Standard carbon steel barrier coating
Hello!
I am researching a product improvement application that will require adhering a (rubber foam) item to a surface of a conventional nail clipper. In researching the adhesive/process most applicable, I wanted to find out what specifically is the standard anti-oxidant coating used in this application. Zinc galvanization is my theory, but I was hoping to confirm this. Hope someone knows this off the top of their heads.
Thank you!
RE: Standard carbon steel barrier coating
My nail clippers appears to be chrome plated. The plating is pretty cheap though; it doesn't keep the clippers from rusting in the shower.
SceneryDriver
SD is correct, nail clippers are Cr plated.
Normally Cr plating,some do blueing or blackening .
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Great. Thank you everyone! Any suggestions on permanent adhesion of foam to it? Trying to use cyanoacrylate (or any one-part, I suppose) if it can be helped. Got suggestions from 'The Handbook of Rubber Bonding' but if there are any more, would be glad to hear.
Thanks again!
