Using journal to select all
RE: Using journal to select all
What exactly are you trying to select? There are methods that allow you to select all the bodies in a part file or all objects on a given layer. If your "filter" is more complex, you'll probably have to sort through all the objects in code to find what you are after.
Here is a function taken from the GTAC solution center that might get you started:
CODE
'Date:  09/30/2010
'Subject:  Sample NX Open .NET Visual Basic routine : demo select all objects of given types
'Note:  GTAC provides programming examples for illustration only, and
'assumes that you are familiar with the programming language being
'demonstrated and the tools used to create and debug procedures.  GTAC
'support professionals can help explain the functionality of a particular
'procedure, but we will not modify these examples to provide added
'functionality or construct procedures to meet your specific needs.
    Function getAllObjectsByTypes(ByVal whatTypes() As Integer) As DisplayableObject()
        Dim objList As ArrayList = New ArrayList
        Dim thisType As Integer = 0
        Dim thisSubType As Integer = 0
        For Each obj As DisplayableObject In s.Parts.Work.Views.WorkView.AskVisibleObjects
            ufs.Obj.AskTypeAndSubtype(obj.Tag, thisType, thisSubType)
            For Each aType As Integer In whatTypes
                If aType = thisType Then
                    objList.Add(obj)
                End If
            Next
        Next
        Return objList.ToArray(GetType(DisplayableObject))
    End Function
www.nxjournaling.com
In this instance I am trying to select circles. have the code check the information on the circle and input its radius as a variable in an expression.
For example
If D<2", then blank circle,
Elseif change color of circle to blue.
The problem is I usually have objects on different layers, around 1-100. This select all command is quite tedious for NX. Even when I do it through journal to see what code it refers to NX Open for samples of such code but I cannot find any.
Here's some code that may get you started:
CODE
'eng-tips thread561-335918: Using journal to select all: Using journal to select all
'select displayed arcs, do something based on arc radius
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
 'Get visible objects in work view
        Dim visibleObjects() As DisplayableObject
        visibleObjects = workPart.Views.WorkView.AskVisibleObjects
        Dim tempArc As Arc
        For Each tempObj As DisplayableObject In visibleObjects
 'test if object is an arc
            If TypeOf tempObj Is Arc Then
                tempArc = tempObj
                If tempArc.Radius < 5 Then
 'do something with small arc
                    tempArc.Blank()
                Else
 'do something else with large arc
                End If
            End If
        Next
    End Sub
End Module
Cowski, I have put this journal on the backburner for a while now, but I keep running into an error while trying to run the Displaymodification1.apply command.
I do not know what the arguments are and I am doing something run in the process of executing it. Please look at this when you get a chance and let me know if you see anything. Thanks in advanced.
CODE --> vb
'eng-tips thread561-335918: Using journal to select all: Using journal to select all: Using journal to select all: Using journal to select all
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.uf
Imports NXOpen.utilities
Imports NXOpen.Assemblies
Imports System.Windows.Forms
Imports System.IO
Imports System.Collections
Imports System.Environment
Imports NXOpenUI
Module Module1
    Sub Main()
        Dim S As Session = Session.GetSession()
        Dim workPart As Part = S.Parts.Work
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim selobj As NXObject
        Dim arc1 as ibasecurve
        dim cpoint as point = nothing
        dim kk as integer=0
        Dim type As Integer
        Dim subtype As Integer
        Dim lw As ListingWindow = s.ListingWindow
        Dim layerObjects() As NXObject
        Dim layerObjectsDisplayable() As DisplayableObject
        Dim layerColorID(256) As Integer
        layerColorID(1) = 6
        Dim tempArc As Arc
                Dim displayModification1 As DisplayModification
                displayModification1 = S.DisplayManager.NewDisplayModification()
                'displayModification1.NewColor = layerColorID(1)
                'displayModification1.NewFont = DisplayableObject.ObjectFont.LongDashed
                displayModification1.NewWidth = DisplayableObject.ObjectWidth.Thick
                displayModification1.ApplyToAllFaces = True
                displayModification1.ApplyToOwningParts = False
                tempArc = tempObj
                If tempArc.Radius < 1 Then
Dim objects1(0) As DisplayableObject
objects1(0) = temparc
displayModification1.Apply(objects1)
displayModification1.Dispose()
                End If
            End If
        Next
    End Sub
End Module
Try moving the Dispose command outside of the for loop. As it stands now, the displaymodification object is being destroyed when the first arc with radius < 1 is encountered.
CODE
                tempArc = tempObj
                End If
            End If
        Next
    End Sub
Alternately, you may get slightly better performance by creating a list of objects, adding the desired objects to the list in the for loop then applying the display modification to the entire list at once after the for loop.
I tried moving the dispose command down and it removed one of the errors I was recieving and gave me another one with the apply command.
I will try that, you wouldn't happen to have any sort of general list code that I could use to this would you?
Try this:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports System.IO
Imports System.Collections.Generic
Imports NXOpenUI
Module Module1
    Sub Main()
        Dim arc1 As ibasecurve
        Dim cpoint As point = Nothing
        Dim kk As Integer = 0
        Dim type As Integer
        layerColorID(1) = 6
        Dim arcList As New List(Of Arc)
        Dim tempArc As Arc
                tempArc = tempObj
                    arcList.Add(tempArc)
                End If
            End If
        Next
        If arcList.Count > 0 Then
            displayModification1.Apply(arcList.ToArray)
        End If
    End Sub
End Module
