187, 2059, 2010, 1997
2161, 2310, 2042, 2011, 1968
2162, 2029, 2043, 1965, 402
2163, 2032, 387, 1922, 2067
2164, 358, 1939, 1966, 2032
2165, 2044, 2026, 2014, 305
2166, 1929, 2357, 2351, 365
2167, 2372, 1971, 1870, 2364
2168, 1982, 1972, 2365, 2005
2169, 1882, 2368, 1956, 2022
2170, 2045, 2255, 83, 2072
2171, 2378, 1975, 2010, 208
2172, 381, 1935, 1978, 2344
2173, 2343, 1978, 1935, 2375
2174, 304, 2253, 2014, 2026
2175, 2012, 1981, 94, 2050
2176, 358, 2063, 1999, 1939
2177, 1889, 357, 2347, 338
2178, 2013, 1985, 385, 2057
2179, 1928, 181, 1986, 2328
2180, 186, 2001, 2048, 2363
2181, 382, 1969, 2017, 1989
2182, 1990, 381, 2344, 2357
2183, 1995, 206, 2390, 1886
2184, 384, 2029, 1993, 2019
2185, 1918, 1937, 188, 1997
2186, 1998, 2351, 2357, 2344
2187, 2054, 339, 2063, 358
2188, 2003, 2002, 93, 1980
2189, 2024, 1955, 2068, 2058
2190, 2058, 2003, 94, 2024
2191, 2064, 84, 2069, 2052
2192, 1991, 2005, 2064, 127
2193, 2065, 127, 2064, 2052
2194, 2053, 2039, 2006, 1952
2195, 2007, 160, 1958, 2062
2196, 2008, 1945, 205, 1948
2197, 2059, 187, 1987, 2363
2198, 2066, 2011, 2042, 338
2199, 2027, 2040, 339, 1983
2200, 2050, 94, 2003, 1980
2201, 2253, 2012, 2050, 2014
2202, 2057, 385, 2051, 2329
2203, 386, 1971, 2013, 2057
2204, 2015, 1962, 2253, 304
2205, 304, 2026, 317, 2015
2206, 359, 1933, 2016, 2289
2207, 2056, 2021, 386, 2070
2208, 2023, 2000, 2062, 2252
2209, 2060, 2030, 2068, 2071
2210, 2061, 148, 2036, 1944
2211, 2029, 384, 2055, 2043
2212, 2071, 2068, 1955, 2020
2213, 2056, 2070, 359, 2289
2214, 2329, 2051, 360, 2033
2215, 2001, 1995, 207, 2048
2216, 160, 1951, 2037, 2053
2217, 2038, 84, 2365, 1972
2218, 2038, 2022, 2030, 2060
2219, 1959, 2320, 2039, 159
2220, 2040, 2011, 2066, 339
2221, 2047, 2041, 2055, 384
2222, 361, 1964, 2041, 2047
2223, 2310, 2370, 2358, 2042
2224, 385, 1985, 2043, 2055
2225, 2255, 2045, 1974, 82
2226, 2069, 2060, 2072, 83
2227, 339, 2066, 2046, 2063
2228, 2347, 1999, 2063, 2046
2229, 1961, 2059, 2363, 2048
2230, 2049, 83, 2255, 1954
2231, 2069, 84, 2038, 2060
2232, 2067, 2054, 358, 2032
2233, 2003, 2058, 2302, 2002
2234, 84, 2064, 2005, 2365
2235, 1944, 2065, 126, 2061
2236, 2016, 2054, 2067, 2289
2237, 2033, 359, 2070, 2329
2238, 332, 643, 2082, 2083
2239, 2112, 2087, 835, 1011
2240, 1008, 2092, 2094, 2108
2241, 2126, 2100, 901, 131
2242, 2103, 110, 848, 2114
2243, 1171, 2104, 2105, 116
2244, 2114, 848, 976, 2116
2245, 1175, 2115, 1077, 2149
2246, 1144, 1033, 2120, 2121
2247, 2125, 1054, 2157, 1168
2248, 2186, 2126, 131, 1433
2249, 2129, 1049, 2150, 233
2250, 454, 915, 2145, 2146
2251, 2148, 2147, 1297, 1450
2252, 1212, 442, 2147, 2148
2253, 2156, 1057, 2193, 1107
2254, 1185, 2121, 2159, 2172
2255, 1005, 973, 2160, 2161
2256, 2160, 276, 2204, 1138
2257, 2162, 432, 2197, 1318
2258, 1132, 2164, 273, 2206
2259, 141, 1240, 2165, 2179
2260, 1367, 2143, 2166, 2167
2261, 2141, 2174, 2176, 1268
2262, 1477, 2177, 193, 2217
2263, 2182, 1115, 375, 1211
2264, 2188, 933, 984, 1584
2265, 254, 902, 2189, 2190
2266, 1272, 2191, 1158, 2224
2267, 2201, 2200, 2242, 87
2268, 1229, 2158, 2200, 2201
2269, 1262, 2206, 273, 2244
2270, 1289, 2176, 2207, 2211
2271, 2208, 1265, 1248, 1288
2272, 2237, 2209, 335, 1398
2273, 1341, 2210, 2236, 314
2274, 2211, 178, 2239, 1393
2275, 2238, 2215, 232, 1554
2276, 2225, 1272, 439, 2265
2277, 2226, 1349, 2266, 438
2278, 2230, 1348, 2281, 417
2279, 2198, 1500, 396, 1584
2280, 1598, 2240, 1645, 2257
2281, 1418, 2243, 260, 2274
2282, 1686, 2246, 1564, 2291
2283, 2202, 1655, 2235, 1608
2284, 2256, 1336, 1360, 1453
2285, 2293, 2262, 1449, 2311
2286, 239, 1548, 2262, 2293
2287, 1443, 2340, 2339, 2263
2288, 2264, 439, 1272, 2224
2289, 1349, 2225, 2265, 2266
2290, 1329, 1409, 2267, 2268
2291, 2318, 2267, 438, 2266
2292, 1513, 437, 2268, 2325
2293, 2324, 2269, 437, 1513
2294, 1328, 1408, 2269, 2270
2295, 2272, 346, 2297, 1698
2296, 2275, 258, 2316, 1485
2297, 2276, 1370, 2307, 1669
2298, 2277, 247, 1435, 2294
2299, 1544, 419, 2322, 2279
2300, 2314, 2281, 1420, 418
2301, 2312, 1445, 2282, 1611
2302, 1796, 2330, 366, 2288
2303, 1648, 2290, 201, 2319
2304, 346, 1632, 2292, 2297
2305, 2294, 1435, 2234, 1486
2306, 241, 2341, 2298, 1545
2307, 2299, 2300, 1580, 1539
2308, 2301, 1481, 1480, 1568
2309, 2307, 246, 2349, 1669
2310, 2309, 1451, 424, 1623
2311, 1398, 336, 1691, 2237
2312, 399, 2313, 1492, 2350
2313, 2313, 399, 2364, 1670
2314, 2321, 2320, 1959, 1905
2315, 148, 2025, 2320, 2321
2316, 1659, 2279, 2322, 2327
2317, 1529, 240, 1715, 1628
2318, 2340, 172, 1338, 1393
2319, 2354, 223, 1765, 2367
2320, 400, 1757, 2355, 2376
2321, 2359, 2358, 2370, 1858
2322, 2358, 2359, 338, 2042
2323, 1763, 2317, 2360, 2361
2324, 2360, 1863, 1937, 2361
2325, 2377, 2367, 1638, 1722
2326, 2354, 2367, 2377, 224
2327, 2387, 2369, 420, 1764
2328, 2373, 1851, 1845, 2380
2329, 2374, 1512, 1616, 421
2330, 1911, 1959, 159, 2031
2331, 2380, 1845, 1866, 1908
2332, 2385, 207, 1919, 1817
2333, 2388, 1830, 2387, 1810
*Nset, nset=_PickedSet4, internal, generate
1, 2390, 1
*Elset, elset=_PickedSet4, internal, generate
1, 2333, 1
*Nset, nset=_PickedSet5, internal, generate
1, 2390, 1
*Elset, elset=_PickedSet5, internal, generate
1, 2333, 1
** Section: Section-1
*Shell Section, elset=_PickedSet5, material=Material-1
1., 5
*End Instance
*Node
1, 19.75, 26.7700005, -1.57863786e-15
*Node
2, 60., 3., 0.
*Node
3, 9.19800065e-16, 7.01999998, 0.
*Nset, nset=_PickedSet97, internal
2,
*Nset, nset=_PickedSet98, internal
3,
*Nset, nset=_PickedSet99, internal
1,
*Nset, nset=_PickedSet103, internal
1,
*Nset, nset=_PickedSet104, internal
3,
*Nset, nset=_PickedSet135, internal
2,
*Nset, nset=_PickedSet137, internal
1,
*Nset, nset=_PickedSet139, internal
3,
*Nset, nset=_PickedSet146, internal, instance="Sheet Metal-1"
9, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25
26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41
42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57
58, 59, 60, 61, 62, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492
493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508
509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524
525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540
541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556
557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572
573, 574, 575, 576, 577, 578, 579, 580, 581, 582, 583, 584, 585
*Elset, elset=_PickedSet146, internal, instance="Sheet Metal-1"
46, 68, 79, 80, 81, 105, 124, 127, 148, 154, 155, 161, 162, 183, 184, 185
186, 189, 190, 194, 195, 196, 198, 209, 220, 232, 236, 245, 246, 247, 253, 265
266, 267, 268, 269, 271, 272, 273, 274, 275, 276, 277, 278, 279, 281, 292, 308
310, 311, 324, 329, 331, 332, 340, 371, 375, 408, 423, 470, 513, 518, 532, 533
546, 589, 590, 596, 671, 709, 749, 750, 789, 807, 808, 821, 829, 837, 845, 847
850, 851, 874, 875, 877, 878, 879, 880, 881, 882, 883, 884, 885, 886, 887, 888
889, 890, 892, 893, 894, 895, 896, 898, 899, 900, 901, 903, 904, 905, 907, 908
909, 910, 911, 914, 915, 917, 919, 921, 923, 924, 925, 926, 927, 929, 930, 932
933, 934, 935, 936, 937, 938, 939, 940, 941, 942, 944, 945, 946, 947, 949, 952
953, 954, 955, 956, 978, 980, 987, 989, 990, 1002, 1007, 1015, 1049
*Elset, elset="_CP-2-Sheet Metal-1_SPOS", internal, instance="Sheet Metal-1", generate
1, 2333, 1
*Surface, type=ELEMENT, name="CP-2-Sheet Metal-1"
"_CP-2-Sheet Metal-1_SPOS", SPOS
*Elset, elset="_CP-3-Sheet Metal-1_SNEG", internal, instance="Sheet Metal-1", generate
1, 2333, 1
*Surface, type=ELEMENT, name="CP-3-Sheet Metal-1"
"_CP-3-Sheet Metal-1_SNEG", SNEG
*Elset, elset="_CP-1-Sheet Metal-1_SPOS", internal, instance="Sheet Metal-1", generate
1, 2333, 1
*Surface, type=ELEMENT, name="CP-1-Sheet Metal-1"
"_CP-1-Sheet Metal-1_SPOS", SPOS
** Constraint: Constraint-1
*Rigid Body, ref node=_PickedSet135, analytical surface=Die-1.CP-3-Die-1
** Constraint: Constraint-2
*Rigid Body, ref node=_PickedSet137, analytical surface=Clamp-1.CP-2-Clamp-1
** Constraint: Constraint-3
*Rigid Body, ref node=_PickedSet139, analytical surface=Piston-1.CP-1-Piston-1
*Element, type=MASS, elset=_PickedSet94_Inertia-1_MASS_
1, 1
*Mass, elset=_PickedSet94_Inertia-1_MASS_
0.1,
*Element, type=ROTARYI, elset=_PickedSet94_Inertia-1_ROTI_
2, 1
*Rotary Inertia, elset=_PickedSet94_Inertia-1_ROTI_
0.001, 0.001, 0.001, 0., 0., 0.
*End Assembly
*Amplitude, name=Amp-1
0., 0., 0.0001, 0.01, 0.0005, 0.02, 0.001, 0.03
0.005, 0.05, 0.006, 0.06, 0.007, 0.07, 0.008, 0.08
0.009, 0.09, 0.01, 1.
*Amplitude, name=Amp-2
0., 0., 0.001, 1.
*Amplitude, name=Amp-3, definition=SMOOTH STEP
0., 0., 1e-05, 0.1, 2e-05, 0.2, 3e-05, 0.3
4e-05, 0.4, 5e-05, 0.5, 6e-05, 0.6, 7e-05, 0.7
8e-05, 0.8, 9e-05, 0.9, 0.01, 1.
** MATERIALS
*Material, name=Material-1
*Density
7890.,
*Elastic
210000., 0.3
*Plastic
240.274, 0.
246.264, 0.0246
367.41, 0.026
418.025, 0.03078
439.375, 0.04
463.21, 0.05
469., 0.055
** INTERACTION PROPERTIES
*Surface Interaction, name=IntProp-1
*Friction
0.1,
*Surface Behavior, pressure-overclosure=HARD
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
_PickedSet146, 2, 2
_PickedSet146, 3, 3
** Name: BC-2 Type: Displacement/Rotation
*Boundary
_PickedSet97, 1, 1
_PickedSet97, 2, 2
_PickedSet97, 3, 3
_PickedSet97, 4, 4
_PickedSet97, 5, 5
_PickedSet97, 6, 6
** Name: BC-3 Type: Displacement/Rotation
*Boundary
_PickedSet98, 1, 1
_PickedSet98, 2, 2
_PickedSet98, 3, 3
_PickedSet98, 4, 4
_PickedSet98, 5, 5
_PickedSet98, 6, 6
** Name: BC-4 Type: Displacement/Rotation
*Boundary
_PickedSet103, 1, 1
_PickedSet103, 3, 3
_PickedSet103, 4, 4
_PickedSet103, 5, 5
_PickedSet103, 6, 6
** INTERACTIONS
** Interaction: Int-1
*Contact, op=NEW
*Contact Inclusions
Piston-1.CP-1-Piston-1 , "CP-2-Sheet Metal-1"
Clamp-1.CP-2-Clamp-1 , "CP-1-Sheet Metal-1"
Die-1.CP-3-Die-1 , "CP-3-Sheet Metal-1"
*Contact Property Assignment
, , IntProp-1
** STEP: Step-1
*Step, name=Step-1
*Dynamic, Explicit
, 0.01
*Bulk Viscosity
0.06, 1.2
*Boundary, amplitude=Amp-3
_PickedSet97, 1, 1
_PickedSet97, 2, 2
_PickedSet97, 3, 3
_PickedSet97, 4, 4
_PickedSet97, 5, 5
_PickedSet97, 6, 6
_PickedSet98, 1, 1
_PickedSet98, 2, 2, -44.
_PickedSet98, 3, 3
_PickedSet98, 4, 4
_PickedSet98, 5, 5
_PickedSet98, 6, 6
_PickedSet103, 1, 1
_PickedSet103, 3, 3
_PickedSet103, 4, 4
_PickedSet103, 5, 5
_PickedSet103, 6, 6
** LOADS
** Name: Load-1 Type: Concentrated force
*Cload, amplitude=Amp-3
_PickedSet99, 2, -5000.
** OUTPUT REQUESTS
*Restart, write, number interval=1, time marks=NO
*Monitor, dof=2, node=_PickedSet104
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT, number interval=100
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
RE: Classic Punch and die Probelm.
Problem can be either too soft penalty contact (if you are using penalty contact). Or too large elements in contact. The stiffer and more refined part should be the master surface. Try surface to surface contact. Include a seperate contact between edges (instead of faces).
As sdebock suggested, it is good if you attach the .inp file instead of pasting it here.
Also, according to the documentation (Defining contact between two separate surfaces) in section 34.3.1 (version 6.11pr3), there are three factors you should consider when deciding which surface to set as your master surface:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
