Tank external floating roof dismantling
Is there any code for dismantling an EFR that is landed on legs and tank cleaned??
Or any experiences for such a job?
RE: Tank external floating roof dismantling
Other than safety issues and whatever jurisdiction (possibly confined space, too), I'm not aware of any API requirements... new work should conform to something.
It may be a matter of scaffolding around the tank and using a mobile crane to hold and lift the removed portions... Depending on the construction, you may be able to use a hydraulic shear attachment.
Dik
Should have added that there is an "Above Ground Storage Tank" forum, somewhere...
Dik
